Folding/ flat-packable rear rack
Being spoiled by Folding Rear Rack 2015 Cro-Moly on my 20" BF tandem, I did not anticipate how much pain would it be to pack the regular rear rack... it does not fit into my ritchey breakaway case and I would've need a second check-in bag to take it with me (the carry one fits two panniers perfectly but not much else). Fortunately, my buddy had space in his bag and I am saved this time. But I would definitely like to either buy a rack that folds or disassembles or find a way to fit the BF rack on the 700c bike. I understand that there is a weight-limit that results from the rack being packable but 55lb limit for BF rack is more than enough for me...
Any suggestions?
Any suggestions?
Quoted: 3461 Post(s)
Liked 1,467 Times
I am not sure if Racktime has a distributor in USA at this time. They used to but for a while they did not. But you should be able to order from Europe if they do not distribute here at this time.
Two models, the difference is that one of them has bolts on the plate that attaches to the dropouts, the other one is welded, depends on how far you want to break it down.
https://www.racktime.com/en/racktime...ct/foldit-fix/
https://www.racktime.com/en/racktime...it-adjustable/
Lots of little bolts and nuts to get lost, bring spares.
i've got an easydo brand rear rack with bolt on legs, similar to (almost a clone) of the racktime in the link. rated for 25kg. seems solid enough.
https://www.bike-components.de/en/Ra...x-Rack-p51682/
https://www.ebay.com/itm/Racktime-Fo...0/113334633100
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
I bought a Blackburn Local, but then didn't use it. I did practice with it though, both front and rear.
Riceowl (wacky name but intriguing) I bought a used bike that came with a foldit, and despite my skepticism, it is a reasonably stiff rack---given the number of bolt points and only two vertical supports, it does a great job.
My wife used it with pretty full rear panniers and it performed fine. I checked the bolts regularly, but was good.
It should for your requirements for space saving.
One to consider anyway.
I had this problem with my S&S bike, and I solved it by using a seat-post-mounted rack. Mine is a Topeak rack with optional side panels (https://www.topeak.com/us/en/product...ual-side-frame). It works, but it's not ideal. You have to be careful not to overload it, and even when not overloaded, it doesn't seem the best way to carry any amount of gear. But with a small enough amount of gear, it does the job and packs easily. Still, if you can pare your gear down enough, a seat bag would be a lighter option, and if you need/want to carry more than goes in a seat bag, then I thing some of the folding options already mentioned would be better. I like my seatpost-mounted rack for ease of packing and ease of set-up, but for sturdiness, I've been considering something along the lines of the foldit.
Not lost wanderer.
Quoted: 886 Post(s)
Liked 998 Times
Try the Nitto R14 it folds fairly flat
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Thanks for your responces thus far. Nitto R14 looks neat but at $150+ it is a bit over my budget. Foldit looks like a more reasonable choice. However, I may found an alternative solution. I can make my BF rack mount but it is tilted 30 degrees backward. It held pretty well as is and ortliebs stay on it. But I will search for a shorter arms
options or drill another set of holes to straighten it in a longer term.
pre-drilled mending plates come in various lengths.......
no bending required. the rack is less than 1cm narrower than the stays. if much wider, it wouldn't be too much trouble to bend the steel plates. you could also use aluminium strips - they hold the rack in place without supporting the full weight, but you'll have surface corrosion.
not sure about the cost, a couple bucks maybe? cheaper than buying shorter replacement arms.
