Calibrate power meter on smart trainer?
So I purchased this trainer late last year, Elite Qubo Power Smart B+ Trainer, and I have to admit that it's been pretty nice to have something to train with when I can't get on the road. However, I have suspected for quite some time that the virtual power it's saying I'm putting out is off. When I sprint it says I'm putting out 1800+ watts which isn't possible. I've never put out more than 1200 according to my PowerTap. It is much easier to hold 350watts for 5 minutes on the trainer than on the road; by a long shot.
So with that said, is there a way to calibrate the power on this trainer? And if so, how do I do it? I can't find anything worth looking at on the Elite website. I feel that my training on the trainer is suffering since I can't trust the numbers that I'm training off of. I'll be getting a Kickr before next winter, but this needs to fixed before then.
In need of some help, advice.
Thanks in advance.
Brandon
Thanks in advance.
Brandon
What software are you using? Use the Powertap as the power source and let the software control the trainer, then you don't have to worry about the stupid numbers the trainer spits out (the Kickr will have the same issue btw.)
Wait, that one isn't even controllable, is it? So virtual power? Wouldn't bother trying to get any accuracy out of that, just use the PT.
Right now I'm using Zwift exclusively but have been looking at trying TrainerRoad as well later this year. Unfortunately this trainer doesn't control resistance.
I can certainly do that, but was trying to avoid my race wheels for my trainer. I run tubeless and I either have to run tubeless on my trainer, which will wear my tire much faster, or constantly switch tires, which would suck.
Understandable.
If you want to give it a go, you could try increasing/decreasing tire pressure and/or the tension knob on the trainer until the numbers match those given by your power meter. You might be able to get it close. You could also try different power curves to see if another one matches better.
Understandable.
Yea that's another gripe I have is that there isn't a tension adjustment. Your body weight is what keeps the tire planted. However when sprinting, or out of the saddle efforts, I get wheel spin .
I didn't think of selecting a different trainer from the menu though. Maybe I'll give that a go and let some air out of the tire.
