Can a Garmin user answer this question?
Quoted: 6934 Post(s)
Liked 10,938 Times
Thanks for all of the input, everyone.
Thanks especially to Marcus Ti for the new acronym: IDGAF. It took me about .3 seconds to figure that one out.
Regarding the Edge Explore: I am looking for something a bit more full-featured, and do want a computer that will connect to my Di2 drivetrain. But it is an interesting option.
Quoted: 4242 Post(s)
Liked 1,343 Times
GRouteLoader doesn’t list the routes.
The routes in RWGPS are given a unique number.
You can enter that number into GRouteLoader to download the route.
It can be the number of any public route.
I would have thought you had to save the route to make it recent.
Pinning the route seems more appropriate.
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 238 Times
I have not noticed that on mine; I run GPS and galileo together. Isn't it a setting for blacklight in map? If it's disable, the screen light all the time whereas in field mode, it goes to blacklight.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
For a non-touchscreen fitness/bike computer...$380 is a very hard sell in 2019. Said another way--For $400USD on Amazon you can get a flagship-tier Xiaomi/Huawei Android smartphone that is full featured for that money, that does everything a smartphone does. BTW-Garmins are on BestBuys pre-black-friday sale, specifically the Fenix 5X watch is presently $300 even (about 40% off).
Quoted: 18883 Post(s)
Liked 10,646 Times
Fenix 5X is a great watch (with routable maps and navigation) but it's the previous generation, which means it should be on permasale.
I do agree $380 is a lot for a bike computer.
Quoted: 3221 Post(s)
Liked 2,043 Times
GRouteLoader does not list any route names in the RWGPS route list, thus you have to look up a route number prior to using the app. That's unfortunate and less then useful (IMO).
I had thought the RWGPS route list got re-ordered when you opened a route, that's not the case, so Pinning a route is likely the easiest way to keep a limited set of routes ready for download and viewable in the RWGPS iW app.
Liked 1,343 Times
It’s much easier and faster to use the phone to look up routes. Looking up routes on the device would be rather awful.
Note that the RWGPS app doesn’t let you do that either.
Liked 2,043 Times
The RWGPS website shows a list of routes a user would have created. The RWGPS iQ app shows part of that list, the most recent, or you can select pinned routes, but you can at least see the name of the routes you’ve created from within the app.
Liked 1,343 Times
The RWGPS app doesn't show the user's routes.
It shows a very limited part of the list.
You can pin any route (not just your own).
But no one is really going to want to search for routes on the Garmin.
If you have the number, using GRouteLoader is fairly convenient.
But pinning the route is going to be much more convenient.
Quoted: 188 Post(s)
Curiosity question... Is it possible to use either the Garmin's or other GPS' without passing along any ride information with the company during updates? I'd like to track my ride information but don't really want anyone or any company to have access to my information. A colleague uses a Garmin watch and it sounds like he has to sync his watch with Garmin to perform updates.
Liked 2,043 Times
Liked 1,343 Times
It's routine that your activities are uploaded to the Garmin Connect website but that should be opt-in to and something you can opt-out of
Garmin Express will do the upload of activities when you plug your device into your computer. But Garmin Express gives you the option to opt-out of uploading activities (it's a setting for the device).
It's not that hard to do the updates manually (avoiding Express entirely). Though, you might need Express for updating maps.
That is, I'd trust Garmin (at the moment) to do the right thing but you'd still have to take care (since the default is to upload data).
Liked 10,646 Times
Garmin used to let you opt out of sending the ride data to their server but they've changed this recently.
Liked 1,343 Times
You can turn off auto upload in Garmin Connect Mobile.
You can turn off auto upload in Garmin Express.
(This is the case for the Edges. The watches should be the same.)
These options might be mandated by GRDP.
I agree with this but I'm not sure I'd go for the ROAM. Got panned in a lot of a reviews. ELEMNT or BOLT probably a better choice.
Liked 10,646 Times
I'm looking at it right now in Garmin Connect Mobile. The option for auto upload activities is disabled (grayed out). It isn't possible to turn it off. Go check yours.
I can't speak to Express, I haven't used it in years, I'm surprised anyone with a modern device does.
Quoted: 550 Post(s)
Liked 325 Times
Liked 1,343 Times
Being grayed-out suggests there should be something that would enable it.
Not pairing the device to your phone is another way to prevent it.
I plug my device into my computer fairly regularly. So, using Express is reasonable in that case. Having Express also means having a smartphone isn't required (which is going to be useful for some people). Though, the modern devices also can use WiFi.
Liked 2,043 Times
Having been burned with OTA system updates on other systems - iPhone, Di2, I only do updates via a cabled connector. Express works just fine for that and I’ve never had an issue. It’s the only time I plug my devices into a computer.
Liked 10,646 Times
I charge mine with whatever is the most convenient USB outlet, often in the car. Sometimes that's the computer, but not often enough to require it on a workflow. And OTA syncing works so well now!
Liked 10,646 Times
I did check it (that's why I was surprised). The "Auto Upload" slider works. Maybe, it's not enabled for watches.
I checked Express too. Do the maps get updated through Connect Mobile?
I can't fathom why this would be different for watches and cyclocomputers?
I don't know if the maps will update over BT or not but they will over wifi.
And you're right that not pairing your phone will prevent sending them your data, to the OP's question. Personally, I trust Garmin for the time being, and pairing provides too much value to not do.
Liked 10,646 Times
Liked 1,343 Times
You're right that being disabled is a weird choice of it just can't be done; it would make more sense to just not show the control at all. I don't know what would enable it? I read, I think on Rainmaker, that they had disabled the option, and the app confirmed it in my case.
It is odd. It should be an option for every device.
