Great Allegheny Passage - Pittsburgh to Boston, PA, what's the trail like?
Bikes: "Hildy", a Novara Randonee touring bike; a 16-speed Bike Friday Tikit; and a Specialized Stumpjumper frame-based built-up MTB, now serving as the kid-carrier, grocery-getter.
Quoted: 11 Post(s)
I rode the GAP many moons ago, and the route from Pittsburgh to Boston was on-road (if memory serves, the off-road option was inconveniently long). But I hear the trail is complete now, and off-road. I may be headed to Pittsburgh for a weekend soon, and the prospect of riding the GAP again is irresistible.
Can anyone confirm that the trail is off-road, like the GAP site suggests? What's the surface like, are smooth road tires an option or should I bring my mountain bike for those 20 miles?
Tour Journals, Blog, ride pix
My bands:
My bands:
- Uke On! - ukulele duo - Videos
- Ukulele Abyss - ukulele cover videos - Videos
- Baroque and Hungry's (Celtic fusion) full-length studio album Mended.
- Artistic Differences - 8-track EP Dreams of Bile and Blood.
Bikes: 1976 Schwinn Super Le Tour, tricked out with modern components. Shimano Alfine 11 internal gear hub. Dynamo hub. Titanium racks and bottle cages. Mercier Kilo Wide Tire dropbar singlespeed
Quoted: 44 Post(s)
Liked 8 Times
Allegheny passage surface report
I have ridden the entire GAP/C&O five times in the last three years, and I am happy to report that the surface from Pittsburgh to Cumberland Maryland is magnificent. It is all very well mantained, well rolled and packed fine crushed stone. You DO NOT NEED a mountain bike, hybrid or fat-tire bike. Super skinny race tires would not be my choice. 30 or above, just fine. I have riddent the entire length with 32s, 35s and 38s. Wider is helpful when you get onto the C&O at Cumberland MD. On the Alleghenny Passage from Pitts to Cumberland, the surface is magnificent. You now start at Point State Park in downtown Pittsburgh. You have a little bit of road and paved riding and then well maintained trail.
Speechless
Bikes: Felt Brougham, Lotus Prestige, Cinelli Xperience,
Quoted: 163 Post(s)
Liked 39 Times
Three weeks ago, I did that Cumberland to Pitt portion on 28's, and could have easily done it on 25's. It is very fine crushed stone, and very easy to cruise along at 18mph with no concern for stability or traction.
Quoted: 258 Post(s)
Liked 291 Times
Pittsburgh to Boston can be ridden completely off road. Using Google maps, the route will take you to the Point via the Ft. Pitt Bridge. https://goo.gl/maps/31uYwJtXRJL2
If you opt for the Hot Metal Bridge route, there's a bit of on-road in downtown Pittsburgh. https://goo.gl/maps/Qe2NJp3BT132 I'd actually modify this route and head down Ft. Pitt Boulevard to Commonwealth and head into the park (Google won't let me do that on their map).
There's a way to eliminate 95% of that on-street (to literally one block on-street), if you drop down to the Mon Wharf parking lot. I can't get Google Maps to draw that, but it wouldn't be hard to describe if you are interested.
Regarding tires, there's no need for mountain bike tires on that section. If my memory serves me, it's entirely paved from downtown Pittsburgh to past McKeesport. Might be all the way to Boston, depending which side of the Yough you stay on, can't quite recall that end. Farther out than Boston, it's crushed limestone, for sure. If it's dry, you could probably ride out past Boston on 25's. If it's wet, meh, 32's or 35's would be better.
Quoted: 18398 Post(s)
Liked 15,495 Times
IIRC correctly, there is one short, on-road section. If you look at the map for the northern most section you will see s trip of yellow. in the Port Vue/McKeesport area. According to the map's legend, yellow is on-road.
Great Allegheny Passage - www.gaptrail.org
Quoted: 258 Post(s)
Liked 291 Times
Yeah, Indyfabz, you're right. I forgot about that section. Now that I think about it, there always seems to be a puddle at the southern point of that road section, where it transitions to trail again. I've also ridden on the opposite side of the Yough and some of that is on-road, but the roads were very quiet when I rode them. You can ride a mapped out circle route on both sides of the Yough between McKeesport and Boston - there are (or were) signs with maps showing the path.
