27" gravel tires choice
Old 09-11-23, 01:03 PM
Johnmwny
Quoted: 5 Post(s)
Hey all I'm converting an old steel tourer into a bit of a more modern gravel rider. My choices for tires seem pretty slim but it looks like Panaracer Pasela ProTite 27"(aw278-lx-18pt2) and Kenda K161 KrossCyclo tire (05742002) seem like the best options. love to hear opinions on these and or other choices.
Johnmwny is offline
Old 09-11-23, 02:44 PM
HTupolev
Quoted: 1979 Post(s)
Liked 1,298 Times in 630 Posts
If you're going to be dealing with mud or wet foliage or other stuff where some knobs are going to make a big difference, the K161 isn't a bad choice. For gravel which is mostly dry aggregate, and especially if you want it to retain good road attitude, a road tire like a Pasela will probably be overall better.
The big limiting factor is width. 27" is historically a road wheel, so wide option for handling chunky stuff just don't really exist. Also, obviously nothing is made for tubeless setup, if you want to go in that direction.
Depending on how major of a rebuild this is, one possible option would be to switch to 700c. Besides opening up wheel and tire options, it also sometimes buys a bit of extra tire clearance. But you'd need to be able to lower your brake pads by 4mm.
HTupolev is offline
Old 09-11-23, 02:48 PM
Johnmwny
Quoted: 5 Post(s)
I considered switch rims and might but at this point the bike is a play ground for learning other techniques for modification and I’d hate to invest a big chunk of money and then much up the frame or something. I have A set of road tires right now that are okay but won’t survive long so I’m going to hit up some of the rougher trails I’d like to ride and see how poorly they handle and go from there.
Johnmwny is offline
Old 09-12-23, 01:30 PM
Johnmwny
Quoted: 5 Post(s)
Originally Posted by Craptacular8
There's really no mucking up the frame switching to 700c wheels/tires. Tektro makes "long reach" road brakes, which is a simple and cheap swap, and allows these older road bikes to run modern wheels.
I built up an early 80's road bike that was originally on 27" wheels. The wheels were crap. I ended up only re-using the frame/fork, and headset. Switching to 700c allowed that frame to run 700x35 tires, which was pretty darn nice. I went with 100 quick release in the front, which was the original hub width for that bike. The rear was likely 126, but it took a 130 without needing to be cold set.
im not worried about the wheels messing up the frame haha. I am not going to invest into rims when I plan on modifying the frame and might have useless rims at some point. Im sticking with 27” rims I made it clear.
Johnmwny is offline
Old 09-17-23, 06:32 PM
bwilli88
Not lost wanderer.
bwilli88's Avatar
Quoted: 886 Post(s)
Liked 1,000 Times in 526 Posts
Sand Canyon tires by Swift, made by Panaracer. 27x1 3/8, these are my favorite 27" tire for gravel.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
bwilli88 is offline
