Let's talk waxing
#51
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
PTFE is one of the best-known and widely applied PFAS commonly described as persistent organic pollutants or "forever chemicals". Only since the start of the 21st century has the environmental impact and toxicity to human and mammalian life been studied in depth.
Seriously... it's Cancerous .. have you ever experienced Cancer? You probably will... from Teflon or any number of other nasty chemicals.
personally, I have skin cancer.... three types!
https://en.wikipedia.org/wiki/Polytetrafluoroethylene
The wax itself is much more likely to contain cancerous chemicals than the added Teflon and it isn’t likely to contain much.
Want some real fear mongering? Any number of the fluids used in an automobile has far more likelihood to cause cancer than PFAS will. Gasoline alone contains huge quantities of benzene as a percentage of weight which is a known carcinogen.
Stuart Black
Stuart Black
Likes For cyccommute:
#52
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
A bit too much fear mongering there. While some perflouroalkyl substances may be toxic, we don’t really know which ones nor how toxic they are. It’s a reasonably safe bet to say that polytetrafluorethylene (PTFE) isn’t. It is a very stable polymer that doesn’t react with much of anything. Being a “forever chemical” may sound scary but the “forever” part means that the chemical is highly stable and not prone to reactivity. Lack of reactivity means that it is less likely to cause cancer.
#53
Liked 4,222 Times
I know you won’t read this (or think you won’t) but PFAS is the latest of a string of SCARRRY words that the media grabs hold of. Remember BPA? Before that was Alar…when people sent the cops to keep their kids from eating apples. Lead. Dioxins. PCBs. And on and on. Yes, some of those are toxic. Yes, some of those cause problems. But as I pointed out above, there are lots of chemicals we use in millions to hundreds of millions of gallons per day that we just don’t even think about. 370 million gallons of gasoline…a known carcinogen…are used every day in the US and we don’t even bat an eye.
And your degree in chemistry is from where? No great loss.
Stuart Black
Stuart Black
#55
Bikes: 87 Bianchi X4, 95 Bianchi Ti Mega Tube, 06 Alan Carbon Cross X33, Gold plated Columbus AIR Guerciotti, 74 Galmozzi Super Competizione, 52 Bianchi Paris Roubaix.
Quoted: 259 Post(s)
Liked 540 Times
Today I noticed a broken spoke on the daily driver so I dusted off the X4, it's time I took it out for a spin.Just got back and you guessed it the chain went into the gas in preparation for w**ing tomorrow. It will be interesting to see how a 7sp syncro shifts that 1st 20 minutes into the first ride after the w**ing.
Chain as is cave man style.
Freewheel as is. I'm just going to run it as is and see if it cleans up over time.
The X4. As soon as I get the Galmozzi together the X4 got in for paint.
#56
Quoted: 4412 Post(s)
Liked 1,567 Times
#57
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
you know it seems like a lot of work.
I actually knew a guy who was badly burned in a chain waxing acccent, this was way back in the day.
silca has gone big on the waxing thing. I use their lube, and had good results with it
my cassette and chain are cleaner than that ! I rode this bike today
/markp
/markp
#58
Quoted: 259 Post(s)
Liked 540 Times
Post cave man clean.
21st century
Syncro worked great.
21st century
#59
Quoted: 259 Post(s)
Liked 540 Times
Today I waxed again.
335 miles since the last wax, 1500 miles total. I know the miles are nothing, but just recording for documentation.
Never cleaned the cassette prior to switch over.
Chain 335 miles since last wax pre clean.
Post clean. Poured a kettle of boiled water over it.
Waxed and ready to roll.
Next time I'll shoot for 400 miles as I didn't feel like the chain needed to be waxed, just did it.
#61
Liked 4,222 Times
Well that isn’t true. Neither are claims of tens of thousands of miles. Nor does wax need to be reapplied every 5 miles as some have implied.
Wax works about a well as oil in my experience. I use solvent wax but it’s similar enough to hot wax to not make any real difference. I’m currently running a long term test where I am keeping records of frequency of application and life of the chain. I’ve gone 450 miles between the first application and the next. The chain has 600 miles on it now…about half way to Zin’s claimed life of a waxed chain…and it isn’t showing any wear.
Even if wax did result in shorter chain life, I’d still use it. Having no need to constantly cleaning the drivetrain…or anything the drivetrain comes in contact with…is worth (purported) accelerated wear.
Stuart Black
Stuart Black
#62
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1949 Post(s)
Liked 1,474 Times
Mr. Zinn's 4th Ed. was published in Feb. 2013.
NEW! Zinn & the Art of Road Bike Maintenance 4th edition - Zinn Cycles - Custom Bikes | Boulder Colorado
That is 10.5 years ago. I don't know what wax lubricants was available then or which ones he was referring to. It is unclear from the posted text whether he was referring to immersion waxing.
