Bengal caliper failure anyone?
Old 06-13-20, 09:51 AM
Pista Largo
Bikes: Bianchi, Trek, Another Trek, Raleigh, Fuji and Santana and another Santana
On inspection, the problem was trivial, and self inflicted
Our Santana team-ti came equipped with the big bengal disk brake. This morning the caliper starts to actuate and then makes a loud click and the cable relaxes instead of squeezing the rotor. Has anyone else experienced this? Can I fix it, or should I just go ahead and order a new caliper? Is this a symptom of a broken pad? The bike has about 30,000 miles if that’s relevant.
Last edited by Pista Largo; 06-13-20 at 04:32 PM. Reason: Original post was uninformed.
Pista Largo is offline
Old 06-13-20, 09:57 PM
OneIsAllYouNeed
Bikes: Chinook travel/gravel/family tandem, Chinook all-road, Motobecane fatbike
Quoted: 232 Post(s)
Liked 34 Times in 25 Posts
Sounds like (1) the cable slipped in the cable anchor bolt or (2) a cable housing ferrule wasn’t seated in a housing stop until you pulled the brake lever. Either way, just loosen the cable anchor bolt, pull the cable snug, and tighten the cable anchor bolt.
OneIsAllYouNeed is offline
Old 06-14-20, 09:12 PM
unikid
Quoted: 47 Post(s)
Liked 25 Times in 23 Posts
Not bad after 30,000 miles
unikid is offline
