Totally Tubular
#1701
Old Legs
Bikes: '80 Strayvaigin, '84 Ciocc Aelle-Shimano 105, '90 Concorde Astore /Campy Triple ,85 Bridgestone 500/Suntour, 2005 Jamis Quest, 2017 Raleigh Merit 1, Raleigh Carbon Clubman
Quoted: 302 Post(s)
Liked 33 Times
#1702
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
That was my understanding. Tufo is one piece construction. No inner tube. So a plug should work. I saw a video, long ago, which showed a guy using super glue to repair one.
#1703
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,195 Times
Specifically looks as if it works with Tufos. I might go this route on my Tufo Tubular Clinchers
Bob
Bob
#1704
Hello All! I just came across my first bike with tubulars. The bike came with the original tires that are toast.... 30 yrs old.
The wheels are Ambrsio Synthesis from the late 80’s to my understanding the wheels are 22.5 wide.
Since this is my first encounter is it correct that i can fit 25-28 mm wide tires on these wheels?
i want to make sure before I buy the tires.
#1705
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
#1707
Quoted: 4806 Post(s)
Liked 3,929 Times
To elaborate a little on DiabloScott's "Yup": widths make little difference for either rim or tire. Nobody thought twice about running the fat (30c) Del Mondos of 40- years ago on skinny racing rims.
That said, there are some newer tires with different construction that I've heard mount better on certain rims. But if you are running any of the classic tubulars and any rim remotely close to "normal" don't sweat it. Just do a good glue (or tape) job.
Likes For 79pmooney:
#1708
understanding.
#1709
understanding.
#1710
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
Take a look at this: https://www.probikekit.com/bicycle-t.../11211219.html
#1711
Freewheel Medic
Liked 2,195 Times
While kcblair mentions he is running Stan's sealant, it might be worth the time researching to see if this product might work with Stan's and save his Tufo. At $10-15 it might be worth just trying.
Bob
Bob
#1712
Old Legs
Quoted: 302 Post(s)
Liked 33 Times
Yes, I realized this and spotted it in the listing's specifications. I haven't added any sealant to my Tufo's yet and have both Tufo and CaffeLatex on hand.
#1713
Quoted: 2338 Post(s)
Liked 2,823 Times
#1714
Old Legs
Quoted: 302 Post(s)
Liked 33 Times
All this with wheel of the bike and the punctured Tufo on the rim. KB
#1715
Liked 2,823 Times
can't hurt to try for sure. I think 30ml is what is called for a 700c tire.
#1716
Liked 2,823 Times
out of curiosity what are people doing for tire pressures?
I am a big guy (243) and have pretty much always gone to make pressure for the tire tubie or clincher
I am riding Vittoria Corsa Control in 30mm Max on side of the tire is 115 psi. I have been riding front a 110 and back at 115.
My LBS go to guy (brought the Miyata by for him to try) commented that a could go lower so today I tried 90 front and 100 rear. Ride was noticeably smoother and didn't feel slower
#1717
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
I have Veloflex Vlaanderen (27mm) on my Griffon, the bike I've been riding most lately. I weigh 170-175. I've been running 55 front, 75 rear recently. That seems to be working well for me.
#1718
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 345 Post(s)
Liked 175 Times
same tire (but now ProTour), same weight, about the same psi works well for me too. I pump front to 60 psi and rear to 5 bar and pump every 2-3 days.
#1719
Quoted: 1949 Post(s)
Liked 2,010 Times
My Vittoria Corsa in 23mm are usually at 90 and 85 and feel pretty smooth. My Vittoria Rallys in 25mm are harsher at that pressure but I usually ride them a little lower. I got a nasty sidewall cut on my rear Rally yesterday that resulted in a remarkably fast deflation on a descent. I hit the only rock in the road at the worst angle I guess. Vittoria base tape is a bear to get off and I'm dreading this repair.
#1720
Liked 3,929 Times
So even the cheap Rally's have secure base tape. Thanks. Sounds like nothing has changed. The $15 Vittorias of the '70 I trained and club raced on were good, reliable tires and I went through a lot of them. (My 9-10,000 mile years, all on sewups. We never called them tubulars then.)
Ben
#1721
Bikes: many
Liked 1,392 Times
If you only have to inflate every 2-3 days, does that imply the ProTour has a butyl inner tube? I inflate my Vlaanderen before every ride (known to have latex tubes). They lose 5-10psi in a day.
#1722
Quoted: 345 Post(s)
Liked 175 Times
I was sort of suggesting my 60 today might be your 55 tomorrow.
#1723
Quoted: 591 Post(s)
Liked 663 Times
Today riding FMB Paris-Roubaix 25mm at 85 front and rear. I weigh 225 lb. I know experts are recommending lower pressure for the front, but when you brake, your weight shifts forward.
Likes For CV-6:
#1724
Quoted: 823 Post(s)
Liked 1,395 Times
#1725
Bikes: many
Liked 1,392 Times
Jan Heine is someone I think of as a tire pressure expert. In this post about braking, he said nothing about changing the way he approached tire pressures, so I presume he didn't deviate from his usual recommendations.
