Will my mixed cassette work?
budget minded enthusiast
Bikes: 2010 Specialized Epic, 1992 Giant Allegre
I have a Shimano Tiagra 9 speed shifter going to a Shimano 105 rear derailleur and am on a tight budget. I have a Shimano 11-22 cassette on it but live in a very hilly area and want to upgrade to an 11-30. I have a Sram MTB 11-34 cassette that I'm not using and was wondering if
I could steal some of the larger cogs off of that and make a combined Shimano-Sram cassette. Would this work with my setup??? Any help would be much appreciated. Thanks!
Randomhead
Liked 3,699 Times
Moved here from General
Quoted: 18378 Post(s)
Liked 4,512 Times
It probably will work depending on the cassette model. Ultegra, and I think 105 cassettes use common carriers for the larger sprockets. Lower level cassettes tend to have the sprockets pinned together. You can remove the pins to gain access to the loose sprockets on the cassette, and don't need to put the pins back in.
I assume SRAM would be similar.
One of the issues you will have is that all the modern cassettes are designed with a specific arrangement of shift gates. Mixing cassettes, and the gates may not line up as the manufacturer intended.
The result is that your mixed sprockets may not shift very well. Not a huge problem, but it could be an annoyance.
Double check the specs on your derailleur that it will clear a 30T rear sprocket.
Bikes: Disc Trucker, Big Dummy, 74 Le Tour, Stumpy FSR 29, Tall Bike, Foundry Broadaxe, Burley tandem
It will work, just not very well.
Sram and Shimano cassettes teeth are in different locations so shifting will be chunky.
I think 105 9 speed derailleurs are spec'ed to work with max of 28T but I've seen them work on 30T.
Make sure that the cage and chain are long enough to get into all the gears.
Try it, and if it doesn't work well the just buy an 11-30 cassette (and maybe a new chain).
Edit: Clifford, you beat me to it.
Really Old Senior Member
Was the 11-22 you mentioned a misprint?
IF you interchange brands, I'd keep the same brand spacer with the same brand cog.
The cog thickness MIGHT vary. The corresponding spacer would compensate.
Probably insignificant, but.....
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
9 speed SRAM cogs and spacers are different width than Shimano
Sheldon Brown's Bicycle Glossary Sp - Ss
Thanks a bunch guys! The derailleur does clear the 30t sprocket. It looks like I will be able to remove cogs as necessary from the cassettes so I'll give it a go (keeping in mind to use the corresponding spacer to cog brand) and see how it works. And yes by the way it was actually an 11-23 cassette. If it's unbearably bad I'll buy a new cassette I guess. Thanks again.
makn'a phonecall to doggy
Quoted: 24 Post(s)
You can align the ramps somewhat and file the one (perhaps two) misaligned groove/s to fit the sprocket to the freehub. You can also re-profile the teeth. The shifting can be finessed via technique.
never heard of that, I would be interested in to know how its done successfully. Make a video
I tend to wear out 17 and 19 tooth cogs. So instead of replacing the entire cassette, I crack it apart, and just replace the cogs that wear down.
Don't overthink this stuff. Buy some replacement cogs from your local bike Co-op (mine charges at most $1 per cog), drop them in, and see what happens. Of course you need the correct spacers, which should be your originals. Cog to cog spacing is critical, the shape and branding of the cogs not as much.
Frankly, I have done all kinds of mix and matching with cassette cogs, including cogs from different brands and even mixing Hyperglide and Uniglide loose cogs. The Uniglide cogs result in somewhat clunky shifting, but I cannot tell much difference in the shifting performance in mixing up newer generation cogs.
Of course you bike shop will tell you that mixing cogs will result in a global Armageddon, but actual experience is otherwise.
No need to file or buy any cogs, it all seems to work fine with just a little clunkiness on the transition from the Sram to Shimano gear. It's good enough for me so I guess that works. Thanks for the help.
[QUOTE=Dave Mayer;18561538]I tend to wear out 17 and 19 tooth cogs. So instead of replacing the entire cassette, I crack it apart, and just replace the cogs that wear down.
I've not had such luck I usually find shifting is compromised, shifting ramp location and profile has a big part to play I assume
regards Pepe
Liked 4,512 Times
If you do it, I would encourage you to do 1/2 Shimano, and 1/2 SRAM, splitting somewhere in the middle, rather than mixing in a few Shimano, then a few SRAM, then a few more Shimano, and a few more SRAM.
New 9s Cassettes are typically cheap enough, or I sometimes find good used ones at my local Co-op.
