Diverge 2018
#251
Bikes: 2017 Specialized Roubaix, 2007 Giant Anthem, Polygon Quatro
Quoted: 103 Post(s)
It's reserved for future updates so they can make marketing claims like the new Diverge shaves off 500g from the previous version
#253
Quoted: 2432 Post(s)
Liked 638 Times
That E5 looks good. FYI my 54cm '17 A1 weighs 22.5 stripped of everything. I calculated how much weight I would drop if I replaced the Claris shifters/derailleurs with 105 and the difference was virtually nothing, just a few grams. 105 weighs more than I thought.
#254
Bikes: Coppi Campionissimo, Gios Super Record
Quoted: 5 Post(s)
Nice, the color actually looks quite nice! Do you Custard remember what size is this turquoise E5 pictured? 52 perhaps?
#255
Quoted: 128 Post(s)
I actually couldn't shift onto the big ring, which means I don't think I'll be buying from this shop!
Next time I'm in a shop I'll see if I can get a 54 2017 Elite DSW weighed.
#256
Quoted: 37 Post(s)
How robust is the E5 frame? Does it feels more solid than a "pure" road bike? I'm tempted to get one for commuting, hauling my kid in a trailer and some road riding, and I want something bullet proof.
#257
Quoted: 103 Post(s)
Cause Spesh wouldn't want to have their frames to crack easily and having to replace them.
Oh and if you're not into gravel/need large volume tyres, do consider the 2018 Allez as well since it now comes with rear rack mounts as well (so you can commute).
#258
Bikes: Cutthroat, Scalpel, Roubaix, Sequoia, SuperX, Diverge
Quoted: 51 Post(s)
just a few notes from me as i spent a good hour riding the new Diverge Comp around on some nice climbs, a small amount of trails (all hardpack), and some nice cobbles.
This is coming from the perspective of a guy who owns a 2013 Fargo, a 2015 Roubaix, and a 2016 Cutthroat.
1. The FutureShock - I'm 115kg/250 lbs, and when I stood out of the saddle to climb a hill, I didn't notice the shock. When I got to a flat, stood and hammered to accelerate hard, I didn't notice the shock. When I turned around and descended down the cobblestone road, I noticed the shock because I *didn't* notice the cobblestones. I was a skeptic about the FutureShock. Now I'm a believer. Enough said from me on that.
2. The one I rode came with 38c Trigger Pros. I'm a big fan of the tires, I like their all around use. Substantial clearance with the 38s. Easily enough to ride the 38s in the mud using front and rear fenders. LBS fit a 42c Sawtooth with room to spare as well, but don't think enough room to fit 42c and fenders
3. Riding position is notably more relaxed than the Roubaix (2015 Roubaix geometry is notably more relaxed than 2017) or even the Sequoia. Not quite as relaxed as my Cutthroat or Fargo.
4. I basically had my Sequoia built from the frame up, and it's 22#. The Diverge felt noticeably lighter, even with the Axis wheelset
5. The "satin blue" Comp looks a lot more like the dark Indigo on some of Spec's other bikes. It actually looks pretty darn good.
6. The 105 and the Praxis shifted surprisingly well, better than I remember 105 shifting (my Roubaix has Ultegra). That said, I'm targeting the Expert as i'm a fan of the SLX24 wheelset as well as Force 1
#259
Quoted: 103 Post(s)
Wow, so your dealer allowed you to ride the Diverge Comp on real trails for an hour?
Yeah, the FutureShock is definitely not a gimmick and I hope it'll continue on for years to come, something like Specialized Brain for the Epic MTB lineup.
I just receive the 2017 Roubaix and my neighbourhood had some trails where it's paved but the roads are in very bad condition, I basically cycled through those areas like how I do with my previous Giant Anthem, sure it's not MTB suspension plush (and you really can feel the frame vibrate) but your arms doesn't hurt at all (definitely smoother than a road bike).
I ended up choosing the Roubaix over Diverge as where I live, its "offroad" is usually paved (as the farmers uses it) and it'll be in a poor condition (cracked, potholes and etc). Oh and as I live on an island, "offroad" are mainly hills over flat roads, the only flats you can get if you actually cycle on the road
#260
Quoted: 51 Post(s)
and yes the futureshock really takes the buzz entirely out of the equation in a good way.
#261
Quoted: 103 Post(s)
my family has bought a dozen bikes from the same shop. They take care of me, I take care of them.
yeah, makes sense. I'll be looking for some dual use of the bike, on- and off-road use, gravel, pavement, mucked up pavement, etc.
Yup, same as me. I wanted a bike that I can go anywhere, thankfully Spesh introduced the FutureShock in 2017, made selection much more easier.
Anyway, regarding tyre sizes, the Roubaix Comp comes with R470db which I assume has the same dimensions as a R460db. So will a 32C with knobbies be slightly smaller? As if I'm not mistaken, rim inner width affects how big the tyres will be when inflated?
As the 2017 Roubaix fits up to 32C tyres.
Currently considering a Panaracer GravelKing SK (hmm, there's the non-SK version at 32mm also, but it seems they're no knobs?) for my training tyres.
#262
Quoted: 1872 Post(s)
Liked 692 Times
Brutal, that's almost what my Tamland weighs and I have several hundred less into it than the price of the Diverge.
2019 Salsa Warbird
2019 Salsa Warbird
#263
Quoted: 128 Post(s)
I do wish there were a corporate code for Spesh!
#264
Quoted: 128 Post(s)
#265
Bikes: Specialiced Roubaix Comp 2017; Giant Anthem X1 2008 (MTB)
Quoted: 16 Post(s)
Max cassette with 105 rear derailleur
I orderered a Diverge Comp E5. What is the largest cassette I can use with Shimano 105 rear derailleur without going to have Problems? I do not want to castantly have to do adjustments. I just want the gearing to work smootheley. I do. not have a lot of experience screwing on a bike.
What about using an XT rear derailleur? Does this work together with 105 components? Can I use larger cassettes with XT derailleur?
I would like to have a 36 teeth cassette or larger.
#266
Quoted: 5 Post(s)
This is my main concern too. The frame is perfect, and as far as I can say, there are no similar frames available, that provides heaps of performance and versatility (plenty of tire clearance, adventure ready mounts, low standover). But for 3450 euros (price for Carbon Comp in north Europe) unfortunately, it feels quite over priced, where one would expect at least Ultegra level components & better wheelset. The stock Carbon Comp weighs 2kg (4,5 lbs) more than my steel road bike. Still, I want one, but I'd like to see Specialized offering Diverge as a frameset too.
#267
Liked 638 Times
#268
Quoted: 103 Post(s)
#269
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
Shimano 11 speed road shifters do not play well with their MTB rear derailleurs. Wolf Tooth also makes the Tanpan to facilitate that combination.
#270
Liked 692 Times
Mine is sitting at 23lbs right now with a little more to come off still Adding up the bike, wheels, and bits I've bought for it I'm still well under $1799.
2019 Salsa Warbird
2019 Salsa Warbird
#271
Liked 692 Times
https://www.specialized.com/us/en/me...rameset/128906
2019 Salsa Warbird
2019 Salsa Warbird
#272
Liked 692 Times
Sorry if this has been asked but I didn't see it. Can the stem be slammed with the FS?
2019 Salsa Warbird
2019 Salsa Warbird
#275
Liked 692 Times
I kinda figured that might be the case. How much adjustment is available then?
I mean kinda, but everything I bought was available to anyone..
2019 Salsa Warbird
2019 Salsa Warbird
