Does Anyone Patch Tubes Anymore?
#76
I have been riding trails on my mountain bikes that are tubeless so I haven't patched or changed a tube in a long time. That said when riding with tubes I typically change the tube and patch later. Depending on the situation I may carry 1 tube or 2.
Also sometimes if the location of the puncture is obvious without taking the tire off I may sometimes leave the wheel on, break the bead on one side part way and pull out just enough of the tube to patch it with the wheel still on the bike. That can work out when there is an obvious thorn or other offending object that can be located and removed without removing the tire.
#77
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
I patch my tubes, and I patch a tube on the side of the road because I can usually do it as fast if not faster than swapping a tube out since about 75% of the time, I can patch the tube without taking the wheel of the bike.
Tires have come a long way even from just 15 years ago, in the last 15 years I've averaged no more than a flat a year, and my roads are pretty trashy, with potholes, glass, and metal wire bits from steel belted tires, The other odd thing to is that during that same 15 year period my tires are not getting cut up near as much as they use, sometimes I can wear out a tire and not a single cut will be found, and if I find a cut it's very minor, but I'll seal it with super glue just to be safe.
#78
New tubes off amazon are cheap and I don't get a flat often, and carry a spare. That said, I still use patches; Why? I ride a folder with panniers, with a claw-mount rear derailleur secured under the drive-side axle nut, so pulling the rear wheel off is a PITA, and the bike is hard to invert because the clip-on aero bars stick up. What I usually do on the rear is:
- shift to the low cog and chainring, and lay the bike down gently on the driveside.
- dismount the tire on the non-drive (left) side, and snake the tube out most places except at the valve stem.
- pump up the tube, look and listen for leak; Placing the tube in front of my lips will detect a leak that cannot be seen or heard.
- Clean and apply a PARK STICKY PATCH. Love'em, way easier than screwing around with glue.
- Put tube back on tire and remount tire, pump up.
What's referred to above as a REMA patch, I didn't recognize the name but did in the picture, yeah I bought that kit with my first good bike in 1989, I didn't have much luck with them sticking, but I may not have sanded and cleaned the tube of mold release, I was a noob back then. But I now carry the Park patches exclusively. In my experience, they work fine for months, but may eventually leak as they get flexed enough. I'm running 44mm at 50 psi, not terribly high.
You know what drastically reduced my number of flats? Save the old tubes, carefully cut off the valve stem (small hole), flatten tube and place between the new good tube and the inside of tire (note, these are not skinny road tires). So 3 layers of rubber between air and tire, instead of 1 layer. Not as tough as polyurethane anti-flat strips, but thicker, and zero cost, versus $15-20 for the strips.
Also, for 1.75" tires, if they sell tubes for 1.5-1.75", and 1.75-2.0", I buy the latter, less stretch when inflated, so rubber is thicker, and also less strained over tube life.
Back when I rode my road-race bike, I hated flats, and when on dirt-cheap winter sale at Nashbar, I bought kevlar-belted Specialized tires, never got a flat with them.
#79
And no, I don't ride sew-ups anymore. It's been at least 30 years since I've been on one.
#80
Quoted: 7351 Post(s)
Liked 2,477 Times
@Duragrouch, the most common mistake in patching is not letting the glue dry. Spread it wider than you need. When I patch at home, I sometimes forget to come back for a long time, and that works out fine. You can even wait hours, though you can't do that on the road.
I got a flat on Wednesday evening. It was dark, and I hit a pothole I didn't see. I hit it so hard that it made me shout, and the weight of my body pushed the handlebars and rotated them forward a bit. I changed the tube and will patch it later. It probably has a snakebite pattern of two holes. I hope to find that pothole and report it to the City.
New York State has had a mandatory deposit plus recycling law for a very long time, and it greatly reduces the amount of broken glass on streets and roads. States without such a law seem to have more glass. Nowadays most people don't get their bottle deposits back, but enough people are motivated to putting containers in recycling bins. And of course, some people make livings scavenging the containers. I'm not sure if they cash out the deposits or just get paid by recyclers.
#81
Liked 253 Times
It only takes 2 to 3 minutes for Rema glue to dry, the patch goes on when the glue turns to a matte like appearance, apply the patch and press hard for 30 seconds, and that patch will stick for the life of the tube. So yes, you can patch just fine on the road, it's been done that way for more than 50 years!
#82
Yeah, I think back in the day, I didn't let the glue dry, didn't realize it was like contact cement.
