10-speed Compatibility
Hello,
New to this forum. Please advise.
Are there any inherent issues/concerns with the following combination?
Current drivetrain:
Shimano Dura Ace 7900 10-speed crankset. 39/53 – 175mm
Shimano Dura Ace 7900 10-speed 11x28T cassette.
Intended upgrade:
Shimano Ultegra FC-R8000 11-speed crankset. 46/36 – 175mm
Sram PG-1070 10-speed 11-32T cassette.
What new chain would work best with this combination?
Thanks for your time and consideration.
Current drivetrain:
Intended upgrade:
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Likes For datlas:
I believe that the 11-30 cassette will work with a standard cage derailleur, but 32 will require a medium cage derailleur as you have mentioned.
Any ideas on the best option?
Liked 8,925 Times
It would be helpful if you told us every component of your drivetrain: RD/FD/Shifters.
You might be able to finesse the 32t with what you have, although cross-chaining may be a problem. See what others in the collective suggest as well.
Sorry about inadequate information. The bike is a 2008 Cervelo R3. The entire drivetrain is 2008 Shimano 10-speed Dura Ace 7900. 11-28 cassette & 39/53 crankset. Wheelset is 2009 Mavic R-SYS SSC.
Liked 8,925 Times
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
You do realize you're going to lose your top end with that gearing combination? Unless you're a spinning fool, of course.
Thanks again for the reply. I have located a new, unused complete Ultegra 6800 11-speed groupset with 11-32 cassette and 34/50 crankset. Very reasonable price. May be a better option for a few more dollars.
Regarding top end.....yes that is a serious concern. We do a lot of climbing here. This is the reason that I think the above listed Ultegra 6800 groupset might be a better option for me. Thanks for the comment.
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
If you pass on the new 6800 let me know I would love to have it. And yes if I were you given a bike I like I would upgrade to R7000. Then you get it all go for the 11-34 cassette.
I run a 46/30 crank on my road bike that does double duty as a gravel bike. How much time on a typical ride do you spend pedaling at over 30mph? It is a lot less than I spend pedaling at 8mph climbing steep hills that is for sure lol. Anyway if I were doing it today I'd go with a GRX crank with 48/31 gearing. That option wasn't available at the time I made the switch. Yeah you need a new FD to go along with it but those are cheap.
