etap front derailleur mount
etap front derailleur mount is flat. used to be rounded. are these new model? or do i need some kind of shim? thanks
https://
20190115_201044 by jerbax18, on Flickr
https://
Anyone chiming in? have the same issue, derailleur twists while shifting, OP what did you manage to do? All the other ones ive seen are rounded along with the stock images.
i installed it without the shim. shims doesnt fit on a 2016 cerveo s5. corners on the bevelled edge was enough to bite the derailleur hanger. used 4nm on bolt
If I’m understanding this correctly, that seems to me like it wouldn’t be a good idea and leaves the FD somewhat unsupported and vulnerable to twisting. You might want to talk to SRAM and Cervelo tech support about that.
