Which rental bike should I choose?
Going to Maui basically to ride up Haleakala (35 miles, 10K ft and then back). Not bringing my bike since it is too much of a hassle and my only bike is a bit beat. There are a few options, some are limited by the store hours. Only need the rental of a day and hard to come back by a certain time. Only know what is listed on the site, but will ask more details before renting.
A few options:
My bike is a Ridley Fenix. Entry level carbon, carbon, relaxed geometry. Do not need to be aero with such a climb!
A few options:
- Scott Addict 20 Disc - $65/day, $55 a day for two days, $50 for three - Best option if I wanted to go for three days.
- BMC RoadMachine One AXS - $89/day. - Best option for a single 24 hour period.
- Cannondale - $50/day - undetermined but the site lists carbon, Ultegra components and compact gearing (50/34 front, 11/32 rear). Reverse image search says 2013 CAAD10, but I think the image is old
- Tarmac Disc SL6 Expert - $100
- Roubaix Sport - $60/ day
velo-dilettante
Quoted: 1628 Post(s)
Liked 3,114 Times
broski, you're going to want the model/rental with the best compact gearing. you've got tons of experience riding looong, 20+ mile climbs
but above 8,000 feet, it's going to be miles of slow scenic altitude suck. can always shift up if you're feeling it. you can only shift down so far.
hardest climb in the world-right? what's another $60-$120 to ensure you're set up as best as you can be to realize a dream?
have fun! that's gonna be a long-*ss descent...
are you bringing your own saddle and pedals?
Likes For diphthong:
Bikes: Trek Domane 4.3
Quoted: 193 Post(s)
Liked 50 Times
I haven't done this ride (would like to), but isn't the rec to get an early start so that you're avoiding the daytime heat during the stretch before you hit the real climb? In other words, you probably need two day rental regardless - day before and day of. If it's 24-hour clock presumably mid-afternoon pickup, early morning start, and you're back by the following mid-afternoon.
Quoted: 1461 Post(s)
Liked 1,486 Times
BMC Roadmachine One with SRAM AXS is a ridiculously nice bike. The SRAM AXS gearing would give you a very low 1:1 gear option (or lower, depending on which setup?), plus it looks like it's the only bike with electronic shifting of the group.
Seems like a no-brainer to me.
Quoted: 4260 Post(s)
Liked 1,364 Times
A few options:
They are all decent bikes (based on just that, it won't matter which you choose).
You probably should prefer having lower gears. And info is missing from most of the options.
Assuming that the others likely have typical gearing (28 in the back), the Cannondale is the best choice.
Not sure if I will do the descent. Depends if the lady friend is willing to meet me and drive down. I want to do it.
Probably yes on pedals if required. No on saddle. Never been picky, although I once purchased a crappy one from Performance Bike that I returned after 3 rides.
The difference between $89 and $110 (for two days) is small enough to not be part of the decision. Given the cost of being able to do the ride, even an extra $100 is moot.
Quoted: 6196 Post(s)
Liked 4,811 Times
I'd agree that you want the bike that will give you the lowest gearing if you are going to be climbing continuously for miles.
I did my first mountain climb a few months ago. A 14'er. I put a 50/34 crank and 11-32 cassette on my bike that is normally 52/36 and 11-30. I was worried that I wouldn't have the high gearing I'd want for the trip down. However turns out I didn't need to pedal much while going down. I was having to slow up to often just to make the switchbacks.
So if you don't normally ride continuously up long grades, then go for something that will let you spin comfortably up to the top.
And the big question shouldn't be which brand of bike, but what are their gearing. And also what position are they made for, a low aero position or a more relaxed upright position.
And good luck, enjoy the views. Maybe get one of those little O2 things to huff on occasionally if you aren't use to high altitudes.
Liked 1,364 Times
Oh, it might be possible to negotiate the extra day (so you could bring back the 2-day rental early on the third day).
Beyond gearing, some degree of cost, and convenience, these are all decent bikes. None of them are going to be really better for this ride than the other. I doubt that the benefits of electronic shifting would show up. (Maybe, you'd consider picking the lightest one but that won't matter much and it's other information you don't have.)
Quoted: 967 Post(s)
Liked 1,631 Times
When we were living in Galveston my wife and I noted a couple of tourists with heavy Bostonian ascents working on two brand new Walmart bikes in the Walmart parking lot. The guy needed some help adjusting the tension on his brake set and I was glad to help. Their happy story is they wanted to rent bikes for thier 5 days in Galveston and it was cheaper to buy two bikes over the phone at Walmart and have them waiting for them when they arrived. Of course they had the for-site to bring in a suitable tool box for adjustments at pick up. It was smart thinking and now I wonder... How big of a tool box would I need to do this today?
130.00 USD Walmart in Maui... ???
The places that rent per 24 hour cycles are also open later, so I can rent from 4:30pm-4:30pm. Done.
The places that rent per day, all close at 3pm. So I can rent at 8am the day before, but getting back by 3pm on the day of the ride would be tough, therefore needs a third day. 7am start, assuming 7 hour ride, means get back down at 2pm, and that is without the car ride back to the shop, which is not near the climb.
Liked 1,364 Times
Sorry if that part was confusing. Was more interested in the bike and not the rental periods, so I did not elaborate.
It's possible that the places with 3:00PM closings would let you bring the bike in early the following day without needing to pay for the extra day.
Quoted: 2952 Post(s)
Liked 3,106 Times
I've done that climb a couple times, once on a rental and once on my own bike. The rental was a Roubaix from West Maui Cycle with a 50-36 compact double. I want to say 12-28 in the back. My own bike was a standard 53-39 with 12-27. Either way, you don't need super low gearing. Nor do you need electronic shifting as you're going to spend the whole day in a few gears. It's a steady 6% to the top and I don't recall anything where I needed a 1:1. It might be nice to have discs if you do the ride down, especially since it can get wet. Biggest hazard on the way down is the tourists on cruisers who get driven to the park entrance and coast down. If you do ride down, either carry a windvest, gloves, and arm/knee warmers or have someone meet you at the top with them.
Likes For caloso:
Liked 1,486 Times
People getting hung up on the electronic shifting is cracking me up. Of course no one NEEDS electronic shifting, but it's a cool feature and personally I'd enjoy the opportunity to try out SRAM AXS for a few days. Unless I'm missing something, the BMC Roadmachine One is the top-of-the-line version of that bike. The one on BMC's website is like $12,000 and has SRAM Red and Enve carbon wheels. The other bikes are far more standard spec:
- Scott Addict 20 Disc - 105 and alloy wheels
- Cannondale - carbon mystery bike with Ultegra components
- Tarmac Disc SL6 Expert - Ultegra and alloy wheels
- Roubaix Sport - 105 and alloy wheels
I guess the bigger question is how can I rent a bike for multiple days and convince the girlfriend that she has to vacation without me while I do the West Maui Loop?
Liked 1,364 Times
The one for rent in Hawaii has $500 AL wheels. (The Enve wheels are $2500.)
Liked 1,364 Times
https://www.krankmaui.com/product/bm...chine-one-axs/
The gearing is:
CHAINWHEEL SRAM FORCE AXS 46/33T
CASSETTE SRAM FORCE XG-1270, 10-36
Quoted: 193 Post(s)
Liked 50 Times
According to this:
The gearing is:
The gearing is:
Liked 4,811 Times
https://pjammcycling.com/climb/7.Haleakala
Quoted: 4415 Post(s)
Liked 4,868 Times
[/list]According to this:
The gearing is:
The gearing is:
The BMC branding is a bit confusing. They have both a Roadmachine 01 ONE and Roadmachine ONE. Is 01 ONE redundant? Nope, different bike. The 01 level is the top of the line.
Best link I can find is https://arcane-brook-43772.herokuapp...hine%20ONE#top
I would definitely be going for the BMC if it was truly the 01 model. At this point, electronic shifting is just added weight.
Looked up the gear ratios, and it looks like I actually would spin out more on my current 50f/11r over the 46f/10r
Liked 1,364 Times
The "BMC ROADMACHINE ONE AXS" (the one for rent) appears to be a 2021 model (the rental site has a link to the specifications).
https://www.bike24.com/p2386349.html
Presumably, the BMC website is showing 2022 models.
The base model name is "Roadmachine 01". Then, there are sub models ("one", "two", "three", "four", "five").
https://www.bmc-switzerland.com/us_e...admachine.html
The 2021 "BMC ROADMACHINE ONE AXS" is (was) a $5300 bike.
https://99spokes.com/bikes/bmc/2021/roadmachine-one
Renting a $12,000 bike (the 2022 "BMC 01 One") doesn't make a whole lot of sense (not sure why people's eyebrows didn't raise with that price).
Different years (probably).
