Internal gear hub, Kindernay?
Old 10-27-19, 11:16 PM
chrisx
chrisx's Avatar
Quoted: 406 Post(s)
Liked 9 Times in 9 Posts
https://kindernay.com/products/
Let me guess,
No has has tried this system?
Sure looks good on papèr.
chrisx is offline
Old 10-28-19, 09:55 AM
Tourist in MSN
Quoted: 3461 Post(s)
Liked 1,467 Times in 1,144 Posts
Sounds like they replicated a Rohloff with slightly wider gearing intervals and through axle. Not interested.
Rohloff hubs have been around for a bit over 20 years, that is long enough that I expect they will be around later if mine needs service.
Tourist in MSN is online now
Old 10-28-19, 02:34 PM
tspoon
Bikes: 1990 Paul Dye Hand Built 7 Speed, 1965 Raleigh Sport, Folding 26" Tourer
Quoted: 63 Post(s)
Liked 43 Times in 15 Posts
I like the part about easily separating the hub and spoke carrier, if only 'normal' drivetrain hubs with gear clusters had that feature, no problems changing a spoke then.
edit: makes it nice and easy to take out for oil changes, or to remove and ship for service supposing that was needed.
tspoon is offline
Old 10-28-19, 02:42 PM
Marcus_Ti
FLIR Kitten to 0.05C
Marcus_Ti's Avatar
Quoted: 2349 Post(s)
Liked 406 Times in 254 Posts
Proprietary hydraulic shifting....was liking until that bit.
Marcus_Ti is offline
Old 10-28-19, 02:59 PM
chrisx
chrisx's Avatar
Quoted: 406 Post(s)
Originally Posted by tspoon
I like the part about easily separating the hub and spoke carrier, .
Main attraction. Multiple rims 1 hub.
?¿? affraid of a leak?
chrisx is offline
Old 10-28-19, 03:09 PM
Marcus_Ti
Marcus_Ti's Avatar
Not afraid of leak...so much as it doesn't work with standard shifters anywhere. At least with Shimano or SRAM brifters you can generally get service at any old LBS in the USA at least.
Old 10-30-19, 10:04 PM
veganbikes
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times in 2,666 Posts
I like the idea of thru-axle but would still rather have a good ole reliable Rohloff. It is a well proven system that has been around a long time and probably will be around for a lot longer. I will say it is a neat hub and one I would love to try but I want to see it belt compatible and electronically shifted.
However I would rather just see Rohloff go thru-axle and go to a Center lock or at least 6 bolt design. Those are really my only major gripes I could have. Sure lighter weight is nice and this and that but really if you could just allow thru-axle and standard rotors that would be more than fine.
veganbikes is offline
Old 01-12-23, 01:23 AM
hkckoo
Quoted: 13 Post(s)
the idea of interchangeable parts where with one hub you can use it on three different frames and also multiple wheels, you just need to swap a shell that houses the hub, is excellent. but the proprietary shifting worries me too.
hkckoo is offline
