#2501
Not sure if this has been posted yet... anybody in a position to rescue this one?
https://richmond.craigslist.org/bik/5590964250.html
#2502
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
Thanks! Not sure how serious I am, but I will using it in a triathlon sprint next weekend. This has been a bucket list item for a couple of years so when the frame popped up I figured I might as well go C/V. I'm not a swimmer so I don't expect to be competitive. But damn I'm going to look good on the bike!
#2503
There are so many things wrong with it..please some save the MV!
#2504
Here's one in Texas. Exactly my size. However not my price, which is currently has to be free or I'm not buying it.
VTG CENTURION Black "Dave Scott" Road Bike
#2505
Quoted: 3241 Post(s)
Liked 2,512 Times
I"ll take a look at the one in Richmond. There is/was also a red and white one in RVA that was even worse.
#2506
this deserves a larger print- "Don't think, Feel..."
#2507
I bought 56 cm Miami Vice frameset off ebay quite a while ago and it has been sitting in my room ever since. I'm finally finding some spare time and starting to build it up with the Shimano 105 groupset that I had laying around. The cassette that I have is in pretty bad shape (see below) and I'm not going to bother with overhauling it. I plan on buying a new Shimano cassette and I was wondering if the 1050 shifter is going to work with a 7- or 8-speed cassette. If I remember correctly, the Miami Vice has a 6-speed cassette, RD, and DT shifter. I'm mostly building it to ride to work and I'm thinking a 7-speed 12-28 should work (that's the setup I have for my current daily anyway) or 12-31 might even be better since I live in a hilly area.
I'm looking at this:
https://www.amazon.com/Shimano-CS-HG...ssette+7+speed
and this:
https://www.amazon.com/Shimano-Speed...ssette+7+speed
I just gotta find out if they would work with the 1050 groupset before I buy one.
There is also an area on the top tube where the clear coat is almost nonexistant. Is there a way to apply a layer of clear coat to protect the paint and also restore the glossiness?
Lastly, I'm also looking for a shorter reach stem to put on this bike, preferably 60 mm. Let me know what you got!
Some pics:
Thanks in advance!
and this:
Some pics:
Thanks in advance!
#2508
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Your 105 derailleurs will actually work very well with, up to, and including a 10 speed system if you are using the correct friction front and index rear down tube shifters. Never tried it with STI's, but in theory at least the rear one should be OK.
A standard 105 series 1050 RD will handle up to a 28 tooth rear cog on an Ironman frame; to use a larger rear cog I'd suggest using one of the many Deore RD's out there, particularly the 600 and 700 series ones that go well cosmetically with 105 pieces.
#2509
That is a freewheel, not a cassette. Good looking Ironman. Is the seatpost stuck or just lowered down into the seat tube for movement?
clearcoat could be something to do but I will let the paint experts chime in for the definitive response.
#2510
Congratulations, WOW nice looking Miami Vice. Definitely worth any investment you put into it. I have a shorter stem that is black, it's yours if you want it. Pm me.
That is a screw on freewheel not a cassette. So if you're gonna use the same wheels you'll need a freewheel removal tool and a screw on freewheel instead of the cassette type you posted from amazon. And a 7 speed will definitely work however you will have to put it in friction mode not SIS on the down tube shifters if the shifters are 6 speed. Keep us posted.
#2511
and this:
and this:
By the way, are you planning to have the chainwheels on the left side of the bike?
#2512
tantum vehi
Liked 992 Times
7 speed freewheels are still very easy to find cheaply. Shimano still makes them in the range you need. If you cruise eBay, 7 speed shifters come up from time to time. Create a search then save it to get updates. I have found old shifters as part of a group or incomplete group, often from people who are just resellers and don't know what they have. They can be pricy given their age. Or you can just go 7s friction.