#63
I gave up on wax because it doesn't hold up that well, especially in the wet. I cleaned my chains in an ultra sonic cleaner, and lubed them with a 4 to 1 mix of chain saw bar oil and unscented mineral spirits. Ride 800 miles and repeat. Holds up well in the wet.
#64
Liked 4,222 Times
Stuart Black
Stuart Black
#65
Keefusb
Bikes: 60cm 1992 Paramount, 60cm 1995 Cannondale R900 (son's bike), 1994 Cannondale H300 (mine), 1994 Cannondale H300 Killer V (wife's bike), 60 cm 1989 Eddy Merckx Corsa Extra SLX
Quoted: 83 Post(s)
Liked 57 Times
The process I have been following is to clean the chain in mineral spirits using the shaken jar method. Remove chain from jar and wipe with a cloth or rag. For hot waxing I have been experimenting with the addition of other lubricants to the melted wax. The best overall results I have had have been with the addition of a teaspoon of mineral oil (the kind you can get at the drug store for $5) to my 2 quart crock pot. There seems to be less flaking off of the wax and the drivetrain is quieter for the first few miles with the addition of the mineral oil. Once the wax cools, the wax "puck" is still solid enough to allow the bottom layer of crud to be scraped off before the next waxing cycle.
#66
Zinn has other strange ideas as well, like the whole proportional crank thing. Or rather the excessively way too long cranks for tall people. Short people definitely need shorter cranks but 175mm is more than long enough for pretty much anyone, unless you're Shaquille O'Neal. I'm 6'5" and I occasionally consider getting 170mm cranks.
#67
Liked 1,567 Times
Waxing is a really old technique that recent lab tests confirm offers excellent, lasting lubrication. Any modifications or additions to that formula are untested (solvent adding guys).
#68
Keefusb
Quoted: 83 Post(s)
Liked 57 Times
I would posit that the non-solvent additives listed above have been tested and that mineral oil yielded the best results.
Likes For Keefusb:
#69
Liked 1,567 Times
Another former chemist here. After experimenting with a number of non-solvent additives to plain old paraffin wax (such as motor oil, silicone, ATF, and castor oil to name a few), empirical evidence suggests that plain old mineral oil as an additive to paraffin wax enhances the properties of plain old paraffin (i.e. that mineral oil helps the liquified wax to penetrate into the inner structure of the chain, it helps to prevent excessive shedding of solid wax, and results in less noisy running and shifting performance) without compromising the positive properties of using paraffin wax (i.e. less attraction of road grit and dirt, less wear, longer chain and drivetrain life, and fewer chain and chainring tattoos).
Why did you decide that the wax shedding is a bad thing?
What does bad wax related shifting performance look like?
Don't you think the quieter chain is because you increased the viscosity and therefore decreased the efficiency? Grease would be even quieter.
#70
Liked 4,222 Times
a quantity expressing the magnitude of internal friction, as measured by the force per unit area resisting a flow in which parallel layers unit distance apart have unit speed relative to one another.
Stuart Black
Stuart Black
#71
Liked 1,567 Times
You don’t seem to understand viscosity. It’s defined as
You don't need to interrupt further.
#72
Keefusb
Quoted: 83 Post(s)
Liked 57 Times
I threw in some old segments of chain that had been trimmed off of some new chains when I was testing (many of these tests were done years ago). When I opened up these segments, the mineral oil mix appeared to put more material inside the links than plain wax. I used a 10x printer's loupe to look at the links.
I believe that the addition of the mineral oil reduced the viscosity of the wax just enough to improve flow into the inner surfaces of the links.
Excess wax shedding is a pain in the a$$ plus it can get on rim braking surfaces and contaminate the brake pads if you are running rim brakes.
I don't believe I characterized plain wax chain performance as "bad". The mineral oil mix was/is quieter than plain wax.
The other variable I didn't test was the wax. I use Gulf canning wax. Other brands or types of paraffin wax may perform differently. Some folks use a paraffin-beeswax mix with good results. I use Gulf because it is cheap and readily available.
The other reason I like mineral oil verses the other lubricant additives is that it is less toxic and can be safely consumed by humans in small amounts. Can't really say that about motor oil, ATF, and silicone. Castor oil is relatively non-toxic, but didn't seem to preform as well as mineral oil.
#73
Liked 1,567 Times
#74
Keefusb
Quoted: 83 Post(s)
Liked 57 Times
Yes, inside the pins and rollers.
#75
Liked 1,567 Times
I find this a bit surprising as liquid wax is so thin and has such a strong capillary tendency that it will climb a wick, yet you're saying that a hot chain in molten wax somehow resists the wax penetrating the roller and allowing the air to escape.
