Go Back  Bike Forums > Bike Forums > Indoor & Stationary Cycling Forum
Which heart monitor with Zwift?
Indoor & Stationary Cycling Forum From spin to Zwift to Peloton, this forum is dedicated to any and all indoor training on stationary bikes
Old 01-12-23, 08:34 AM
WT21
Quoted: 119 Post(s)
Liked 23 Times in 18 Posts
Using a Zwift kickr core connected to a Mac. I've tried using my Apple Watch as heart monitor, but can't seem to get it to work. I'd like to race a bit more, and need a heart monitor for it to count.
Anyone have recommendations they find that are easy to use and not fussy?
WT21 is offline
Old 01-12-23, 08:39 AM
Polaris OBark
ignominious poltroon
Polaris OBark's Avatar
Quoted: 2244 Post(s)
Liked 3,445 Times in 1,804 Posts
Apple Watch, as you found, doesn't broadcast heart rate (like a Garmin watch or wrist or strap monitor does).
There is a phone app that allows you to create a bridge. I don't know anything about it, but you could probably find it on the app store.
Polaris OBark is offline
Likes For Polaris OBark:
Old 01-12-23, 10:37 AM
La Tortue
La Tortue's Avatar
Quoted: 37 Post(s)
Liked 34 Times in 27 Posts
The Apple watch does not work. Traditional chest straps like the Bontrager or TACX work well. You are looking for one that uses both Bluetooth and ANT+. I have both the Bontrager and TACX which have given me years of trouble-free use. My wife swapped to a rhythm wristband linked here. Some say they aren't accurate but this one seems to work fine after more than a year of use. It is more comfortable and a little more convenient.. If my other two chest straps HR will break I will replace them with a wrist strap.
La Tortue is offline
Likes For La Tortue:
Old 01-12-23, 10:49 AM
BTinNYC
Bikes: Bicycles? Yup.
Quoted: 482 Post(s)
Liked 1,593 Times in 739 Posts
Wife uses a $40 Fitbit, seems to work as well as my Polar HRM
BTinNYC is offline
Likes For BTinNYC:
himespau
himespau's Avatar
Quoted: 4236 Post(s)
Liked 2,949 Times in 1,808 Posts
I like the Garmin Dual. There are a number of generic knock offs that tend to work well as well.
himespau is online now
Likes For himespau:
Old 01-12-23, 11:24 AM
WT21
Quoted: 119 Post(s)
I've tried HR chest strap probably 10 years ago and hated it. This wrist band seems much easier to put on and likely more comfortable. I might look into that. Thanks!
WT21 is offline
Old 01-12-23, 11:32 AM
Black wallnut
Black wallnut's Avatar
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 179 Post(s)
Liked 169 Times in 84 Posts
If a wrist one doesn't work out for you. I have used chest straps from both Garmin and Wahoo. I have found the Wahoo to be better. The replacement straps seem to last longer and hold shape better plus cost a bit less. Wahoo's C/S has been superior to Garmin as well.
Sir Mark, Knight of Sufferlandria
Black wallnut is offline
Old 01-12-23, 11:54 AM
msu2001la
msu2001la's Avatar
Quoted: 1461 Post(s)
Liked 1,486 Times in 870 Posts
I use a Garmin chest strap HRM for Zwift - it connects via ANT+ so I also have an ANT+ dongle for my Mac. (I also connect my Wahoo trainer via ANT+ as I've found it to work better than Bluetooth).
I use this same HRM for outdoor riding - connected to my Wahoo head unit.
My Garmin strap is starting to show a lot of wear (I've had this one for a few years and it's been through the washing machine many times). I'll probably look to Wahoo for a replacement - I'm intrigued by these wrist/arm straps. My Fitbit isn't very accurate but I think it's because I keep it too loose on my wrist. Something with a fabric strap probably works better than a watch in this regard.
msu2001la is offline
Old 01-12-23, 11:58 AM
himespau
himespau's Avatar
Honestly, I have 3 of the fabric straps that I rotate in between. The straps tend to fail a lot more frequently than the sensor units, so I figure rotating between them makes it last longer.
