Different mount for Cat Eye Rapid Mini Rear Light
Quoted: 104 Post(s)
Liked 5 Times
Cateye also sells mounts for their lights: https://www.amazon.com/dp/B009YM2KLW
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Quoted: 573 Post(s)
Liked 118 Times
Since the question is very close…
Do all Cat Eye lights use the same bracket, or at least the Omni lights?
I'm going to order an Omni 3 set of front/tail lights, along with a couple of extra mounts so that I can use the lights on my two bikes.
Thank you.
Thank you.
Quoted: 523 Post(s)
Liked 229 Times
If you buy a light that specifies it will run this many hours on two alkaline AAA batteries, don't expect it to be very bright.
Runtime:Approx 100hrs in constant, 150hrs in flashing, and 200hrs in rapid mode
The output in lumens seems to be a deep, dark secret. It is not mentioned on any of the sites that sell the light. If you take a quick look at reviews, one problem that seems to pop up often is the light is not very robust so has a tendency to come apart with the lens falling off. Doesn't seem like much of an improvement over dollar store lights. Before I learned about better lights I used them. Plenty bright but also tended to come apart.
Likes For angerdan:
no1mad
14
10-26-12 01:32 AM
EsoxLucius
1
09-03-10 09:01 AM
