Bent Axle?
Quoted: 12 Post(s)
Bent Axle?
I'm working on getting an '88 stumpjumper back on the road. I recently regreased the bearings, bought 7 speed freewheel and new chain, put this on today and notices the hub wobbles when I turn the pedals. Is this a bent axle? It didn't look bent, but I don't know what else would cause this.
Here's what it looks like:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
that ain't the hub... that's a lousy, poorly made freewheel.
That normal for a freewheel , there nothing wrong with your hub or wheel .
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
Freewheel wobble is primarily caused by hub defects.
Most cheap entry level freewheel type hubs will have machining that is off center at one or more locations to various extents.
Freewheel simply inherits whatever hub motion in created as a result.
Search Youtube for Wheels By Fleming - I have a video explaining it.
The effect on the bike and shifting? Little or none...nothing to lose sleep over.
=8-)
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
Quoted: 12 Post(s)
=8-)
=8-)
I don't see a name in the hub either, however, everything on the bike is Deore.
Old fart
Quoted: 3582 Post(s)
Liked 3,395 Times
Quoted: 12 Post(s)
Quoted: 239 Post(s)
Liked 7 Times
Vintage ones do. (and a few moderns ones that copy old designs)
It's all about progress
when Vertical dropouts became normal, QRs were improved to take advantage by reducing their cost.
Quoted: 12 Post(s)
As for the wobble, I guess I'm stuck wth it.
The good news is that there's nothing for me to fix here and I can move on to other parts of the bike.
Thanks again for all the replies and help.
On an unrelated note, I think the rear dropouts might be bent, so that's my next point of investigation....
Quoted: 86 Post(s)
my '88 or '89 (?) stumpjumper, with original wheels and u-brake, has what look to be shimano 600 hubs. but i would imagine that they called them Deore or something similar. and IIRC they had uniglide freehubs on them.
BTW, i can't see much from the video, except it looks like the entire rear of the bike is wobbling.
Quoted: 12 Post(s)
Does yours have QR rear hub?
As far as the freewheel wobble, I reinstalled the original freewheel and it still had wobble though not as much. From what I read here, I'm not going to worry.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
For all I know, making the threads 100% parallel is very hard to achieve. The mismatch could be either the hub, or the freewheel, or both. It's very hard to machine the threads so they are 100% centered to the axis.
Have you experimented with switching a freewheel from a cheap, to a higher quality hub to confirm that the hub is the (only) faulty part?
Quoted: 12 Post(s)
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Regarding the axle, it may well be bent but that cannot be what's causing your wobble. The axle doesn't move. The bearing cones are on the axle that doesn't move. A bent axle could result in your wheel not lining up between your brake pads, or between your chainstays. But it won't cause wheel wobble.
Spin the wheel with the crank so that the freewheel is not "clicking" and is rotating with the hub. Is the hub rim rotating evenly? With the chain on the small sprocket, can you see if the freewheel is wobbling? If the hub itself is wobbling, then whoever made it didn't pass machine shop 101, and you have bearing seats that are not concentric with the hub rims and (probably) the freewheel threads. And you need a new hub. If the hob does not wobble when you use your crank to rotate the wheel (that is, the freewheel isn't clicking), but you see the freewheel wobble (easiest to check viewing the big cog, with a popsicle stick or something clipped to the seat stay) then the freewheels bearings, threads, and/or cog seat was poorly made, or the hub might have its threads not parallel and concentric with the hub axis. New freewheel for the former issue, new hub for the latter.
The technology to ensure concentricity was available in the 1890s, and Sir Joseph Whitworth (namesake of Whitworth screw form, inventor of the surface plate) had measuring devices that resolved down to something like 5 millions of an inch back in 1840 or so. So mfrs had the means to check concentricity.
But it ain't the axle.
Quoted: 86 Post(s)
and although i didn't explicitly state it, mine does not have a freewheel, but instead, a freehub. not that it makes much difference. IME, the cogs often wobble a little on either one. BTW, the rims say SATURNE or something similar on them. i'm sure they are original. it looks like it's a machine welded cromo frame with a big old unicrown fork and shimano oldschool wide cantis. built like a tank.
Mostly harmless ™
Liked 216 Times
So, not disputing, more "thinking out loud", please correct me if I'm wrong on any account: frewheel sprockets stand relatively far away from the threads - both laterally and vertically. Making any marginal error seem (more) visible. So 0.01 degree error on a cone might be compensated by material flex and definitely hard to spot with an eye, but if a cone had a 15 T ring attached to it, it might be even visible? Low quality cup and cone hubs let you choose between play and considerable friction that is easily felt when turning an axle by hand on a removed wheel. Higher quality ones are a lot better, but I'm sure even they are not 100% perfect - all comes down to acceptable tolerances and the cost of satisfying them in production. My info is that making freewheel/hub threads so that no play can be seen is very hard. Also, from my knowledge, when something needs to be 100% centered like that, threads are not used for centering - splines or other mechanisms are preferable. Am I correct?
I think every freewheel I've ever seen has some amount of wobble. If what you say is correct, it could be possible (and wouldn't amaze me) that all the manufacturers didn't care much about precision machining - close was good enough for the use and rotating speeds freewheel "sees".
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
I've attached scans from the 1988 Specialized catalog to confirm. The whole catalog can be found at retrobike.co.uk HERE.
So long as you're using a freewheel, you're gonna have some wobble.
Liked 341 Times
I'm not an expert on machining, so I'm not contradicting your claim - just questioning and taking it with a grain of salt, because, from my knowledge, having "investigated" the wobble phenomena, that is not correct, at least for the length and width (diameter) of freewheel attachment mounts.
I grew up working in my Dad's machine shop, and studied engineering. Not an expert, but I have some knowledge.
Round stuff is often made on a lathe. In the old manual process, you'd fasten work to the "spindle" (the thing that is connected to a motor and spins on bearings to rotate the work) using a chuck. The chuck is not perfect, and the round piece may be off-center (known as "run out"), but if you use the lathe to cut the outer diameter off your raw stock, the turned portion is round and rotates perfectly on center. Any further cuts (recesses for bearings, threads for freewheels, rims to accept spokes) you make without taking the workpiece out of the chuck remain perfectly on center. So you should be able to get a lot of a wheel hub, for example, very concentric. Within a 0.001 or so (or better). This amount of runout would not be noticeable even with the geometry points you correctly note. If you have to take the workpiece out and rechuck (for example, to machine the NDS after you've machined the DS) it you can get into trouble. Rechucking in a worn old "three jaw" chuck that use a scroll to control all jaws at the same time can give poor results. You can be off-center, and the work can end up not parallel with the other work features you've turned in the work. You can get good results by centering the workpiece using a "four jaw" chuck with individually adjustable jaws, but this takes time and expertise.
Modern production is done using automated machining centers, and these should give you work with almost no measureable non-concentricity.
I've never had a freewheel or hub that was off by much, but you've had a different experience. A freewheel made with care, by experts, should not show wobble.
Mostly harmless ™
Liked 216 Times
You are correct about quality production - most freewheels I've come across were (lower end) Shimano freewheels, on lower end Shimano, or "no name" manufacturers' hubs. All had wobble.
Other equipment made by Shimano, even lower end stuff was always of decent quality - hubs, cassettes, derailleurs... Don't understand why they would allow for wobbly freewheels, unless manufacturing straighter ones was more expensive/time consuming? It doesn't affect function, but looks bad IMO.
Quoted: 12 Post(s)
The Stumpjumper was a higher-end bike. It definitely would've had QR axles. It also would've had a freehub and cassette, not a freewheel.
So, I can keep my current wheels and live with them for now - or I can find a higher quality wheelset, either the original wheels or something current that is the right size for this bike.
I found a listing on eBay for vintage gx23 wheels with Deore hubs that would cost $130 shipped. I'm assuming that those would be the original wheels or close to it. Opinions? What new options might exist that don't require resizing the rear triangle?
