Gravel bike Gear-inches
What gear-inches are you good folks running on the low end?
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
lowest gear on a geared bike or singlespeed? I ride mid-high 50s for SS. 36/17 on 700C 32mm tires at the moment.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
I have a 30-32 low...so with 700Cx44mm tires that comes out to 26.1. Very useful for pea gravel or MMR 15% inclines
Sunshine
Quoted: 10995 Post(s)
Liked 7,519 Times
34-36. So just under 26GI, since i use 40mm tires.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
About 25.8 inches according to the online calculators.
It is a 34 ring and a 36 sprocket with 38 mm tires.
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
30-36 with 650Bx47 tires. 22.6 gear inches.
Noob
Bikes: Gravel: 2018 Specialized Diverge Expert. Road: Trek 2013 Domane Di2, 2006 Specialized Roubaix Pro (retired), MTB: 2014 Trek Fuel EX8 29er, Folder: Dahon Mu P24
Quoted: 12 Post(s)
Diverge Expert. 24.7" 38mm tires 38t front, 42t rear. Came stock with 42t front, I swapped it out for a 38t.
Sheldon Brown's Bicycle Gear Calculator
Quoted: 7010 Post(s)
Liked 11,010 Times
29". Which means I may be pushing my bike up a couple climbs during some races I plan to do this summer.
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
About 29" (34 chainring and 32 cog). Good for the climbs around here (kansas) which at most get to 15% in spots and never last more than a 1/2 mile or so.
If I regularly rode in mountains I might go with with a 34 or 36 cassette -- but at a certain point you're just going so slow with those gears the bike doesn't stay upright.
Never had to walk a hill with my combo though. (knock on wood).
Squeezebox
18
05-05-16 11:13 PM
Cyclist0103
9
02-19-16 06:07 AM
