Internal cable routing help - please
Old 10-31-15, 01:04 PM
flyfisherbob
Bikes: Trek Domane 4.5, Kona Jake, Centurion LeMans RS
Hi all,
The Scapin project is coming along, and I ran into a snag. The rear brake cable and housing run through the top tube. I ran the new cable through the old housing, then pulled the housing off the new cable. Now, I can't get the new housing to run back through the frame. It is hitting somewhere at the exit port, but I can't get it to thread the final bit through.
Any tips?
Bob
flyfisherbob is offline
Old 10-31-15, 01:20 PM
iab
iab's Avatar
Quoted: 1752 Post(s)
Liked 542 Times in 290 Posts
Did you try reversing insertion direction? (That's what she said.)
You may need to sacrifice your cable to go the other way. (Not that there is anything wrong with that.)
iab is offline
Old 10-31-15, 01:31 PM
Scooper
Decrepit Member
Scooper's Avatar
Bikes: Waterford 953 RS-22, several Paramounts
Quoted: 617 Post(s)
Liked 25 Times in 23 Posts
Did you try shaving a chamfer in the end of the housing that's hanging up at the exit transition?
- Stan
my bikes
Science doesn't care what you believe.
Scooper is offline
Old 10-31-15, 01:35 PM
jiangshi
Quoted: 348 Post(s)
Liked 79 Times in 50 Posts
smaller housing?
jiangshi is offline
Old 10-31-15, 02:01 PM
ramzilla
ramzilla's Avatar
Quoted: 573 Post(s)
Liked 164 Times in 137 Posts
Vaseline & patience
ramzilla is offline
Old 10-31-15, 07:33 PM
thumpism
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 1701 Post(s)
Liked 415 Times in 295 Posts
You might need a helper. Get yourself a sharpened spoke or other needlelike tool and position yourself at the outlet end of the frame tube with the helper feeding the bare housing slowly from the other end. Shine a light and look for the approaching housing end. When it appears use your tool to insert into that end, then have the helper feed more as you guide it out. You can then feed the cable through the housing.
thumpism is offline
Old 11-01-15, 06:10 AM
RobbieTunes
Half drunk? Finish!
RobbieTunes's Avatar
Quoted: 378 Post(s)
Liked 899 Times in 572 Posts
Originally Posted by ramzilla View Post
Vaseline & patience
it's old, well-ridden; shouldn't need it
just keep moving it around....
I need to stop.
I have unfinished business.
RobbieTunes is offline
Old 11-01-15, 10:56 AM
flyfisherbob
I need to stop.
Well, that seemed to have been the solution (sans the vaseline). I'll stop as well. Thanks for the assist, and the entertainment. I should be finished today, just a good final cleaning and hopefully a test ride. Pics when done.
Old 11-01-15, 12:33 PM
Scooper
Decrepit Member
Scooper's Avatar
Quoted: 617 Post(s)
I don't know how the Scapin internal cable routing is implemented, but most custom builders have a stainless steel or brass tube inside the top tube and brazed at both ends. There is a smooth cable exit transition at each end and the internal tube prevents water from getting inside the top tube. This is how Darrell McCulloch (Llewellyn Custom Bicycles) does it.
- Stan
my bikes
Scooper is offline
Epicus07
Classic & Vintage
3
08-15-11 06:52 PM
Frankinbiker
Commuting
21
06-10-11 03:28 PM
highhung723
Bicycle Mechanics
5
05-01-11 11:03 PM
JG6663
Bicycle Mechanics
3
08-06-10 05:30 PM
viet_Cong
Bicycle Mechanics
10
04-08-10 05:55 PM
