Reducer headsets
Reppin' the hacks
Bikes: '07 Diamondback Respones XE-based frankenbike (since deceased). '92 Schwinn Hurricane. '97 Trek 800.
Reducer headsets
I need to go from 1.5" to 1 1/8", torn between a few options. Should I run the "problem solver" spacers and a 1 1/8" headset, or a reducer headset (leaning toward Crank Bros Opium C)? Or is a reducer headset essentially the same thing as option 1 (doesnt look like it...)?
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times
I use both and both solutions work well. I prefer a reducer headset, though. The extra room gives the designers the ability to use larger bearings to take the load and the leeway to design a headset with almost no stack height.
Headset reducers are fine, though, especially if you already have the 1 1/8" headset on hand and wish to make use of it. The reducers insert as far as a deep-insertion headset, usually, so there is no danger of ovalizing a headtube just because you run an adapter. And if you want a bit of extra insurance, you can press a deep-insertion headset into the reducer.
If you want a super-beefy reducer heaset, check out the Syncros FBI. Yeah, it's a bit heavier than most; but that's a real Timken tapered roller bearing in the bottom end of that sucker.
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
Bikes: Fondriest Status w/Campy, Schwinn Moab 2 Aluminum Mountain
I run a Cane Creek reducer headset on my Cannondale- originally it had a HeadShok, now has a Manitou. It works great. I have the reducer rings from problem solvers, but thought the reducer headset was a better option.
