Peugeot 753
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 636 Times
Peugeot 753
After a lot of trials and tribulations I finally have my sticky mitts on a much searched for addition to the the fleet .
HAs a whole lot of interesting (hopefully not just to me ) bits about it as well as racing pedigree .
Took some quick night shots . Will take some more shots in the daylight tomorrow after I calm down . !
check that cable guide hanger !
753
drilled dropouts !
753
drilled dropouts !
Quoted: 2323 Post(s)
Liked 4,990 Times
Score! Can't wait to see more.
Steel is real...and comfy.
Quoted: 1608 Post(s)
Liked 2,216 Times
REALLY like that axle stop design! Serviceability to nth degree! I bet you could retrofit to existing DO with stripped or otherwise damaged threads.
Hmmmm…..
Interesting vent hole in the chain stay too. Does it have an insert?
Is ti expected to use center pulls? Nice bracket.
Hmmmm…..
Bikes: '68 Masi Special road, Grail bike
Quoted: 108 Post(s)
Liked 70 Times
I like the minimalist lugs. kinda disappointed that the stays are just domed. the brake cable hanger
is nicely done but now you're stuck with centerpulls, I guess you'll be looking for some Mafac 2000s
as they were their best. why is the shifter boss painted gold with a touch of blue behind?
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
Nice score. You will like the ride.
Quoted: 3464 Post(s)
Liked 2,831 Times
Quoted: 834 Post(s)
Liked 2,126 Times
Adding on to what repechage notes about the domed stays, I wonder if the main tubes are 753, but not the stays? I know that some 753 frames got chrome treatment, but it was generally discouraged. Might explain the chrome socks on this Peugeot. Just speculating. Regardless, very sweet frame/project. Looking forward to more pics.
Quoted: 1641 Post(s)
Liked 831 Times
Looks like a PY10 from Peugeot's special custom build shop that built bikes for their team pros!
Fantastic find!
The domed stay ends are just what was typical on Peugeots. Gitanes had better looking chisel point stay ends, but who cares with a super Peugeot bike like this one!
Fantastic find!
Likes For Chombi1:
Quoted: 283 Post(s)
Liked 636 Times
The bike came complete minus wheels .
So have the centrepulls it was designed for.
The boss gold is greasy gunk with a little bare metal showing .
Likes For 1simplexnut:
Quoted: 591 Post(s)
Liked 663 Times
753
drilled dropouts !
753
drilled dropouts !
Quoted: 283 Post(s)
Liked 636 Times
Yes it is odd .
Hiya By "touched" do you mean the absence of the S in simplex ?
I looked at it sideways myself when I first looked at it .
Looks to be done in the factory . all tidy and chromed .
I wonder why it was done ?
I have noticed that the thickness of the dropouts appear to be heavier that standard simplex on other pugs i have .
Will have a measure up when I get a chance .
Pic attached of hanger .
Quoted: 283 Post(s)
Liked 636 Times
chombi hit the nail on the head earlier in the thread .
Definately a frame from the pro shop in my opinion .
A whole lot of features point to that .
A couple of real obvious ones which i will share later .
Component list mainly french as you would expect .
MAFAC GT brakes
Simplex/spidel derailleurs
Spidel crank set 175mm and spidel pedals
Stronglight competition alloy headset
Bottom bracket Stronglight cartridge ?
spidel alloy seat post attached to a Ideal 2002 which is marked "titane"
Components all in tidy used usable condition .
Condition of frame is well used .
Lots of scratches and scrapes here and there plus a couple of small dings in the top tube .
It is a very solid build without a lot of frills .
Just a good honest racing machine .
Plan is to give it a good clean and treat the frame etc for corrosion .
Then put it back together and ride it !
Should be fun !
More pictures to come as I progress . cheers
teaser
MAFAC GT brakes
Should be fun !
teaser
Quoted: 283 Post(s)
Liked 636 Times
Not sure how I would be able to tell ?
It is not a standard factory built frame so anything is possible ?
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
Quoted: 108 Post(s)
Liked 70 Times
never saw those Mafac GTs b4. like the bolts,don't like the QRs
always liked the simple/elegant design of just releasing one side of
the straddle wire. plus they opened wider than other brakes
Quoted: 5888 Post(s)
Liked 3,471 Times
This is a cool bike. What are you going to run for wheels? Low flange maillard 700 hubs?
Quoted: 283 Post(s)
Liked 636 Times
Quoted: 283 Post(s)
Liked 636 Times
Fantastic find!
Fantastic find!
Quoted: 283 Post(s)
Liked 636 Times
A couple of Italian bits amongst all the frenchness .
Bar plugs are cool !
Quoted: 283 Post(s)
Liked 636 Times
Some progress here and there . Mainly cleaning and polishing bits
Saddle came up well .
before
after
before
after
Quoted: 283 Post(s)
Liked 636 Times
Progress ! a couple of little bits to sort . looking forward to the ride.
Liked 4,990 Times
^ Totally digging it!
Quoted: 108 Post(s)
Liked 70 Times
why would someone not bother to center the bars in the stem? would have expected Phillipe bars and stem
it's interesting that in the Spidel era that the Simplex seatpost hasn't been upgraded at all...
Quoted: 283 Post(s)
Liked 636 Times
Cinelli pretty standard fare for the Peugeot racing teams back then .
Bike is an interesting mix of bits . Simplex rear , spidel front mechanism .
I like the seat post . Very light . I dont recall ever seeing a spidel branded seat post previously on a bike of this era ( sure someone will show me other wise now )
