Paint removal for welding
#77
Really Old Senior Member
Maybe you should start a new thread before this one gets tedious-
Stycast 2850 removal for welding
#78
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
#80
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
The good news is that, from a quick look at it, it has most of what you need to get around as a single speed on it already.
If your wheels from the recently deceased bicycle that started this thread will fit it, you can convert the rear one to single speed, and it has a front brake that will probably work.
#81
Quoted: 18378 Post(s)
Liked 4,512 Times
Virtually all bicycle warranties for the last 20+ years only cover the original owner.
It is possible some of the old Schwinn warranties would have covered the bike under a second or third owner, except the company went bankrupt years ago.
#82
Habitual User
Quoted: 4957 Post(s)
Liked 8,098 Times
#84
Quoted: 3513 Post(s)
Liked 2,927 Times
#85
Habitual User
Liked 8,098 Times
#86
Habitual User
Liked 8,098 Times
Did you purchase the bike or frame new or used?
Likes For Eric F:
#87
Expired Member
Quoted: 3674 Post(s)
Liked 5,438 Times
Yeah, there's some overlap. The Huffy Genius also has a $5 Schwinn and posts mostly in General. The Schwinn Genius was posting in Mech but has threatened/promised to leave. Then there is the Huffy/Campy guy with a legit thread in C&V, not to be confused with the other two.
#88
Quoted: 967 Post(s)
Liked 1,631 Times
I don't know how you did this. Was it a fall, or a crash, or a jump? Is the frame still aligned? Can the crack be closed by manipulating the frame?
My fix would be to remove the crank and inspect the bottom bracket. If all was OK and aligned properly I would strip and burnish the area clean then "Alumaweld" a triangular 3mm thick 80mm x 80mm x 80mm aluminum wedge into the area and ride on.
#89
Liked 4,512 Times
However, I think the bike has had some kind of resin goop put in or around the bad area which only lasted a day, and would make it just that much harder to repair.
Likes For CliffordK:
#90
Habitual User
Liked 8,098 Times
Huffy/Campy guy will never be confused with the other guys. AMCO is in a different league, entirely.
#91
Quoted: 2700 Post(s)
Liked 486 Times
A light was turning red so I stood up and accelerated to beat the light, and I felt something funny and the bike started making a clicking noise when pedaling. Thought it was coming from the rear wheel at first. I don't know how much any previous crash contributed to it, it had been only ben ridden about 200 miles since the last crash and it had another more serious crash about 400 miles ago. So its seen recent abuse, but it was my fathers old bike and he is also a heavy strong guy who doesn't spin nice circles so the bike also experienced a lot of normal fatigue through the years.
my buddy from Bosnia says I should drill some holes to mount a bracket to fix it, similar to your idea. I think Ill never trust the frame again even if I fix it, bike is dead, but the parts on it are newish and fancy. Worth salvaging. Its semi-abandoned with a sign on it saying the frame is busted and not to ride it, I think im going to store it somewhere hidden away at work ("radiation tunnels" for a discontinued part of the accelerator) but I dont want someone finding it and hurting themselves on it in the future.
Likes For LarrySellerz:
#92
Liked 2,927 Times
#93
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Any person who is a master welder will refuse to even try to weld this. And any person that agrees to weld this is not a master welder.
And yet... it broke. There was enough stress to break the factory welded frame, which had the benefit of a post-weld heat treat. A repair weld will be weaker than the factory weld. What makes you think that its possible that the respair will hold?
It's not terrible? Based upon what? A stress analysis evaluating vector forces on the frame? Your gut feel?
Physics, and the strength of materials really, really, really doesn't care what you think. You can be happily riding on your flex-o-matic one second and paralyzed the next, from your head hitting pavement and breaking your neck.
Ah, so maybe he/she does have some competence. If warranted, transfer parts to a new warranty frame. If not warranted, buy a replacement frame and do the same thing.
I mean... I only have PhD in Engineering and am a registered professional engineer, so perhaps you gut feel is a better guide than the education, 40 years of professional experience, including 5 working in a bike shop.
I mean what was it that Matt Damon said about crypto? "Fortune favors the brave"!? Oh.. wait..
#94
Liked 486 Times
#95
Liked 2,927 Times
#96
Liked 341 Times
Kind of agree with smd4. If you are in an airplane, knowing that the left wing will fall off first is not operationally actionable. The seat tube is an integral part of a system (the diamond frame) and removing it adds stress to both joints (down and top tube) to the head tube. It also adds bending moment at the rear dropout. At any of these joints the failure mode can be catastrophic (as in your face being scraped away on the pavement).
It's an al frame, and welding it would be difficult (difficult geometry, "hot shortness" which is al welds are very brittle when hot and often crack, and a signficiant heat-affected zone size leading to premature failure). It's dead, man. Let that frame rest in peace.
#97
Liked 2,927 Times
#98
Quoted: 1279 Post(s)
Liked 1,393 Times
i was thinking of quitting BF because it had become so repetitive, but then this thread showed how even within repetition, new heights can be reached. faith in universe momentarily increased. what a gem.
Likes For mschwett:
#99
Quoted: 2485 Post(s)
Liked 2,956 Times
"Abandoned"---?
#100
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
