What is the diameter of the handle bar on a mid 1980s Trek 520?
Quoted: 5793 Post(s)
Liked 2,585 Times
Assuming you have original aluminum drop bars, then odds are it's 26.0mm which was the standard for road bars until fairly recently.
However, there's a small possibility that it 25.4mm (1").
The difference is big enough that you can make a gauge by carefully cutting a 1" slot into a piece of card stock, then seeing if it will slip over the fat section near the stem.
FB
Chain-L site
FB
Chain-L site
25.4 is most likely. 26.0 is common on European bikes esp. Italian bikes.
https://www.sheldonbrown.com/cribsheet-handlebars.html
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
The clamp, as discussed above, is either 25.4 or 26.0.
The handlebar itself is probably 23.8 mm assuming it's an aluminum drop bar. If it's a steel bar, the diameter may be 22.2 mm.
www.rhmsaddles.com.
www.rhmsaddles.com.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
Liked 2,585 Times
If it's 0.3mm thick. I believe that's more than the bypical can, so no.
OTOH - I once bailed out a friend with a paper shim made by winding paper coated with glue around the bar to reach the right diameter. I assembled and clamped it wet for good adhesion between the layers, and my friend rode it for much longer than we had originally planned, no problems.
FWIW, I'm a big fan of paper laminate shims and have enjoyed great success using them in all sorts of applications. I greatly prefer them to reliance on beer cans.
FB
Chain-L site
FB
Chain-L site
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
My dad as a hobby makes recurve bows out of laminate pre-paper. (Only one or two have assploded in people's hands)