The other issue was the tube of glue going dry.
I may pick up a REMA kit.
#83
Liked 253 Times
They are most popular to use. I leave the thin plastic sheet on the patch, it doesn't hurt anything, but sometimes trying to pull off the plastic could lift the edge of the patch which might make it leak air.
Likes For rekmeyata:
#84
Liked 2,477 Times
I've had as many as eight patches on a tube. Some other folks have had as many as 30. Patching makes more sense than replacing a tube most of the time.
#85
The glue does tend to dry out after you open it. I periodically check to see if I have some left, and usually, the tube is unopened. I patch tubes in batches at home, so I have a big can of the glue to do that. Using that can means I rarely need to open the little tube that comes in the patch kit.
I've used a can of contact cement for auto tire plugs, dip it and push in wet, it acts as a lubricant, then drive slow and gentle for at least a few hours. Best if I can leave overnight and check if any leakage before cutting off excess plug, as I would use that to pull it out if it leaked.
#86
Liked 2,477 Times
No, you really should get Rema vulcanizing fluid. I tried rubber cement, and my first impression was that it was just as good, but then half of the patches came off. Vulcanizing fluid makes an interlocking bond at the molecular level, if I understand it correctly, which I probably don't. But it does work best, however it does so.
LINK
LINK
Likes For noglider:
#87
LINK
LINK
#88
Liked 253 Times
Thanks! That may also be great for auto tire plugs. I might buy some and keep in the car emergency plug kit, and use for bike tubes too. Probably keep a tiny jar of it on the bike. Would be good to know the solvent of it, so can add some if the glue in the jar thickens over time.
#89
(above) I don't like Slime as it can imbalance a tire. A real mess on bike tires too. I prefer a permanent plug. In recent years, tire places won't plug from the outside, I guess worried the plug will come out. They require pulling off the tire and applying a patch inside. But when a friend I was riding with had a slow leak (and at the time, my snap-on plug kit had been stolen from my car and I had not yet replaced), a tire place did that, only $15 (2018).
#90
Like I said somewhere above, I bought a can of Rema fluid and a box of 100 Rema patches. I kept the sandpaper from an old kit and a single edge blade and have been using this "kit" for years now. I keep a couple of tubes with me to match whatever tires are on whichever bike, and patch at home in batches. The fluid in the can doesn't dry out. I use the blade to slice the cellophane backing so I can pull from the center out and remove it. Give it a slice, bend it before removing the foil, and it'll come off easily.
#91
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 338 Times
Sorta but not well. There is a lot more chemistry involved then just slapping rubber cement on the tube and sticking stuff to that rubber cement. In this post, I linked to a technical note that discusses the chemistry in-depth…like Mariannas Trench in-depth deep.
You read the literature, do a bunch of experiments, and spend a lot of money to replicate the REMA TipTop system. Or you could just follow the Doneem hypothesis* and buy a REMA kit and be done with it.
#92
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
Don’t redo something if someone else has already done ‘em. See also “wheel, reinventing”.
Stuart Black
Stuart Black
Likes For cyccommute:
#93
Quoted: 839 Post(s)
Liked 1,064 Times
For anyone worrying about buying a can of REMA fluid and having it dry out. Store the can upside down which will let the fluid fill in any tiny leaks in the cap preventing evaporation.
Likes For Crankycrank:
#94
Liked 253 Times
#95
Quoted: 2604 Post(s)
Liked 1,933 Times
Great idea. Works for at least two or three years, IME. If you're using it in a coop or store, that may be long enough to get to the bottom of the can. OTOH if you're patching maybe a dozen tubes a year, plan to toss the goop after that and buy a new can.
#96
I've had my can for at least 5 years and it is still fine. I store it upright. Just make sure you tighten the lid.
#97
Liked 253 Times
I just buy small tubes of Rema Glue, I don't get that many flats in 5 years to use a huge o can of it, heck a can of that stuff would probably last me 20 years, but it would probably be no good by that time. Probably necessary though if you own a bike shop. I get the 4 tube package, the glue won't dry in the tube as long as the seal isn't punctured. I don't carry a spare tube of glue when I ride except on the touring bike, I carry one glueless patch instead, just in case I get a rude hello from a glue tube.
I do wonder about something, maybe one of you have tried it? Will Rema Glue work on a glueless patch?
#99
Liked 253 Times
#100
Quoted: 502 Post(s)
Liked 436 Times
