World Tour: Tubeless Tires?
(1) Just bought a Giant Gravel bike (Revolt 2). Will fly to Japan for 3 mo then China. Plan to bike all of mainland Asia. Should I remove the Tubeless tires and use a regular tire w/a Tube?
(2) I want to be bikepacking but it seems the only way I can carry a MacAir laptop is via a bike rack. True?
Thanks.
Pali
Thanks.
Pali
check dimensions of laptop and bike triangle.
consider custom made frame bag.....waterproof and heavily padded inside, with carbon-fiber (or just plain old plastic) side panels for protection.
I would go tubeless but bring spare tubes. Keep the sealant fresh, and hopefully you won't need the tubes, but if you do need them, you have them, and you can convert to a tube set-up when necessary.
No idea how to carry a laptop on a bikepacking set up. My iPad sits in my handlebar bag, but that likely won't work for a laptop. Backpack would work, but I'd rather use a rear rack than a backpack.
Likes For Rob_E:
Quoted: 18413 Post(s)
Liked 15,536 Times
Don't know if this is the case with wider tires, but one issue with some road tubeless tires is that they don't play nice with tubes. This spring I had a puncture that would not seal due to me being remiss in not adding fresh sealant. I had to limp back to the car because I could not get the tire (25c) to seat properly with a tube in it. Despite trying three times, it kept bulging at the valve stem hole. I would at least test fit a tube in your tire before embarking.
Quoted: 3459 Post(s)
Liked 1,465 Times
Some air security personnel will deflate your tires if they inspect the bike. There are rules against compressed gasses on passenger aircraft and some security personnel think that a pumped up tire holds compressed gas, which a strict reading of the rules is correct. Would deflated tires with sealant in them be a problem?
You can't carry compressed gasses on a plane, the people that I know that have used tubeless carry CO2 cylinders. If you need CO2 cylinders, you might have to resupply after every flight. Is this a major hassle?
I have never used tubeless, maybe my comments are not pertinent?
Once a tire is aired up and seated on a tubeless rim, letting most of the air pressure out shouldn't be a problem. I've run multiple non tubeless specific tires on a tubeless rim and had no problem with low pressure once it was seated. I deflated my tires almost entirely to fit my bike into a box once and the tires didn't unseat during the flight. I would not, however, use non tubeless rims. Tires don't seat on them, and you will lose your seal/sealant. That would be a mess and a PITA.
As for the road tires, I haven't used them personally, but from what I've read, they seem to be a different thing to deal with all together compared to higher volume mtb type tires.
Personally, I'd run tubeless and bring a couple spare tubes as suggested above. Chances are you'll save yourself from getting any flats. Worst case, you get a flat and put in a fresh tube as you would do anyway. My one caveat being that this applies strictly to Stan's sealant. I've done a lot of reading on the subject. Stan's seems to be the way to go. I tried it and it works great for me, so that's what I stick with.
Non omnino gravis
If the OP is using the OEM 700x40 Giant Crosscut tires, there should be absolutely no issues with poor sealing or fitting an emergency tube. Even at a +200lb rider weight, pressures would be in the 40-50psi area.
The Revolts all appear to have a decently sloped top tube, so I cannot see a laptop fitting inside the triangle. It's rear rack or backpack.
Liked 1,465 Times
I've heard of people using that specifically because initial set-up is easiest with a fast burst of air, but I've heard that it can interfere with the sealant, so an air compressor is preferred. But the need for that burst of air is generally a one-time thing. Once the tire is seated on the rim, you can deflate it and reinflate it with a normal pump.
Quoted: 273 Post(s)
Liked 487 Times
Thanks.
Pali
Thanks.
Pali
WORLD tour and you don't know what tires to use? ))
