Pics of your IGH touring bikes.
Bikes: Mercier Kilo WT5, Fetish Cycles Fixation MTB, Schwinn Pro Stock 3 24" BMX, 70's Schwinn single speed beater
Post some pics if you IGH touring bike.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Liked 16 Times
Here is my 1972 Raleigh Superbe and my 1971 Raleigh Twenty both which get used for tours. I actually can tour on any of my bikes, I just choose the one that strikes my fancy and works for the trip I am on. I don't have any loaded pictures for some reason. Most recent trip was a S24O down near Charleston, SC. I rode the Twenty about 35 miles to a campground spent the night and rode back the next day.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
You can go to Rohloff.de, there is a builders list of framebuilders , there.
N.H. based Peter White imports and retails German Tout Terrain frames from Germany.
Eccentric BB for chain tension, is a common tandem frame component
to tension crossover timing chains..
CoMotion in Oregon builds Rohloff ready frames , as does UK Thorn bicycles
another solution is a sliding dropout on the back, the axle and disc mounts slide together
so stay in adjustment relative to each other
if you are retrofitting a frame with a disc mount reaction fork piece OEM 2 slides over the lower bolt
of an ISO disc mount, and a chaintensioner takes up slack .
I got this a Koga WTR '04 used, 3rd hand. low mileage https://www.cyclofiend.com/working/20...clark1008.html
added the Schmidt generator hub.
there is a signature program at Koga Now, a menu of component choices is built up in NL factory
then shipped to dealers, but there are few in the US,
But you could have a meeting abroad with one near the Airport
say Shiphol AMS, in Holland.
