Tribar on MTB?!
Tribar on MTB?!
Now this may seem ridiculous but hear me out I've entered into a single stage MTB race called the Munga, it entails covering 1000km+ across South Africa in summer. I'm looking for aerobars to help with position and general comfort.. I currently have the Bontrager Kovee pro carbon 35 handlebar and because of its unique shape its almost impossible to find the right aerobat that will fit the bar. Can anyone help by recommending something that will work? would be super grateful for any help!
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
Jones H-bar - they have carbon and titanium options as well ——. Its the only bar id want for a ride like that
Likes For DMC707:
Quoted: 2483 Post(s)
Liked 2,955 Times
Chat with someone at Trek to ask whether any clip-on aero bar would work with that bar's "unique shape" (is the cross-section not round?). If not, given the length of the ride you propose to undertake, you might want to consider installing another bar that will allow use of a clip-on bar.
In any event, be sure that your long-distance setup includes padded forearm/elbow pads, which are invaluable for supporting your upper body weight. I'm primarily a road bike rider, but for decades, I've done all my cold weather/rainy weather training on an old Cannondale mountain bike with fenders and clip-on aero bars. It's so comfortable, I sometimes use that bike instead of one of the road bikes even in good weather.
Quoted: 1944 Post(s)
Liked 2,164 Times
I’m no expert on mtb geometry, but I think a lot depends on exactly what bike you are going to ride and the type of terrain. Older mtb’s placed the rider with more weight over the front wheel. Over time that weight distribution has moved back.
I would think you would need to get the bike setup correctly with flat bars and see where your tuck ends up. My other concern is the amount of control you would have with narrow tribars on a slack head angle mtn bike.
John
John
Check out some options that BarYak has. Not traditional aero bars, but they are designed to be used with flat bars. And they also provide mounting options for electronics.
Likes For TruckerBrad:
Liked 2,955 Times
John
John
Likes For Happy Feet:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
I'm guessing the aero bars won't go because of the long taper down from the 35mm clamp area which is very wide on this bar, probably for lights. If you swapped for a bar with a wide 31.8 clamp diameter like a Salsa Rustler and a stem to match you'd be able to mount the aero bars no problem
Kovee Pro
Kovee XXX
Kovee Pro
Kovee XXX
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
I would look at the Koga Denham Bar that might be the better choice for a long distance event like that. Jones bars have way too much sweep for comfort at least for me. The Denhams are perfect.
Quoted: 2236 Post(s)
Liked 1,314 Times
Or just get a 31.8mm stem and use any flat bar that will also fit any clip on aerobar. The only problem really is the oversized diameter of the current one.
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
that race sounds awesome!
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times
I’ve gone back to Jones, as they just feel better to me in technical terrain (full rigid 29+).
I have a new, unmounted Denham (I ordered 2 ) that I’d sell. Just putting it out there, since the main source is in Holland and my order took over 3 months to arrive. The Denham offers an ideal “on the hoods” postion (on the integrated extensions) that is hard to beat for long, straight cranking.
The Jones option offers their “Narwhal”, which IMO would be the ultimate true aero setup un a MTB.
Denham on my bike from different angles.
Here’s the Jones H bar / Narwhal combo
Likes For canyoneagle:
Clark W. Griswold
Liked 3,994 Times
the Denhams are definitely nice. Hard to source, but great all-rounders.
Quoted: 174 Post(s)
Liked 157 Times
I’ve attempted to emulate the same kind of setup, but found it difficult to get the sweep and bend mix that works. Too many tradeoffs.
I can’t recall the exact cost, but they’re in the same ballpark (maybe a little more) as other alt bars, or nice swept bar + ends. Not enough difference to sweat, unless on a tight budget.
Here’s the writeup comparing his one-off version (Denham) to other bars in the genre (so called alt-bars).
https://www.cyclingabout.com/compari...with-alt-bars/
Disco Infiltrator
Liked 2,105 Times
What I can't figure out, with bars like those, is what the frame reach and stem are supposed to be to go with them. You see people putting them on both flat and drop bar frames and seemingly happy. I can't see what to do without making the "hoods" too far or the flats too close. In fact the same deal with bar ends. I don't like drop bars very much but they don't do that.
Genesis 49:16-17
Genesis 49:16-17
