Re: Power Efficient Ebike Conversion Help
Bikes: Dahon Speed UNO, Schwinn Hybrid, MTB
Hello,
I purchased a 8 speed legend populo commuter bike. I like the look of it and I want to convert it to an ebike. I do not mind peddling and need some assistance with hills. So, I want something simple, small, and efficient. I am leaning towards a small front hub. Does anyone have any 250w front hub recommendations? My goal is to have something that is efficient that will give me a boost up hills.
Thanks!
Thanks!
Bikes: Treks and a Moulton
Quoted: 64 Post(s)
You might find these threads interesting...
https://www.bikeforums.net/electric-...st-system.html
https://www.bikeforums.net/electric-...ub-review.html
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times
I suggest that you take a look as something like one of these:
https://www.amazon.com/Arrival-Elect.../dp/B0736T5RFG
https://www.amazon.com/Electric-Moun.../dp/B01N1VR6ND
https://www.amazon.com/Electric-Moun.../dp/B075SYVWW2
And then change the sprocket to only provide assist up to say 10 mph. The motor has a freewheel on it, so no problem over speeding the motor, or shutting it off entirely. The motor will provide no assist above its maximum revs. The above motors at the output of the gearbox run about 300 rpm at the rated voltage; they have a 12T sprocket. To get ~10 mph, that would be matched with a 30T sprocket on the rear wheel. This would give you a good amount of hill assist, and absolutely no top speed assist.
Motors do not like to be heavily loaded at less than about half their maximum speed. Hill assist is almost always by definition less than that. Many direct drive hub motors have a noticeable amount of drag when not powered.
Bikes: All mine are electric bikes now
Quoted: 57 Post(s)
Liked 59 Times
Clean Republic has a nice 250w front hub that is extremely easy to install, small and unobtrusive if you want your bike to pass at first glance to look exactly like a "regular" bike, and will certainly help on the hills, but can't surmount anything other than a mild slope on its own. You will need to pedal. Finger tip throttle only. They also have a 350w kit with a variable thumb throttle. This size motor is more agressive when it comes to hills. The hub is bigger, however, and gives the donor bike more of an "ebike" look. I purchased my 250w kit with two 20 mile lithium batteries from them several years ago, and still love using it. It is my favorite bike to ride anywhere and everywhere, and no one has ever been able to discern that it is anything other than a simple vintage hybrid bike. The motor is so small that it just doesn't stand out.
They are a very reputable company with excellent customer service, and excellent products. US based, west coast.
https://www.electric-bike-kit.com/hill-topper.aspx
Quoted: 340 Post(s)
Liked 275 Times
I would rather have a 500W rear hub, but this might be enough with a 350W front. While I have never seen this kit in person, what I like about it is the prospect of an easy installation. The electric controller is inside the battery so Installing the battery cradle on the water bottle mounts is all you have to do. The 62 mile range is probably attainable at 12 mph. (I've done 67 miles on a similar sized battery and similar size motor.
Its main failing is no pedal assist, but one can ride on manual pedals and feather the throttle for help on hills. And I dunno how they are on customer service.
The other issue is that every bike conversion is different. Don't know if your front forks are conducive for a front motor.
https://dillengerelectricbikes.com/e...dillenger.html