Old 01-13-23, 08:11 AM
bblair
Bikes: Lynskey R230, Trek 5200, 1975 Raleigh Pro, 1973 Falcon ,Trek T50 Tandem and a 1968 Paramount in progress.
Quoted: 380 Post(s)
Liked 395 Times in 234 Posts
Wahoo TickR chest strap. Way more predictable than my old Garmin.
I did have a problem with the first one after about 6 months and they replaced it, no questions asked. Pairs in seconds with Zwift Ant or BT and my Wahoo head unit. Would buy again.
bblair is offline
Likes For bblair:
Old 01-13-23, 09:59 AM
dmanthree
dmanthree's Avatar
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times in 191 Posts
I use a Wahoo Tickr and it works just fine. No issues at all using it for a couple of years.
dmanthree is offline
Old 01-16-23, 10:53 AM
PeteHski
PeteHski's Avatar
Quoted: 4420 Post(s)
Liked 4,873 Times in 3,017 Posts
If you don't like chest straps I can definitely recommend the Polar Verity Sense wrist/armband HRM. I've been using the older version (OH1) for 3 years and it hasn't missed a beat (see what I did there?)
DC Rainmaker has some good reviews on HRMs, above score very highly.
PeteHski is offline
Old 01-18-23, 06:55 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4739 Post(s)
Liked 1,533 Times in 1,004 Posts
I've been using the original Scosche Rhythm which is worn on the forearm -- has been pretty reliable and convenient. Just hang it up on the handlebar when done with a ride, strap it on when starting a ride. Easy to rinse off under the tap, etc.
Sy Reene is offline
Old 01-18-23, 07:57 AM
Kai Winters
Quoted: 242 Post(s)
Liked 456 Times in 267 Posts
I have three...Wahoo Tickr, Garmin and Polar H9...they all work well with Zwift but I find the Polar to be more steady while I've had dropout problems with the other two...the problems are sporadic otherwise they work fine.
Kai Winters is offline
Old 01-18-23, 07:46 PM
808HIcycler
Bikes: 2020 Scott addict RC 10, 2024 Polygon Siskiu D7
Quoted: 8 Post(s)
Liked 56 Times in 26 Posts
I got a polar H10 when I got my tacx last winter. I thought battery life was suspect, but that appears more of operator error when it would take a couple minutes to connect, not a dead battery after a month.
808HIcycler is offline
Old 01-19-23, 01:28 PM
WT21
Quoted: 119 Post(s)
To close the loop, I got the one that La Tortue linked to here. Three races so far, and works like a charm. Longevity - not sure yet. Easy to use and sending data that corresponds to what my watch is recording meaning it's either accurate or they are both off. Either way I've been benchmarking to my AW for 3 years, so it's good enough for me
WT21 is offline
Old 01-26-23, 07:26 AM
rm -rf
don't try this at home.
rm -rf's Avatar
Quoted: 974 Post(s)
Liked 512 Times in 352 Posts
My Tickr quit working after about 3 years -- it started getting intermittent, then finally stopped completely.
I just started using a Polar H10, and I like the strap on it. Gripper dots to keep it from slipping down, and a wide sensor area.
rm -rf is offline
Old 01-27-23, 05:16 PM
kcjc
Quoted: 90 Post(s)
Liked 47 Times in 34 Posts
I had a Polar (lasted just over 12 months, didn't keep track of duration of use), CooSpo (just under 2 years & ~600 hours), and now using a Magene H303 (9 mos old and ~220 hours). I go through the straps approximately one a year. They all work about the same and didn't seem to justify spending 3x the price for named stuff. I still have my CycleOps hard strap that I use mainly outdoors. That was around ~$100 back in 2020. It acts up indoors but not outside, go figure.
kcjc is offline
