Wheel questions
#51
Quoted: 1562 Post(s)
Liked 1,734 Times
It should be either 120mm or 126mm unless it was altered.
Likes For icemilkcoffee:
#52
Quoted: 682 Post(s)
Liked 453 Times
You seem to have a bit of experience with bikes so is there enough extra room in those horizontal dropouts to get a 700c wheel in and meet the brakes (you want a 5speed freewheel so clearly not a fixie) and not hit the seat tube?
#53
Speaking of mounts, does it have a rear derailleur mount? If not, you can use a "claw mount", either separate, or integral with the derailleur.
Oh, you may have said track *wheels*, not track frame.
Outer Locknut Distance (OLD), the inside width between the frame rear dropouts is everything. But if a common standard for wheels with rear freewheels or cassettes, you have a great choice of wheelsets available in 700c, way more than 27".
Knowing answers to the above, will help. I agree with asking questions online, we just need enough info. My wild-@ss guess on your (Original Poster, OP's) 10-speed being a 5-speed freewheel, was useful. Just not current terminology, but no worries. Usually, a LBS could answer your (OP's) questions in 60 seconds if you brought wheels and frame to them, but I totally get it if you are way far and a full tank of fuel round trip away from them. Conversations online also help remedy emotional isolation if that far from everything. We're here for ya. Just don't confuse questions we need to ask to convey solutions, versus snide remarks. A lot of folks get jaded or emotionally reckless online, and this can be emotionally cruel to someone like yourself (OP) that just needs help. I'd ask you to private message me, except that a) you may not have enough posts to allow that, and b) I'm not an authority on track frames and their OLD spacing and dropouts.
Kind thoughts. Consider the above, ask further.
Likes For Duragrouch:
#54
Quoted: 1109 Post(s)
Liked 1,200 Times
Bike jambalaya : I might suggest a clean re-set with an organized summary. People are talking past each other and not addressing or not understanding what you need.
1 Year and model of bike - not really necessary but might help
2 a photo of the current tires with the size displayed
3 a photo of the front and rear brakes to show if there's any additional vertical (up or down) adjustment that can be made
4 an accurate measurement of the rear dropout (not wheel axle) - inside to inside as illustrated above.
5 your weight
6 your expected riding pattern.
7 a photo of the current shifters and front and rear derailleurs
8 a photo of the current rear sprocket cluster
I think with this info, people will be able to easily give you pointers to actual wheels and sources.
And to make it really fresh and get past all of what's been going on here, post this question and the above info in the Classic and Vintage forum. The folks there are nice and helpful.
Good luck, I hope this thread settles down into constructive information for you.
5 your weight
Likes For Camilo:
#55
Maybe it is because you vaguely said so below?
If this is not the case why not just clearly state what size wheels you are looking for?
If your bike comes with 27" wheels, but you don't want to replace them with other 27" wheels, how will the brakes work? Or are you turning it into a track bike and thus don't need brakes? This is logic, not magic.
Vaguely literally means I did not say that.
I actually failed to clearly state that I was not looking for wheels
I want to say I failed at clearly stating that I had already found locally track wheels in a 36 and 32 spoke configuration
*that are of 700c size
I guess I should not have not thought to use "track wheels" as a nomenclature for a 622 or 700c wheel. My bad
#56
Yes it was no more than a 1/4 inch smaller than the hub spacing of 5 1/4 inches
#59
Senior member
Quoted: 943 Post(s)
Liked 658 Times
What everyone so far has failed to grasp is that track wheels usually do not have enough axle protrusion with the stock axle to accommodate a multi speed freewheel, even a five speed one.. if the hub is a cup and cone type (unlikely but possible) the axle could be swapped for a longer one and spacers added.
the more likely scenario is that it has cartridge bearings with a dedicated axle.
Likes For Dan Burkhart:
#60
Quoted: 332 Post(s)
Liked 742 Times
Honestly still confused about what’s actually being asked, but here’s perhaps a simple helpful answer:
NO, you do not want track wheels for your bike, unless you wish to convert it to single speed.
#61
Quoted: 332 Post(s)
Liked 742 Times
Likes For bboy314:
#62
Quoted: 682 Post(s)
Liked 453 Times
I think I get what he was saying
1. The term "vaguely" that was used, literally means it was not what he actually said (what he said was he acquired a bike with 27" wheels, not that he wanted to get some more 27" wheels)
2. He admits he didn't explicitly say he was looking for wheels, but that he wanted to know how / if he could get a track wheel to fit a 5speed freewheel on that frame.
3. He thinks he probably should have said the track wheels he'd found were not 27" but 700C and they had the number of spokes he thought could be beneficial
4. He thinks the focus on track wheels. because he'd found those, probably obscured his general interest in getting some 700C wheels and a wider initial question might have helped the conversation.
#63
Liked 1,734 Times
"No more than a 1/4 inch smaller than". OK. so it can be anywhere between 127mm to 133mm. Anyways, track wheels have 120mm hub spacing. So that one is a no go. Assuming you measured everything correctly I am going to guess that somebody somewhere along the line had set the frame spacing to 130mm. Luckily there are 100's of 130mm spaced 700c wheels on your local craigslist and in your local bike co-op . These are extremely common on the used market.
#66
Seems like starting threads with no knowledge of what the community needs or wants to know is ass backwards. So it's logical to me to ask everyone what they want to know before I ask anything.
#67
Liked 1,200 Times
That thread is pinnacle. My new method of started threads here. Pleading everyone ask all that they desire to know before. Before I put any effort into forming an actual question.
#68
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
Likes For SoSmellyAir:
#69
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,996 Times
Let's say I call BS
What information in fact did I not provide you. That can't do without. Must be enough to list a few or important enough to actually handicap you.
Please enlighten me on what information you did not have.
So that I can improve.
I don't live in the sticks I just hope that those words will act as a repellant for those who habitually suggest a lbs visit. *coughs like you
Camilo had some excellent questions as well you failed to answer.
So you are lying about the location of your bike shop? Why the need to lie? You are anonymous internet poster no need to lie like that. Just tell the truth. The reason we suggested you go to your local bicycle shop again is because you need help and they can help you. You are a bit combative online but being able to bring in the bike and show it to someone live will allow you the ability for someone to say "this is the wheel you need" from looking at your bike or "or here are some wheels that would work". It would make your life easier and prevent you from avoiding useful information even more and having to fight with everyone because they gave you good advice.
Likes For veganbikes:
#70
Quoted: 503 Post(s)
Liked 634 Times
The best jambalayas are the one where you just throw in what you got on hand, so....
If I understood correctly (no guarantee of that) I think I saw where "track wheels" meant 700c road wheels, but I'm punchy from all the nonsense to be sure...
#71
Quoted: 1944 Post(s)
Liked 2,164 Times
Unfortunately I think this is becoming just another internet exercise. Maybe a bit of chatbot with some tweaking.
If you look at the OP’s other threads, they all have a certain vagueness and they all lack any substance.
The OP has stated elsewhere, that he has been building bikes for years and is getting back to road bikes. No one who has that experience is not aware of what information is needed.
Just another typical winter on BF.
John
John
Likes For 70sSanO:
#73
Quoted: 3513 Post(s)
Liked 2,927 Times
Likes For smd4:
#74
Liked 2,927 Times
