HELP (about the KMC 710SL)
Old 06-11-12, 06:22 PM
jammincakes
Okay, my chain is not "breaking" right now. The pin is not moving, and the plates are getting bent.
Please help quickly! (I've broken chains before with no problems. I use a CT-5, and the chain can't go through the second "slot".)
jammincakes is offline
Old 06-11-12, 06:25 PM
Leukybear
THE STUFFED
Leukybear's Avatar
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times in 17 Posts
Use the second slot, I've always found the 710SL is always a tight fit in a park chain tool especially if it is rather new and not broken in. A light tap or two with a rubber mallet/ hammer usually does the job for me to get it in the second slot.
¿pɐǝɹ oʇ sᴉ sᴉɥʇ ƃuᴉʎouuɐ ʍoɥ ǝǝs
Originally Posted by veganbikes
Pound sign: Kilo TT
Leukybear is offline
Old 06-11-12, 06:28 PM
jammincakes
will try right now.
Nagrom_
Fixie Infamous
Nagrom_'s Avatar
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
Liked 4 Times in 4 Posts
If it's not lined up just right, you bend links.
Nagrom_ is offline
Old 06-11-12, 06:29 PM
Adrian_
Adrian_'s Avatar
Dont rush things. I ruined a brand new 710SL and a Park CT-3 deluxe chain tool because I rushed/wasn't paying attention.
Adrian_ is offline
Old 06-11-12, 06:31 PM
jammincakes
the pin is still not going through.
EDIT: I'd like to get this done really soon... I have somewhere to go in under 30 minutes.
Old 06-11-12, 06:34 PM
trrubicon06
Liked 5 Times in 4 Posts
I broke a cheap chain breaker trying to remove some links from my 710-SL. I actually had to use my Crank Brothers multi-tool that I carry on my MTB to break it. I think the CT-7 is made for bigger chains...been thinking about getting one.
trrubicon06 is offline
Old 06-11-12, 06:40 PM
jammincakes
Sorry, I don't really have time for that right now. My LBS doesn't have it either.
Oh, and, it's not getting better. Smacking the chain in and out of the tool doesn't seem great.
Old 06-11-12, 06:56 PM
BigglyPuff
CT-5 is intended for derailleur chains. Dunno if that makes a difference.
I use the CT-3 on mine and I have to work at it a little bit and use the different slots.
BigglyPuff is offline
Old 06-11-12, 07:07 PM
jammincakes
It does, as geared chains are 3/32" wide while the 710sl is 1/8" wide.
Old 06-11-12, 07:09 PM
8bits
Quoted: 7 Post(s)
my x-tools chain breaker does this with ease, maybe it's the tool?
the only trick I have to use to get it done is put a cloth on the grip and twist with more torque than with other chains. the other thing is that I try to align the pin perfectly and apllying small pressure to keep it in place before using the cloth.
8bits is offline
Old 06-11-12, 07:20 PM
Scrodzilla
Your cog is slipping.
Scrodzilla's Avatar
Quoted: 640 Post(s)
Liked 100 Times in 58 Posts
I've said it a million times - the little Rivoli chain tool is much better at dealing with a K710 than any Park chain tool.
Scrodzilla is offline
Old 06-11-12, 08:03 PM
DexTan
Bikes: Kilo Team
i also used my Crank Bros multi tool to break the 710SL, i was expecting it to be hard to do as i've read here, took it easy and the pin was off in no time.
DexTan is offline
Old 06-11-12, 08:16 PM
Bat56
Bat56's Avatar
Quoted: 47 Post(s)
Liked 4 Times in 3 Posts
I've said it a million times - don't start a bike repair if you need to ride that bike within the next three hours. Don't put air in the tires, don't wipe off the down tube.
The time it takes to finish a repair is inversely correlated to the number of hours between the start of the repair and the time the bike is next required.
Bat56 is offline
Old 06-11-12, 08:22 PM
McChinken
Thugnasty
McChinken's Avatar
I used to have problems using my CT3, I kept trying and one day it just worked. It's worked ever since.
#TheChainToolThatCould
McChinken is offline
Old 06-11-12, 08:32 PM
CharneK
SpecialK
CharneK's Avatar
Bikes: 2007 SE Lager
Best chain tool I've used to date. Accepts Park Tools pins too. Not that this helps you much right away...
CharneK is offline
Old 06-12-12, 12:21 AM
jammincakes
Thanks, guys. After muscling it really hard (with some extra torque), I got the pin(s) out. No damage to the chain. I have it all synced up, and ready to go. Runs great! Now I should get a EAI cog...
Old 06-12-12, 12:27 AM
tomatsu
Did you grease the threads of the tool? I know it sounds simple, but my breaker works a lot better/smoother with a bit of grease.
tomatsu is offline
Old 06-12-12, 06:37 AM
broakland
Señor Member
broakland's Avatar
Bikes: Fixie
The first 20 minutes of the thread look really intense:
"Please help quickly!....I'd like to get this done really soon... I have somewhere to go in under 30 minutes..... I don't really have time for that right now."
broakland is offline
Old 06-12-12, 07:14 AM
yummygooey
i smell bacon
yummygooey's Avatar
Bikes: Geekhouse Deerfield, GT Edge Ti, Spooky Skeletor, TET Track, Ritchey P-650b, Bridgestone MB-3
The CT5 sucks.
yummygooey is offline
MrRider
Bicycle Mechanics
10
06-16-18 10:18 AM
dj1891
Bicycle Mechanics
12
08-23-14 05:56 PM
hamster
Bicycle Mechanics
16
10-02-13 04:07 AM
lightstays
Bicycle Mechanics
3
12-16-12 12:30 PM
bud16415
Bicycle Mechanics
4
08-23-11 11:57 AM
