Whats more aero
Quoted: 5 Post(s)
Whats more aero
Which would you all think would be more aero... a 27mm rim with 20/24 spokes or a 24mm rim with 16/20 spokes. Or would any difference be negligible
thanks
thanks
Former Hoarder
The aero advantage of wheels is quite small, really. Much more important are: position, time trial bars, helmet, skin suit, cables... once you've fixed all those, you might look into wheels.
That frontal area difference (couple mm) might be about the same difference between wearing a tighter fit shirt and a loose fit one. Probably not enough to notice unless you are riding well over 50 to 75 miles at a time.
Cookies!
Bikes: Red Huffy, CAAD10 Rival
From everything I've read about the amount of watts that these wheels save, for half the price a set of aerobars and a TT helmet will save MUCH more energy.
I assume most people purchase these wheels either for 1) smooth/quality ride 2) better durability than cheap wheels 3) looks 4) already own everything else aero and trying to eke out the last bit of performance.
Of course there's a difference and you may or may not notice it. The important thing is does the wheel do the intended job? Every wheel has it's pros and cons. Figure out your goal and get the wheel best suited for it. There's threads all over the place discussing it. GL
Bikes: S-Works Roubaix SL2^H4, Secteur Sport, TriCross, Kaffenback, Lurcher 29er
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
I don't think you'll find any speed differences between the two wheels. But one big advantage of the 27mm rim is better handling
Recusant Iconoclast
