Schwalbe One Tubeless
Quoted: 33 Post(s)
Anybody use these tires?
I read a review and they seem to have rolling resistance comparable to the Conti 4000 ll.
Do you have to put anything inside the tire or can you just ride them on a tubeless rim.
The only minus I can see is that they are a bit heavier.... about 345 grams vs 215 for the Conti.. (although a tube does weight close to 100)
will stop for donuts
Quoted: 13 Post(s)
I've been running them all this year, and love them. I have a set of 23's on Bontrager Paradigm rims, and they measure out at 26.5.
They held air just fine without any sealant, but then you're kind of losing some of the benefits of tubeless. I'm running 30ml of sealant on either tire to help seal puncture flats.
Overall, they are fantastic tires. I'm about 145, and running 80psi in the front and 85 in the back, and they feel firm, smooth and fast under me. Would definitely recommend.
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
I just got my tubeless wheels built and was going to use Orange Seal initially, but I have the 23 PRO Ones. I use NoTubes sealant in the mountain bike tires and have for years but since I have some Orange Seal (used on the Fat Bike) I'll guess I'll use that thigh I prob still have Notubes/Stan's sealant left. I have been using the Conti 4000s for a while and recently switched to Vredestein Quattros or whatever. I prefer the Vreds for comfort...speed seems similar. If we continue with this good weather, I'll report back soon. The Contis were pretty harsh over road gaps and jolts. Looking forward to trying the Pro Ones soon.
Non omnino gravis
The Schwalbe One tubeless is a tire that trades everything for grip and low rolling resistance. It's like an F1 tire for a bike. If your roads are immaculate, expect around 1,200 miles from a rear. If they're real-world roads with potholes, chipseal, and the usual detritus, expect 900-1,000. There is absolutely zero flat protection built into a One, it all comes from the liquid sealant. And everything will puncture. I had to top off sealant every 2 weeks, just from the amount expelled during punctures.
But man, were they ever fast and smooth.
Quoted: 33 Post(s)
Non omnino gravis
I'm wondering why one would want to run a tubeless tire without sealant and also why not buy the new Pro One's that are way ahead of the original One's in weight reduction, rolling resistance, and ride quality? I had my first puncture riding tubeless a few weeks ago and the sealant did its job so I made it back home without having to break out the repair kit.
Quoted: 33 Post(s)
If you run without sealant....would you have as much flat protection as riding on a tubed rim....
Debris still has to penetrate the tire...does a tube really offer any additional protection. I figure is something penetrates the tire it will also pop the tube
Super Modest
Quoted: 10965 Post(s)
Liked 4,621 Times
As for Schwalbe Ones, I agree that the wearability is shorter lived than say, 4000s.
Keep the chain tight!
Tubeless tires have inherently better flat protection than an equivalent tubed tire. Since the tire is totally sealed, a pinhole leak remains a pinhole, while with a tube, the hole can expand as the tube stretches and can flop around the rim. Tubeless are much less likely to suddenly deflate, and will stay locked on the bead even with total deflation.
