Pletsher Twin Kickstand Questions?
Bikes: Easy Racers Fold Rush 1987 Miyata 215 ST Rans Dynamik 1987 Schwinn Sierra Burley Duet
Quoted: 30 Post(s)
Liked 18 Times
I am in the process of fitting out a 2002 Burley Rock and Roll to suit us. It has an Arai drag brake. So my Greenfield kickstand will not mount due to interference with the drag brake support arm. I never felt that having the kickstand so far back was the best setup anyway. I see a number of you have the Pletsher twin kickstand that mounts just behind the Stoker's BB. I was wondering if the Pletsher will fit all tandem setups or are some setups not suitable for the Pletsher? Is there a possibility of some part of the kickstand interfering with the primary or secondary chainrings? I have changed the Stokers crankset to a shortened Sram S600 MTB crankset and a shorter BB to keep the chain in the same line as was original.
I checked the Pletsher Website and they have only one twin kickstand listed in two different lengths and available in black or silver. They have it listed as "twin". Yet on some sellers websites they have a "Pletsher twin ESGE KS12" kickstand listed. Except for the two different lengths and two colors that Pletsher offers are all the Pletsher twin kickstands the same?
Thanks!
Thanks!
Quoted: 680 Post(s)
Liked 948 Times
we havde this guy and it works well. it could be a bit longer as it hardly gets our 700cc wheel off the ground. but its stable and beefy. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 189 Post(s)
Liked 106 Times
If you eventually give up on the kick stand, you may wish to consider a Click-stand (Click-Stand Home Page)
Quoted: 30 Post(s)
Liked 18 Times
Thanks to both of you that have replied. After doing a little more homework, I think I will pass on the Pletsher for now and give a Clickstand a try.
Quoted: 2495 Post(s)
Liked 738 Times
Likes For Leisesturm:
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
I will be putting a Pletscher Twin kickstand on it soon. It has the frame plate for it and will be a lot easier and more intuitive than its current solution.
Quoted: 189 Post(s)
Liked 106 Times
This is in part personal preference. We have used the click-stand on heavily loaded long tours for more than 10 years and found it to be simple and reliable. The stand is affixed to our frame so always available. A cord that resides on the handle bar readily locks a brake on. We sometimes tour with others that have the twined kickstand. They must find approximate level ground and their bike has fallen more than once, but perhaps they are less careful. The click-stand does not require level ground and our bike has never fallen (knock on wood). Either stand requires something like a wide plastic bottle cap in muddy conditions to keep the stand from sinking into soft dirt. It is of course true that fixing a flat is simple with the rear tire off the ground, but that also means you must lift your heavy load off the ground each time your park the bike, and a heavy load affects the stability of the twined kickstand when bike is up. We usually have tough tires on tour so rarely a flat (more knocking on wood), but panniers/bags must come off the bike to fix a flat, which is certainly a hassle. We also use a steer-stopper to lock the front wheel in line, which is important when carrying loads on front wheel. The steer-stopper is a bit pricey, we used to use a length of webbing wheel-to-frame, but the the steer-stopper is simpler.
Likes For IPassGas:
Quoted: 13 Post(s)
We use the Pletsher/Esge kickstand for normal (nontouring) use. It works very well, is easy and quick to deploy, and has the added benefit of holding the bike up like a bike stand when assembling and disassembling the bike when traveling. It has a weight limit, if I recall, of around 20 kg. So, we recently bought a Click-stand to use when the bike is loaded with panniers.
Quoted: 80 Post(s)
Liked 39 Times
We have a Pletsher twin kickstand on our DaVinci Grand Junction. We like it. It is better than a one-legged stand for a loaded bike. Yes, it is a bit of a task to lift the loaded bike up to put the stand down. But, it holds the bike well on the stand and, as other have mentioned, it's beneficial to have the rear wheel off the ground (fixing a flat, adjusting disc brake, checking for glass in tire, etc.).
Quoted: 680 Post(s)
Liked 948 Times
the one I recommended is a bit heavy but you don't have to lift the bike just pull it backwards with a foot against the kickstand and push it forward to bring it up,. It can handle 170 pounds.
Liked 738 Times
Edit: I have a cargo bike with a double (not Esge) stand and it (the stand) gets poor reviews. I can't verify this, but apparently Ergotec double leg stands are very good. All I can find out is they are German.
Quoted: 680 Post(s)
Liked 948 Times
Ursus Jumbo Double Leg Kickstand made in Italy. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
here are some more pics. it works fine on less then flat surfaces. my only complaint is it doe not aways get the rear wheel off the ground. you also cant peddle the bike while using it like a work stand.
Yes, the Jumbo is a good answer for a dual kickstand. I've been keeping an eye out for a used one to appear. Tough to fork out for a kickstand what many complete used bikes cost.
Thanks!
Thanks!
Quoted: 427 Post(s)
Liked 339 Times
+10 for the Pletcher. Hve had one on last 3 tandems. If a regular greenlee kickstand will fit then likely the pletcher will too.
Quoted: 30 Post(s)
Liked 18 Times
Does a Pletcher double kickstand require a hard, flat, and level surface? We sometimes stop for a break on the sloped, gravel shoulder off beyond the edge of the pavement to be out of the way of traffic.
