Decided to go clip less.
Bikes: Specialized Roubaix
Quoted: 13 Post(s)
After much thought, I've decided to go clip less. I'm thinking about going with Shimano 105 pedals and I guess some Shimano shoes.
If I choose to use the Look KEO pedals, can I still use the Shimano shoes?
From what I can understand, it looks like these cleats just screw on to any shoe rite?
My budget is kinda tight rite now, the Shimano 105 pedals and the Shimano shoes I was looking at are in my price range. Am I buying cheap stuff? Should I just wait, save a little more money and buy better equipment?
The shoes by Shimano that I'm looking at are the R077 road shoes for $74.99
And the 105 pedals are $54.99
Please share any info you want about clip less are what I've talked about. I'm still very new to road bikes and I've never used clip less shoes and pedals. I'm all ears guys!
Keep on climbing
There are two "standard" styles of holes for mounting cleats to shoes. Shimano SPD-SL and Look pedals use the same three-hole mounting pattern. If your shoes have three-hole mounting patterns, they'll work.
Shimano SPD (the mountain-bike kind), and various other cleat systems, use two-hole mountain patterns. If your shoes have two-hole mounting patterns, they'll work.
Mountain-bike specific shoes or shoes with "recessed" cleats only support the two-hole mounting pattern. Most smooth-soled shoes have both the two and three hole mounting patterns, meaning that they'll work with anything.
The best shoes are the ones that fit your feet.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
yup. compatible.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
Quoted: 13 Post(s)
Thanks for the info guys.
kevinF, you said the best shoes are the ones that fit your feet. I believe that to be accurate, the pedals and shoes I mentioned earlier is stuff that I'm looking at on the Internet. That's what's bad about looking at them on the net, you can't try them on. I guess what needs to happen is I need to head to the LBS and try on shoes. The LBS's are a good drive from my home, so I try to order things if I can. But in this case ill have to drive down there.
Should Be More Popular
Quoted: 22610 Post(s)
Liked 8,934 Times
I do strongly encourage you to go to the LBS and get shoes in person. They may look great on the web but if they are not a good fit, you will hate yourself for getting them.
Stick with "road type" shoes (3 bolt cleat pattern) and you can get shimano spd-sl OR look keo pedals. Both systems are fine. Pick what suits your budget. Pedals you may wish to by online if you save a chunk of change.
Too Fat for This Sport
Bikes: 2011 Cannondale Supersix
If you like those shoes go for it. Shoes and Saddle make a humongous difference, if you can afford to find a lighter-stiffer more comfortable shoe I would do it. Please consider that you will be using this shoe for several years, however I began on a very small budget early on and just recently began serious upgrades on my new bike. That being said, I think you will find as you mature as a cyclist and become more knowledgeable you will make informed decisions about what you can do with/without when considering costly items. My verdict: Do it! Important thing is GET ON THE BIKE.
Quoted: 18883 Post(s)
Liked 10,646 Times
I started with cheap shoes. They were fine for a while, but certain parts of my shoes got very sore at the end of long, hilly rides. Eventually I stopped using them and have much better shoes.
On the other hand, I wished I'd gone clipless years ago.
Quoted: 13 Post(s)
Guys I forgot to mention. I live out in a rural area, the road I live on is gravel, but I only have to go roughly 130 yards until I'm back on the black top. I push the the bike until I get on the black top, then ride from there. Will these shoes/cleats hold up to me walking on a gravel road? Or, will I have to walk in, lets say, some crocs until I get to the road and then put my shoes on?
Keep on climbing
Bikes: Specialized Allez Sport
Quoted: 12 Post(s)
105 pedals is great. R077, if it fits, is a fine shoes. You can ride on gravel too nnless, the gravel is really soft making it impossible to stay balance. The shoes can handle the walking but your feet might protest a little.
hmm..
absent
Powered by pie
Quoted: 13 Post(s)
Get Kool Kovers.
Quoted: 13 Post(s)
Quoted: 13 Post(s)
No doubt! The shop I'm going to go to is the same place I bought my Roubaix. Super friendly guy and I will buy from them. It's just a drive to get there. But in this case it's definitely worth it so I can get a good fitting shoe.
Quoted: 13 Post(s)
Thanks for commenting fella's! I tell you, I've learned a lot of good info from this forum, and most of you give great advice. I just jumped rite into cycling and without this forum I'd be up s*** creek lol.
105 pedals are great...not much more expensive than the base SPD-SL pedals, but my understanding is that they are light years ahead in quality/reliability. Also, as someone mentioned above, get some Kool Kovers or Cleatskins...they're pretty much indispensible IMHO.
I have been using shimano's system for a while and have their 105, Ultegra and Dura-Ace pedals with SH R-131 shoes. Also Mavic Zyllium shoes (awesome). Have 9 bikes so 105 is on my least nicest bike on up to dura-ace which is on a new Rock Racing (DeRosa) sram force outfitted machine.
105 pedals are very high quality and shoes are nice.
Good Luck to you
Good Luck to you
