Campy hub, is it dead or not?
RUSA #3100
Bikes: Yes
Quoted: 237 Post(s)
Liked 505 Times
I believe this rear hub is a late 80's Chorus/Victory unit. I am considering building a wheel with it even though it has this obvious flaw outboard of the hub flange on the rear non-drive side. It wont be a display bike, more of an occasional rider. Any thoughts?
https://utahrandonneur.wordpress.com
Passista
Quoted: 868 Post(s)
Liked 721 Times
I wouldn't build a wheel around it unless I had an used rim and used spokes already - and I wouldn't trust it much anyway.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
There's zero reason to build it up. Use the axle, nuts, washers, cones, and caps for parts. Polish the shell and put it on the bookcase.
Likes For SurferRosa:
Quoted: 3464 Post(s)
Liked 2,831 Times
Time to let this one retire,
Crawlin' up, flyin' down
Quoted: 1027 Post(s)
Liked 2,531 Times
If it's a rear hub: No, I would not ride it.
If it's a front hub: Hell no, I would not ride it.
Bikes: '68 Masi Special road, Grail bike
Quoted: 108 Post(s)
Liked 70 Times
it might be fun to file it and see how deep the crack goes but it's not worth reusing
mid to low level Campy parts from this era were made in the "eastern bloc" somewhere
not the same Campy that alloyed al-alloy for the space shuttle and formula one wheels
Likes For steve sumner:
Quoted: 930 Post(s)
Liked 1,293 Times
It's dead, Jim!
Likes For davester:
Likes For pcb:
Quoted: 1088 Post(s)
Liked 1,205 Times
I'll just pile on to say that I'd never ride that wheel. Considering the forces you ask a wheel hub to withstand, that's asking for trouble. A few good parts inside that hub that can be salvaged, though, as others have pointed out.
RUSA #3100
Bikes: Yes
Quoted: 237 Post(s)
Liked 505 Times
Sounds like a Star Trek quote! I'll respond with "I'm a doctor, not a magician!"
I probably won't build it up. Hubs like this are not that expensive. I was just curious to see how bold others on this forum are.
FWIW, the wheel that this came out of had already done the Eroica Cal medium route in this condition and it did not seem to get any worse because of it. I do know that it will eventually fail though.
Cheers!
Cheers!
Quoted: 4806 Post(s)
Liked 3,931 Times
I'll be contrary. That hub is perfectly safe as long as you keep the crack down. So ride it accordingly and don't sweat it.
Perfectly safe for rides up to ~24 (inches, not miles).
señor miembro
Liked 6,488 Times
