Magura EV02 Hydraulic Brakes- ANY GOOD or Trouble ?
Quoted: 97 Post(s)
Liked 40 Times
I am considering the purchase of a Tandem with these HYDRAULIC RIM RUB brakes and have only ever used regular wire pull
rim brakes and drum brakes on a Tandem. The specific model of Magura Brakes is the HS33-EVO2
The bike I am looking at is 13 years old and I am afraid of problems and being too difficult for me to fix.
Wire pull rim brakes are fully visible and easy to figure out when problems occur.
Are these hydraulic RIM RUB brakes a good idea or do they represent a lot of probable regrettable headaches ?
pan y agua
Quoted: 1428 Post(s)
Liked 697 Times
Hydraulic dis brakes are a dramatic improvement in braking performance over cable actuated rim brakes for a tandem.
Magura is one of the original manufacturers of disc brakes for bikes and have a good reputation.
the brakes are likely to need little maintenance other than changing They might rarely need bled. ( Magura claims that because they use mineral oil, the original fluid can last a very long time without needing bled). If they do need bled, it’s not that hard to learn, or jjust pay a shop to do it.
You could get lost and die.
You could hit a tree and die.
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 460 Post(s)
Liked 539 Times
Are the EVO-2 brakes the hydraulic RIM brakes Magura made a few years ago?
pan y agua
Liked 697 Times
I think they are. I just saw hydraulic and assumed disc.
Quoted: 460 Post(s)
Liked 539 Times
I don't know what the reliability history has been for those brakes,but in general Magura stuff is OK. Back in my motorcycle days, their stuff was highly thought of. I know some people had issues with some of their low end disk brakes using polymer castings and easily buggered by improper wrench turning, but these look to be all metal.
I believe that those brakes mount on standard cantilever brake post mounts. If that is the case, the worst case for you would be that you will need to swap out the Magura for some cable actuated cantilever brakes. Shimano probably still makes them.
As far as being a maintenance headache, my guess is that the only maintenance you will need for a while is to change the pads. I have no idea if they are still available, but Google says that Koolstop still lists them. If you like the way the brakes work, maybe buy 5 sets?
Other than that, hydraulic brakes are just different from cable actuation. You may need to bleed them. Fluid needs to be changed, and they probably use Magura mineral oil which is very available. Compared to hydraulic, cables are an inefficient system and a real maintenance headache. But they are simple and fairly easy to fix by the side of the road if you have spare parts, and they are cheap.
Bikes: Landshark, Kestrel Ironman, Giant Defy, Redline 925er, Orbea team Euskatel, AMP B2, Landshark e-Tandem, and, well you get the idea.
Quoted: 26 Post(s)
Liked 45 Times
I have these on my old 1995 AMP B-3 mountain bike. They still work great and have been maintenance free all these years. I cannot believe they still make them.
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 275 Post(s)
Liked 201 Times
I just replied to the other brake topic and mentioned my Maguras. I have them on my mountain tandem. As a mechanic, I've always had pretty strong hands, but found the Maguras didn't provide enough brute braking power I had expected. I rode them front and rear for over a decade and then happened to upgrade the shock which required switching to hydraulic disc. The difference couldn't be more obvious! One finger braking on the tandem on the steepest terrain. THAT is what hydraulic brakes SHOULD be. So this only confirmed my bad impression of the Maguras. They SHOULD be incredibly powerful, but have never been. I started with the standard black pads and upgraded to their green pads - same issues.
That said, the advantage of ZERO squishy feel is still there. My road tandem has XT cantilevers and the rear has always been squishy. Not so bad as to be an issue, but annoying nonetheless. Hydraulic eliminates this problem by design.
My Maguras are from '97, so I can only hope and assume they've improved the power issue. Or perhaps not, given they aren't really designing for the tandem market and probably exclusively the observed trials market at this point (also a tiny market segment).
I hope that helps.
PS In 23 1/2 years, I have never had a SINGLE maintenance issue with the Maguras. Only brake pad changes and pad adjustments.
I hope that helps.
Quoted: 97 Post(s)
Liked 40 Times
I . I started with the standard black pads and upgraded to their green pads - same issues.
. BTW, I did see your mention of "pad adjustments" but I wasnt clear if that was only upon initial installation or ongoing as the pads wear.
Quoted: 1073 Post(s)
Liked 999 Times
I hope that helps.
I hope that helps.
Quoted: 275 Post(s)
Liked 201 Times
I am curious re the Magura Hydraulic Rim brakes.... When the pads wear, are they self adjusting or does the space between the pads and the rim steadily get bigger as the pads wear until you replace the pads? I didnt know about the different color pads. I assume they are Magura OEM and perhaps the green pads are softer and thusly offer greater friction and stopping force.
And crushing rims? I've never even thought about that eventuality and obviously never experienced this. Running Sun Rhyno Lite rims.
Quoted: 97 Post(s)
Liked 40 Times
I want to report to everyone that I DID buy the bike and I absolutely LUV the MAGURA HS-33 EVO2 hydraulic rim brakes. When I bought the bike the pads were worn
and the pistons were out of adjustment with never having been adjusted for pad wear. With new "RED" "competition" Magura pads and proper adjustment,
I can easily ( with very little grip pressure) lock up the rear tire with stoker on back at high speed.
