Two observations since using a power meter
Quoted: 131 Post(s)
I have my Wahoo Elemnt Bolt setup for 7 Power zones. We have a climb near my home that is about three miles at 6%. I keep my power at zone 5 instead of 6 or 7 and blow up before the hill is over. I've noticed I climb the hill faster, feel better, and don't have to resort to my lowest granny gear.
Quoted: 942 Post(s)
Liked 527 Times
Zone 5 is right above threshold power on the 7 zone power. I'm assuming he has an Wahoo Elemnt, because I also use the 7 zone option.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
You said a 75 mile race, but okay. It was a ride.
Regardless, races/rides typically start out fast. That's what makes group rides and races what they are, the surges. You stay with the surges and wait for the calmer bits. Siting up just because you were scared of a number potentially robbed you of a much faster ride with possibly similar efforts.
Bikes: bikes
Liked 1,429 Times
Yep. Biggest "aha" moment for was how much time I wasted on solo training rides. I'd do a 3 hour training ride and coast/soft pedal for 45-60 minutes of it. Madness.
Quoted: 131 Post(s)
I think of zone 5 as 106-120% of FTP (that is how training peaks has it set), and while I can hold the low end of zone 5 for over 10min, I would struggle do even that for 20min. I can only hold the middle of zone 5 for 5ish minutes.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Wow! I'm impressed. That's a 1647' climb, so in under 20' you'd be climbing over 5000''/hour. Most of the club riders I ride with climb at about 1/2 that rate.
Results matter
Results matter
Quoted: 131 Post(s)
I did a 3mile climb today at an average grade of 5.5%. It took 17min. That is pretty standard for me. I've climbed it faster and slower. Fastest time was 15min, slow times at around 20min.
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 136 Times
Where are you getting 1647'? 3miles at 6% is only 950'. At 20 minutes, that's a 870 VAM, more or less, which is not super fast (no offense!).
Quoted: 131 Post(s)
Yeah, you are absolutely right. My 3mi 6% climb today came in at just under 1000' (according to GPS). Average pace for me is 9-10mph on a good day. Not bad, but I'm just an average cat3 lady :-)
Quoted: 647 Post(s)
Liked 136 Times
Bikes: bikes
Liked 1,429 Times
It's going to vary pretty significantly, but 15 minutes at 105% shouldn't be out of this world for the more aerobically trained and predisposed.
VO2 isn't necessarily 120%, either. That also varies. Mine is closer to 130% in peak shape.
105% is most certainly not sweetspot, however, as alluded to above. Doing 2x20 at 105% would normally suggests FTP is low. And sweetspot is traditionally 88-95% FTP in any case.
Quoted: 647 Post(s)
Liked 136 Times
Yeah, zone 5 is 105-120%. That's right over threshold.
Liked 1,938 Times
[QUOTE=cthenn;20890611]I'm sorry, I messed up the calculation. 950' is correct for the 3 miles, 868 VAM. A very good effort.
On 8' Z5 repeats, I get ~950, but 8' is my absolute limit for that. On all-day climbing rides, I get about 600.
My apologies for causing a tiny ruckus. I was just so amazed that we had a La Course contender on here! No slight intended.
Results matter
Results matter
Quoted: 741 Post(s)
Liked 412 Times
Yeah, I was going to say, SS is not above TH, it's just below TH. The main problem is people using an incorrect FTP. If your FTP is really higher or lower than you think it is, all these zones are incorrect. You may think you're doing a Z5 effort for 20 minutes or whatever, when really if your FTP is higher, then it's not Z5. You really have to do fairly regular FTP tests to get a truer sense of the actual number.
Quoted: 20810 Post(s)
Liked 9,456 Times
Quoted: 741 Post(s)
Liked 412 Times
It changes a fair amount between January and March, and then June. I will take another before September to see how much I will lose by January 😂 I do the two 8 minute version. They aren’t as taxing mentally. Swift has a new ladder type test I want to try.
