Micro tracking device - does it exist?
I couldn’t find an effective “micro” tracking device for a bike (in case of theft) and I am wondering whether such thing really exists at this moment on the market. Necessary features should be:
- Minimum size and weight (to easily hide it)
- “Sleep” mode with very low consumption and long battery life
- Send GPS location via SIM at request, e.g.: when sms is send to sim number. Location Coordinates could then be identified on google maps with the mobile phone or PC.
That would be all. Led lights, voice recording, memory card, alarm sound, etc - all are useless and only increase size/weight and reduce battery life.
Did anybody see such device on the market?
Quoted: 314 Post(s)
Liked 683 Times
The closest (but not exact) match for that might be an Apple AirTag. I've got a couple of these. Not much use if you don't have an iPhone though.
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
Sounds like a very difficult design problem.
Low battery usage, but it's always connected to the cell system and listening for a text message? How would that work.
Transmitting from within an aluminum or steel frame tube -- would the signal get out?
I've seen reports of cyclists tracking down their stolen bike that had an Air Tag on it. They knew it was inside a building, but the cops wouldn't do anything about it. Others have recovered their own bike, with the help of some large friends.
So far, the thieves aren't smart enough to have apps to check for Air Tag, Samsung Tags, and the other ones. The app would tell them they are being "stalked" since the tag would stay nearby them.
Rider. Wanderer. Creator.
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 394 Post(s)
Liked 781 Times
My Tiles last for months and months without having to change the battery. The smallest ones are small enough to slip into a small saddlebag. You might be able to hide one in the seat tube - you'd need a way to retrieve it though, i.e., fishing line attached to the seat post. But I'm not sure if they'd be able to pick up a wifi signal through a steel or aluminum tube. Not sure about carbon fiber.
https://www.youtube.com/watch?v=vjLbxywixro
I would say only being activated by a predefined standard sms. I was thinking about a carbon bike, as this is more and more the norm nowadays.
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 3,999 Times
Stuff designed for purely misplaced items is not ideal for stolen goods. I think a lot of companies are just jumping onto trends without thinking about it.
This is one I saw a few years ago and it seems like it is viable as it has stuck around: https://www.viasatonline.it/en/products/sherlock-2-0/
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,472 Times
What to do if you get an alert that an AirTag, Find My network accessory, or set of AirPods is with you - Apple Support
Quoted: 4260 Post(s)
Liked 1,364 Times
Liked 1,472 Times
Liked 1,364 Times
These things don’t mean it is going to be useful generally.
https://www.makeuseof.com/airtag-vs-tile/
https://en.wikipedia.org/wiki/AirTag
Tile network: 35 million.
AirTag network: 1000 million.
The Tile network is never going to get that big and it might not get much bigger than it already is. It might even get smaller.
(Some of the Tile models have much longer range than the AirTags.)
There’s some indication that Google is planning an AirTag clone.
https://arstechnica.com/gadgets/2023...ndroid-phones/
Quoted: 394 Post(s)
Liked 781 Times
This doesn’t really contradict what I said.
Liked 1,364 Times
People are going to assume it's suggesting that Tile would be useful as a theft-tracker. Tile might be useful but its network is going to be too small for theft-tracking (the Apple network might not really be large enough).
Liked 1,472 Times
Liked 1,364 Times
The problem with the Apple network is not whether it is large enough. An iOS device (and maybe also a MacBook) would warn its user if it is being tracked by an AirTag whose owner is not also in the proximity of the AirTag, and allow the user to disable the AirTag. (See the link in my post #8 above.) Good for privacy, bad for theft recovery.
I suspect the time available for tracking something that is stolen is short anyway. The AirTag warning isn't immediate. So, it might be long enough.
There's a relatively-simple way of disabling the noise maker in the AirTag.
The Tile network is likely small enough that it warning people doesn't matter.
Likes For njkayaker:
Quoted: 394 Post(s)
Liked 781 Times
It's a confusing anecdote. Your tile in the Philippines? ???
I don't think people will be misled. I recognized that the Tile network is smaller by quoting your post. And I wrote, "Coincidentally" which is just that, a coincidence. Not an endorsement or refutation. A coincidence.
Whether or not the Tile of Airtag will work due to network size or the privacy issues with the Airtags that SoSmellyAir brought up, the answer is...it depends. Neither will be as good as the OP wishes, but they won't be entirely useless either, as there's a chance that they can relay the last known location from time to time and narrow any search efforts.
OP, for reference, I sometimes travel with a Spot tracker. It's about the size of a deck of cards and pings its location off of satellites, so it's not dependent upon limited cell, wifi, or nearby bluetooth devices. As long as it can see the sky, it can report it's position. Garmin has a competing product that's maybe half the size. That's basically where we are in terms of the size of consumer location devices that can work in remote areas.
Liked 1,364 Times
It's probably much more worth while taking efforts to avoid the bike being stolen in the first place.
Liked 2,979 Times
android = cube pro
-Oh Hey!
-Oh Hey!
Tile network is too small for it too work effectively. I have one in my car, parked on a city street. Rarely registers a hit.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
This device hides in your handlebars, tracks GPS location, and reports its location via cellular network:
I used one for a couple of years, until the cellular contract ran out. It worked.
Now I just us an Apple Tag.
Likes For terrymorse:
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
The air tag is going to take some time before it notifies the thief they’re being tracked. ( it was 8-24 hours, although Apple said some time ago they planned to shorten the time.)The thief also has to have an IPhone, and have find my turned on. So while less than ideal for theft recovery, there’s a decent chance you’ll get a lead before the air tag is disabled. Also, if I were a thief, and figured out I’d been tracked, I’d be ditching the bike ASAP.
You could get lost and die.
You could hit a tree and die.