If you're mostly commuting, you can get a new 6s 14-28 freewheel for cheap. I would spring for a 38t chainring to get a bit lower gearing and you're good to go - nice even spacing in the FW. Think about the last time you really needed that 12t sprocket... Unless you're in beast mode I'm guessing you'll likely spend most of you're time in the 52 and the 16t or 18t sprockets on the flats.
#2513
Thanks for all your amazing responses and offers! I actually posted some photos on here when I first got the frame but never had the spare time to really sit down and build it up.
I'm hoping to keep 105 RD as well so if it won't work with anything above 28 tooth, I'll just stick with 28 as my largest rear cog.
Thanks for the correction. I can never remember the difference between the two. The seatpost is not stuck. In fact, it's the opposite of stuck. It's all greased up so it doesn't have any friction to the seat tube and just slides to the bottom.
Thanks for your offer! I'm hoping to keep the stem, handlebar, and seatpost in silver but I'll definitely hit you up if I change my mind! So you're saying in order to pair the 105 shifter and RD I have with a 7 speed freewheel, I'll have to operate it in friction mode? Is that because the shifter has only up to 6 clicks?
Thanks for the offer! I'll shoot you a pm. Good catch. I thought that photo looked a little weird until I realized I had put the rear wheel incorrectly. It was only for the photo though.
Thanks for the suggestion. Like I said, I live in a hilly area so my daily commute is barely (~20%) on flats. I'm in the 42 (front) all the time with larger sprocket going uphill and smaller sprocket going downhill (12-28). I'm thinking 6 speed 14-28 should work. I much prefer index shifting than friction for rear derailleur.
As others have already said, you need a freewheel for that hub, not a cassette. I have a Shimano freewheel (not cassette) with 13 15 17 19 21 24 28 teeth. I bought it new February 19th of this year and used it through April, so it's almost new. Interested? I'm in Manhattan.
#2514
Nothing wrong with keeping it 6 speed. In fact that freewheel may clean up nice with WD 40 and a toothbrush however I believe that's a 13-24 tooth. At which point you can assess if you need to order a new screw on 6 speed SIS compatible freewheel with those shifters or get a set of 7 speed shifters and a 7 speed screw on freewheel to keep the index shifting.
Have fun and good luck.
#2515
Here's the big brother to the Ironman. And my favorite color Ironman as we've seen at least one Ironman in this color scheme. I can't make out the size though. Possibly a 56. Either way more than fair price.
Vintage Centurion Prestige Road Bike Bicycle
#2518
Here is the full list of Suntour parts I will be selling, all of which were original parts on my Centurion Ironman and now replaced with Dura Ace components:
brake levers and hoods
hub on Mavic front wheel with skewer (bearings replaced late 2015 or early 2016)
rear hub and skewer (no wheel)
front and rear brakes
rear derailleur (7-speed)
front derailleur
front and rear shifters
crankset 175-mm 52/42
I will also be selling Suntour brake levers and hoods bought NOS 3/1/13.
front derailleur
#2521
Bikes: Viscount: Pro, GP, Gran Touring, Gran Sports, custom single speed. Vitus 979, Trek Madone 5.2, Motobecane Le Champion SL Ti, Kona Koa, Centurion Ironman Expert
zs3889, I switched the 1050 down tube shifters to 1055 shifters found on eBay. These are designed for 7 speed index shifting (7 clicks!). It took me a while to find decent ones at a fair price, so good luck.
#2522
front derailleur
front derailleur
#2523
Anybody got a Shimano 600 Rear Derailieur from a 85 Ironman they want to part with. the Dark anodized one.
This girl has a 600 Ultegra unit but i want to go back to stock on it.
And did the 85 have Dark anodized 600 Brake levers or was that 1986? most of all the pics ive seen of the 1985's dont have the Anodized ones.
#2524
Yes, except for the second pair of brake levers I bought as NOS 3/1/13.
CORRECTION: The front wheel is an Araya CTL-370, not a Mavic.
Here's a picture of the Ironman taken July 24, 2014, with the components-for-sale mentioned previously:
