Paul Newman's mystery bike frame
Bikes: 1980 Gitane sprint,1977 Motobécane C4, 1977 Carlton Clubman, 1959 Claud Butler European
Quoted: 69 Post(s)
Liked 125 Times
Ha! That got you! Oh, you thought THAT Paul Newman……lol (my wife just said, a lot of people here wouldn’t know him now!). Ok, what have I bought for £35? Stronglight crank 60/52 tooth. Mafac cantilever bosses. TDC headset. Nervex lugs. Steel drop outs. Curved brake stay. Fluted seat stay caps. Holdsworth or Claud Butler I am thinking? Top tube 25.6mm. Seat tube internal approx 27.9mm.
Likes For awac:
Quoted: 69 Post(s)
Liked 125 Times
Also a couple of wheels thrown in with new tyres, woo-hoo! 4.375kg as is in the picture….I needed an excuse to buy a Stronglight crank extractor….!
1004 serial number
60/52 teeth
Likes For markk900:
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 681 Times
From https://www.nkilgariff.com/FrameNosTemp.htm
1004 as a Holdsworth serial number would be about 1936.
Claude Butler were 6 or 7 digit
Freddie Grub it could be 1923 or 1939.
None of those look likely to me.
But here's the fork from my 1961 Holdsworth Cyclone which is almost the same
However the brake fittings are no match:
Quoted: 69 Post(s)
Liked 125 Times
Better view of head lugs. The fork stem also carries the serial number 1004 found on bottom bracket.
Looking at the freewheel, I'd guess the prior owner liked to pedal with a slooooooow cadence.
What a great find. The wheels/rims,... what can I say? Wow!
There were two other bikes shown a couple of months ago, one being repainted in red, which also had those "spear point" seat stay caps. It could be, those help with identifying the maker. (Bad Lag takes off to find thread, put pedals slowly)
Likes For Bad Lag:
Quoted: 69 Post(s)
Liked 125 Times
Thanks for the photos, I think it is pretty close if you disregard the centre pull cable bracket above it and the cantilever bosses, seat lug looks different. Claud Butler had a model called European around 1959 with Mafac criterium cantilevers, is this one or were these added as extra later? The fork lug is close isn't it!
Quoted: 69 Post(s)
Liked 125 Times
The seat stay caps. Have seen a picture of this type on the web, so far, bertin, Holdsworth and interestingly Eddie Soens from Liverpool which might link the wheels with the Tierney cycles sticker.
Wheelman
Quoted: 298 Post(s)
Liked 681 Times
You won't have the same lugs as a Cyclone unless it's actually a Cyclone - a special Holdsworth lug set.
But seat stays look similar too - can't see clearly but I think yours are the thin spearpoint type:
Edit: cable stops have been replaced
Looks like different dropouts too, these are Campagnolo (10 shillings extra)
Likes For Aardwolf:
Wheelman
Quoted: 298 Post(s)
Liked 681 Times
Likes For Aardwolf:
Likes For due ruote:
Wheelman
Quoted: 298 Post(s)
Liked 681 Times
1959 European:
And checking the next couple of years thay switched to Mafac racer in 1961 !!!
Likes For Aardwolf:
Quoted: 3817 Post(s)
Liked 6,741 Times
Have you checked with the Chelmer Cycling Club? https://www.chelmercc.org.uk
Likes For nlerner:
Quoted: 69 Post(s)
Liked 125 Times
I just checked on https://nkilgariff.com/ClaudButler.htm
1959 European:
1959 European:
1957–1987 Holdsworth ownership of Claud Butler.
Your cyclone with the spear point seat lugs, with the Mafac criterium brakes on the European? Possible factory bitsa?10 shillings extra for campy dropouts,, trust me to find the cheapskate…..lol.
Quoted: 69 Post(s)
Liked 125 Times
Wheelman
Quoted: 298 Post(s)
Liked 681 Times
Claud Butler went bust in 1956
In 1958 Holdsworth bought 3 Claud Butler trade marks
The Claud (by Holdsworth) European launched in 1959 with frame numbers in the range 0001 to 4400.
It's all on the site https://nkilgariff.com/ClaudButler.htm
Likes For Aardwolf:
Wheelman
Quoted: 298 Post(s)
Liked 681 Times
Just a thought: could you link the advert you found this on
Guessing it's Ebay but I do peruse the adds when I'm bored and I totally missed this one.
Not that I have room for another bike.
Quoted: 3823 Post(s)
Liked 3,369 Times
looks like it may have been done for a retailer as a house branded frameset
NERVEX lug pattern 86bis/158
NERVEX bottom bracket shell nozzle cut Nr. 158
NERVEX dropouts Ref. 1007
NERVEX seat stay bridge Ref. 600 serie
Vagner fork crown Nr. 12ref+
seat binder Gripfast
TDC headset is Europa model
suggestion -
at earliest convenience reset registration ("clocking") of T. A. chainwheel adaptor Nr. 175 so that it is symmetric
suggestion -
Likes For juvela:
Quoted: 69 Post(s)
Liked 125 Times
Doh, I missed a bit: Claud Butler frame numbers reset when Holdsworth started making them.
Wheelman
Quoted: 298 Post(s)
Liked 681 Times
It's always interesting to learn the history of who made what back in the day.
If you want to check for the original colour have a look under the crown race.
Likes For Aardwolf:
Quoted: 69 Post(s)
Liked 125 Times
suggestion -
suggestion -
Wheelman
Quoted: 298 Post(s)
Liked 681 Times
Goodness gracious great lugs of er, well, frame. Amazing. Thank you for a full lug list, very, very handy. It is my great shame that I do not own a stronglight crank extractor, but a local charity bike shop owner I know thinks he might have one so will take it to bits tomorrow hopefully. Secretly I hope he does not so I can explain to my wife this is an essential purchase…..that’s how I have all the other crank and freewheel tools…sigh.
2in1 Stronglight Specialites T.A. removal remover crankset Arm Puller Tool NEW
Although other places also sell them.
Quoted: 69 Post(s)
Liked 125 Times
I got one off Ebay: https://www.ebay.co.uk/itm/222325878325
Liked 3,369 Times
wrt Stronglight crank puller -
you want to verify that what you order is the 23.35mm size for early Stronglight and not the 22.0mm size for later Stronglight
Likes For juvela:
