Settings for the Varia RTL510 - on/off/standby?
Quoted: 800 Post(s)
Liked 512 Times
For those of you who own the Garmin Varia RTL510, I have a question for you. Ok, maybe two questions.
In my reading of the manual, there are basically two on/off settings.
- The unit is totally off
- The unit is in stand-by mode, waiting to pair/connect with the head unit. The light is off and by all appearances the unit is 'off'.
- Am I correct in my understanding of the on/off settings? If so,
- What off mode do you keep the unit in? If the unit is in sleep-mode, do you notice significant battery drain between uses?
Quoted: 20810 Post(s)
Liked 9,456 Times
Yes. In the 4th mode, as selected by the on-unit button, both the light and the radar are off, though the little status LED will flash occasionally to let you know it's in Standby. A long press of the button turns it fo real off.
I leave it in off-off because I have a Wahoo, which doesn't do ANT+ light control, which means Standby doesn't do me any good.
Quoted: 152 Post(s)
Liked 173 Times
I have a Garmin 830 which does form a light network so I leave in stand-by mode (occasional blue LED flash). It has virtually no effect on battery life. I think the battery life in standby mode is 5 months and it is handy to have the light come on automatically. Plus you can control it from the computer although I just leave it in day flash mode since I only ride during daylight hours.
Likes For August West:
When riding primarily indoors I turn it off. When most of my rides are outdoors I will put it to sleep instead of turning it off.
Quoted: 173 Post(s)
Liked 57 Times
There's a standby mode? Like if I park the bike for a bit while I rest the unit will remain on, but not active (no solid light or flashing)? How do I put it into standby?
Liked 9,456 Times
Standby isn't like an auto inactivity shutdown, it's a mode for waiting for for ANT+ Light instructions from your (compatible) cycling computer. As you cycling through the lighting modes (with short presses of the on-unit button), Standby Mode is the 4th and last option. I supposed that putting it in to Standby would be easier with gloves than the long press to turn it off completely (and then back on afterwards).
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Today it randomly disconnected after about an hour. I think Wahoo has a whole bunch of bugs and incompatibilities to sort out. Or just ways they tickle bugs in the Garmin firmware. Their support seems a little POC grade.
Liked 9,456 Times
When my friend connected his Garmin GPS to my Varia, his GPS battery drained really, really quickly. I've since heard others report the same, so I'm happy with the Wahoo compatibility on the whole... though I do wish that Wahoo would get on top of ANT+ Light control - that would take care of both my Varia and Cycliq and I'd be a happy camper.
Garmin / ANT+ needs to do a group-ride / stumble upon network thing with those. Say after 30 secs of consistent signal, it'll just add the Varia data feed to any head unit that wants the data. If you're varia-less and you join a group ride and you have it enabled, you'd get the radar data from the other guy.
Liked 9,456 Times
It's BLE / ANT+. If you're in range, you're about 3-10ft from the unit and you'd be going the same direction. What's confusing about that?
Liked 9,456 Times
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
So.. is there a mode where there's no light but radar works with the head unit? Obviously I haven't played enough with my own unit.
Liked 9,456 Times
Only only if you have ANT+ lighting control through your GPS unit. There's no way to access the mode directly through the on-unit button. IOW, Wahoo users are SOL for the time being.
Liked 9,456 Times
Likes For WhyFi:
Bikes: Yes please
Quoted: 536 Post(s)
Liked 308 Times
if you have a garmin unit, swipe down and right/left to get to the lighting control page and then you can turn the light off, without turning the radar off.
Likes For kissTheApex:
Advocatus Diaboli
Liked 1,532 Times
Sy Reene, this ^..
Quoted: 800 Post(s)
Liked 512 Times
How are you noticing battery drain on the 520 with the Varia connected? The battery on my three old (or is it four?) 520 head unit is draining much quicker now that I have the Varia connected. I am interested in hearing your thoughts/feedback. Thank you.
Liked 9,456 Times
I too am using the Varia with my 520 unit.
Advocatus Diaboli
Liked 1,532 Times
Quoted: 800 Post(s)
Liked 512 Times
WhyFi Sy Reene Yeah, it really is too bad about the battery drain. I like the Varia and I like the fact that I am altered to cars coming up behind me. But if having the unit on means I cannot complete a century ride without the 520 dying on me, that's not very promising. My 520 still does everything I need a bike computer to do, and I'd hate having to buy a new computer just because 520 doesn't have the battery power. I see the 1030 is on sale right now, but still.
Mrs. NoWhammies has the new Garmin 530. I can always see if the battery drain on her system with the Varia is just as bad.
Advocatus Diaboli
Liked 1,532 Times
Liked 9,456 Times
Some posts out there on the interweb, seem to say that it depends on how often you're actually getting traffic hits, as it turns on the backlight each time. So it's said that it's not really the radar that's the cause of battery drain, but the backlight turning on and being on that much more. Workaround may be to reduce brightness of backlight to eg. 10%
Advocatus Diaboli
Liked 1,532 Times
I know. My recollection though (haven't ridden and tried this out to verify yet) is that each time the Varia gets a hit on traffic behind, the head unit beeps, and the backlight goes on. A more trafficked area can mean your head unit's backlight is on a lot more than with the varia not running. I'm going to try a lower brightness on the backlight, and also reduce my backlight timeout setting to 15 seconds (had it at 1 minute).
Likes For Sy Reene:
