For Want Of A Nail....
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,923 Times
I recently acquired a 1985 Centurion Ironman in really good condition, but of course I stripped it down, cleaned it and am putting it back together - original stem and bars is one thing. Original grease in the BB and headset is something else entirely. It came with what I assume was the original front reflector, which puzzled me because it had none of the other reflectors. This one was one of those that fits into the headset under the locking nut.
It turns out, that is exactly why it was there. Without it, the lock nut bottoms out on the top of the steerer before contacting the top cup, so it doesn't lock up anything. "Oh, well," I thought, "I'll just run out to a bike store and pick up a spacer to replace it."
Yeah, right.
I'd figured any shop that's been in business more than 10 years would have a bunch of these. Turns out, not so much. So I turned to Ebay, where I discovered you could either buy a pack of 10 of them, or buy a single one from Europe and pay exorbitant shipping and wait a few weeks. So I ordered a 10 pack, and meanwhile used a hacksaw to cut the reflector mount down to a 3/4 circle I could use as a spacer in the meanwhile to complete the build, pending the arrival of the spacer I needed and 9 more that I don't.
So, first, where did all the spacers go? And second, have you ever been stymied by the inability to find what SHOULD BE a common-as-dirt part that EVERYONE used to have?
Yeah, right.
Likes For genejockey:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Pretty sure I do, too. Shoulda put out an ISO!
Incidentally, when the oddball headset on my Diamondback started having trouble staying in adjustment, I added a reflector bracket. With that, I had a visual indication whether the stack of headset nuts had loosened, and a convenient way to swat it tighter for the time being. (Now that I've ground down a headset wrench to 33mm, I can finally adjust it properly and the reflector bracket is now superfluous again.)
Quoted: 1088 Post(s)
Liked 1,205 Times
Send me a PM if having nine spares seems like too many for you...
Likes For noobinsf:
It does boggle the mind when you think a part should be a “sure thing” find. I have two bike shops in my town. One looks at me confused when i don’t want the latest and greatest thing...
The other one has a bone yard of parts decades old. Guess which one I hang out in!
Likes For 3speedslow:
Likes For mprince:
ambulatory senior
Quoted: 1956 Post(s)
Liked 3,662 Times
I've cut down so many of those spacers. The reflector brackets that are also cable hangers usually get modified by me too.
Quoted: 4560 Post(s)
Liked 2,802 Times
Yup, before the original Nashbar was sold out I bought an old style keyed spacer and, for bikes with cantilever brakes, a cable hanger that doubled as a keyed spacer.
Centurion may have changed that design later. My 1989 Ironman and early 1990s Univega came without the reflector mounts. On the Univega the reflector mounts also doubled as emergency catchers in case a straddle cable broke -- extremely unlikely considering how thick those cables are, so I never bothered replacing the cable catchers. Either those bikes didn't need the keyed spacer, or whoever removed the reflector mounts replaced them with their own keyed spacers which were probably readily available back then.
Quoted: 502 Post(s)
Liked 466 Times
Likes For Dfrost:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Quoted: 472 Post(s)
Liked 1,037 Times
I'll submit that a spacer without the bitty key are better even. I've seen plenty of those key nubs turned and ground away, which makes life harder and damages the steerer tube. I've filed them off when in doubt. I believe the key's interface was only a manufacturing convenience. File the key off the spacer, put it all together and use two wrenches properly.
Likes For Prowler:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
Quoted: 3464 Post(s)
Liked 2,831 Times
i would have gone to American Cyclery
they were on Fremont, closed during an earthquake retrofit but last I read were back up snd running.
the typical reflector brackets were to withstand a 50 lb load without bending. Usually just above 1mm thick, so depending you might need one or two washers.
Liked 2,831 Times
Now 756 Stanyan street
Sunshine
Quoted: 10970 Post(s)
Liked 7,498 Times
SF area has to have plenty of bike collectives/co-ops. Anywhere that still deals with threaded headsets should have tons of spacers.
Liked 11,923 Times
So I decided that phoning was no good, and I'd have to actually physically go to every shop, if I wanted to find one. So I ordered the bag of 10 and broke out the hacksaw. Shakedown cruise should be tonight.
Liked 11,923 Times
not for free
Liked 11,923 Times
SF is 20 miles away, plus you'd think the older bike shops on the Peninsula that do a lot of business servicing old bikes would have them. But you'd be mistaken. I was.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
They don't strictly need to be keyed; it just helps hold the adjustment while you tighten the locknut. With a non-keyed spacer, you can use one of your headset spanners to hold the adjustment while you tighten things down.
Liked 11,923 Times
Liked 11,923 Times
Bianchi Goddess
Quoted: 2937 Post(s)
Liked 2,934 Times
Is it that they don't have the spacer or the employee just didn't understand what you were looking for because you had a threaded headset?
Working at a well known Boston shop around 1995 or so I saw an employee refuse to sell someone a freewheel for an older Fuji (something like an '85ish Team or Ravoli) but anyway the customer asked for a Suntour freewheel and since we didn't have any Suntour freewheels on the shelf this guy wouldn't sell him anything despite my repeatedly telling him a Sachs FW would work even better than the Suntour. He said NO since it had a Suntour RD it had to have a Suntour FW to shift properly. I think it has been down hill for shop service since that day.
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 280 Post(s)
Liked 955 Times
@genejockey for anything vintage there's a really good chance that Cupertino Bike Shop would have it. If you go there for anything, W,TH, & Fr are the best days since Greg Davis, their Vintage Mechanic, works those days. On other days the knowledge of where the different vintage parts are located is a little more hit and miss.
Likes For SwimmerMike:
