Storing bikes
Storing bikes
Old 02-01-10, 11:54 PM
michael k
michael k's Avatar
Quoted: 43 Post(s)
Storing bikes
I'm running out of room,just picked up bike #27 today and... running out of room.Currently there's 15 hanging from the ceiling with both wheels using hooks.Nice and high so there out of sight when the garage door is open. Except There is the one that needs to be relocated.Its been in the same spot for 35 yrs and today I hit my head on it half dozen times.(am I getting taller?)If there hung from one wheel will it harm the wheels?
Did I mention I'm running out of romm???
michael k is offline
Old 02-01-10, 11:57 PM
frpax
Steel is real, baby!
frpax's Avatar
Bikes: 1984 Pinarello, 1986 Bianchi Portofino, 1988 Bianchi Trofeo, 1989 Specialized Allez, 1989 Specialized Hard Rock, 2001 Litespeed Tuscany
Liked 7 Times in 7 Posts
Sounds like it's time to build a nice big shed.
frpax is offline
Old 02-02-10, 12:28 AM
Ablaut
Latvietis
Ablaut's Avatar
Bikes: '86 Serotta Nova, '77 Schwinn SLT 12.2, '73 Fuji SSR
With lots of pics documenting the process and result.
Ablaut is offline
Old 02-02-10, 12:33 AM
Exit.
No lugs? No hugs.
Exit.'s Avatar
Bikes: '85 Miyata 310, '06 GT Performer
The fact that you have bikes that haven't moved in 35 years may be an indication that you have more bikes than you need.
Exit. is offline
Old 02-02-10, 02:57 AM
WNG
Spin Forest! Spin!
WNG's Avatar
Bikes: I used to have many. And I Will again.
Quoted: 7 Post(s)
Liked 11 Times in 10 Posts
Attic space? Move the ones you don't ride up there.
WNG is offline
Old 02-02-10, 03:24 AM
prettyshady
12345
I keep 85% of my bikes in the attic, but there is a hatch on the wall. Its not fun getting nice bikes up and down, and anything over 56cm's get difficault. Its worth the hassle.
prettyshady is offline
Old 02-02-10, 04:07 AM
Panthers007
Great State of Varmint
Panthers007's Avatar
Liked 15 Times in 15 Posts
"Need" here doesn't work. It's a compulsive-action from their genetics and upbringing. So we are back to square-one: How to best store the collection. I suggest in the air. Let the air our on the tires. And come back later!
Panthers007 is offline
Old 02-02-10, 06:04 AM
20grit
Curmudgeon in Training
20grit's Avatar
Bikes: 1974 Gazelle Champion Mondial, 2010 Cannondale Trail SL, 1988 Peugeot Nice, 1992ish Stumpjumper Comp,1990's Schwinn Moab
Quoted: 19 Post(s)
Liked 9 Times in 8 Posts
compared to the pressure applied to the wheels while riding, the weight of the bike during hanging shouldn't do a whole lot of damage. if you're worried, rotate the wheels on the hanging point occasionally.
someone else may disagree.
20grit is offline
Old 02-02-10, 08:53 AM
phillyrider
peddling fool
phillyrider's Avatar
Bikes: Mid 50's Frejus, Late 50's Frejus, Early 1960s Frejus Professional, Mid 1960's Frejus Professional, Early 70's Gloria (branded), 76 Blue Pogliaghi
I don't have many bikes - but I now remove wheels and rotate them around various frames.
One nice set of wheels can be used on 3 or more bikes.
If you have nothing special - ditch most of the 27" steel wheels. Rotate a nice set.
If you want to really condense - rotate handle bars. A few handlebars could fit multiple bikes - just clip in the brake levers, use a piece of electric tape to mark height, and drop them in when you want to ride. Wheels and handlebars probably take about 5 minutes to line up - then you're off.
If you do both - you storage usage of space is probably cut down by 2/3rds.
phillyrider is offline
Old 02-02-10, 09:10 AM
due ruote
due ruote's Avatar
Quoted: 904 Post(s)
Liked 527 Times in 320 Posts
One might ask, if you're going 35 years without riding the bike, how much do you really care about the hub bearings?
But back to your question: I always hang my bikes by one wheel. No problems in 30 years.
due ruote is offline
Old 02-02-10, 09:48 AM
SJX426
SJX426's Avatar
Quoted: 1608 Post(s)
Liked 2,216 Times in 1,103 Posts
I don't have that many but do have the same problem. I have too many other hobbies that take up room. My hooks are spaced enough to prevent the pedals from hitting the next bike. I have a shelf under the bikes for storage and must remove the front wheel to clear it. I then hang the wheel on the drive side pedal. After installing the hooks, 10 I think, I discovered that the spacing was such that a MTB bar interfered with a RDB handle bar. To be able to remove any given bike, I was forced to determine the best hanging order. The bikes are different sizes for the family members.
My last solution was to use the mini bungy cords that are about 8" long to rotate the handle bars to the non drive side and hold them in place. Like a 90* left turn. This gave me lots of clearance without the MTB bars hooking into the drops on the RDB. I used string prior to finding the mini bungy's.
My previous house had high ceilings in the garage that allowed hanging above the garage door. I used a long pole with a Y "hook" on the end to get them up there. I needed to hang from both wheels to clear the door. That was a great arrangement and kept my arms in shape!
SJX426 is offline
Old 02-02-10, 10:14 AM
Kobe
Kobe's Avatar
Quoted: 276 Post(s)
Liked 339 Times in 179 Posts
I built a mini shed. The height is only 6' at the tallest and I have 2 wide doors to back the bikes in. The low height makes it alot less intrusive to the neighbors.
Kobe is offline
Old 02-03-10, 08:08 AM
RobbieTunes
Quoted: 378 Post(s)
Liked 1,410 Times in 910 Posts
wear a helmet.
problem solved.
RobbieTunes is offline
Old 02-03-10, 12:21 PM
fahrrad streber
I'd say look into local self-storage places. I don't think you'd need a large unit so it should be <$30/month. Pick 10-20 bikes to go live there and you could even trade them in and out and make an afternoon ride out of going from house to storage unit and back.
fahrrad streber is offline
deepakvrao
Road Cycling
15
03-26-16 09:16 AM
Steepndeep
Road Cycling
31
10-31-13 01:45 PM
gaucho777
Classic & Vintage
63
06-16-12 08:04 PM
simpso57
Road Cycling
37
09-26-11 12:32 PM
storckm
Bicycle Mechanics
11
05-19-11 08:56 PM
