Chain derailment more common on ring or cog?
Bikes: 1976 Schwinn Super Le Tour, tricked out with modern components. Shimano Alfine 11 internal gear hub. Dynamo hub. Titanium racks and bottle cages. Mercier Kilo Wide Tire dropbar singlespeed
Quoted: 44 Post(s)
Liked 8 Times
I'm finishing a build with an internal gear hub -- so technically I am posting on the wrong forum. However, since this is a setup with just one ring in front and one cog in back, I think the question is applicable here. When a chain derails on a 1x1 setup, is it more likely to derail on the ring or the cog? I have a bash guard outboard of the ring and a chain-drop preventer inboard, so I am not concerned with chain drop. I chose, however, not to use the dorky looking Shimano IGH cog that comes with a guard on either side of the cog. So I am wondering if I run the risk of chain derailment on the rear cog, or if derailment tends to happen at the ring rather than the cog. I have semi-horizontal rear dropouts and have achieved pretty good chain tension (about 5/8 slack at the loose point and very little slack at the tight point). Chain line is pretty good. I would grudgingly put on the shimano guarded cog in back if I am told that most chain derailment happens at the cog rather than the ring, so I don't have to worry when riding rough bike paths in the middle of nowhere, solo, on tour (C&O Canal/Great Allegheny Passage). What say ye?
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
I have lots of 1 x 1 setups, fixed, singlespeed, even IGH. None of them have any kind of chainguards, and none of them have ever derailed on me either front or rear, and I've got more than 5/8" maximum slack on many of them. As long as you've got reasonable alignment between the front and rear sprockets, there should be no problem.
on fixed: it's most likely to fall off on the inside of your chainring.
on a singlespeed it can fall off anywhere since you can coast.
use 3/32 ring and cog w/ 1/8" if you're worried about chain derailment.
I've never thrown a chain on my SS or FG. I have thrown chains several times on my 3x9 hybrid. Especially when going from 3 > 1 on the Crank... she loves to toss that chain right onto the bottom bracket.
Your cog is slipping.
Stop overthinking it. Instead of asking a bunch of people on the internet, simply ride your bike and see what happens.
Quoted: 138 Post(s)
Liked 17 Times
Funny thing is I was just about to ask pretty much the same question. After having dropped the chain twice in the past 1.5 months, both times it appears to have dropped off the cog first(yesterday it was still wrapped around the chainring when I stopped) I was wandering the same thing. I know you always hear about it when it drops off the chainring and locks up the wheel. I was wandering if my homemade dropout set up was helping me to drop it off the cog or what. Some answers given thus far have been rather intriguing.
Brown Jersey Winner
Quoted: 243 Post(s)
Liked 13 Times
#kilott
for serious tho ive never had a chain come off at the back except on a derailleur bike when i dumped 7 gears and hammered on the pedals
Bikes: MTB & Road
Quoted: 5 Post(s)
Are your chainline(s) out of bounds? I can't imagine how my chain would ever fall off, when proper tensioned. I have an offset in chainline on 1mm that I'll zero out tomorrow, but even that looks perfect and deadsilent to my ears and eyes. Can't see how it should derail with chainline within bounds.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
canis lupus familiaris
Bikes: En plus one
The only times I have dropped a chain on a fixed gear has been due to my own neglect, the chain was way too loose and I was riding on "bumpy" surfaces. This was made worse by having cheap components that weren't very round so chain tension varied as the chain rotated.
