Rim Tape?
Rim Tape?
Living in South Africa for the past few years. Last year I bought a Trek 7300 with two wheelsets. The narrower tires didn't hold pressure well, so I swapped out the the set with 32mm tires.
I then stripped the tires off the narrow wheelset, and hard pieces of rim liner fell out. I guess this is what had caused the previous issues.
Rim tape at the local bike shop is only available in bigger (more expensive rolls), else they will charge to retape.
I am moving to a smaller country town where access to well-stocked cycle shops is slightly more problematic. What would make a 'reasonable' (not perfect) and cost effective substitute? I have taped the rim with electrical tape for now, but suspect I may need at least 2 layers. The other alternative is maybe cloth wiring / electrical tape, which should be available in the hardware store.
Or am I being naive and have to go online and pay shipping charges (and wait) for the 'real thing'?
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 121 Post(s)
Liked 212 Times
Shipping/strapping filament tape works just fine and comes in various widths. Here's a 3M page which gives you an idea of what may be available in your country. I've had it on a set of rims for years and it just works.
https://www.3m.com/3M/en_US/p/c/tapes/filament/
Likes For Garthr:
Quoted: 18421 Post(s)
Liked 4,537 Times
I've tried cloth electrical tape, but I think it often is sticky on both sides and makes a bit of a mess.
Do you have single walled or double walled rims? The tape requirements may be different for the two, as the single walled rims just needs one to cover the nipples, and the double walled rims need support over the holes.
Cloth handlebar tape may also substitute for rim tape, but probably isn't any cheaper than the rim tape.
With newer tighter fitting tires/rims, I've pretty much given up on the cloth tapes, and started getting plastic rim tapes. Usually ordering a few from overseas bike shops.
I have intended to experiment with various heavy duty tapes, like packing tape, but ultimately it wasn't needed.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3913 Post(s)
Liked 6,526 Times
Likes For SurferRosa:
Bikes: old ones
Quoted: 26463 Post(s)
Liked 10,420 Times
I usually use a couple of full wraps of Kapton tape. It's tough, so use something like an ice pick to punch the valve stem hole.
Likes For 3alarmer:
señor miembro
Liked 6,526 Times
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1300 Post(s)
Liked 742 Times
Quoted: 5874 Post(s)
Liked 2,722 Times
My old standby is cloth surgical (first aid) tape. Though the cloth version is getting scarcer as plastic is taking over, it's still available at most retail drug stores. A roll is cheap enough, and any left over can be kept and used with your other first aid supplies, so no waste.
FB
Chain-L site
FB
Chain-L site
Quoted: 519 Post(s)
Liked 453 Times
Gorilla Tape, if you can get it. Also, the cheap rubber rim strips most shops sell for about a dollar work fine as long as your pressures are below 80 psi (5.3 atm).
Sr Member on Sr bikes
+1 on the Kapton tape.
Dan
Dan
Likes For _ForceD_:
Quoted: 1088 Post(s)
Liked 701 Times
I wouldn't ride with electrical tape in there for very long. Even with two layers, it's still going to move around and create a sticky mess. I've done it in an emergency (two layers) but replaced it as soon as I could.
If you have to order something, why not just go with Velox? You're not going to find anything better - it lasts forever and doesn't move. Plus it's available in a number of different widths.
Likes For Jeff Neese:
Keefusb
Bikes: 60cm 1992 Paramount, 60cm 1995 Cannondale R900 (son's bike), 1994 Cannondale H300 (mine), 1994 Cannondale H300 Killer V (wife's bike), 60 cm 1989 Eddy Merckx Corsa Extra SLX
Quoted: 83 Post(s)
Liked 58 Times
Velox or Pedro's rim tape would be my first choice. In a pinch, fiber-reinforced packing tape, or cloth first aid tape will work, but I have found that the first aid tape leaves a sticky mess like electrical tape. You can order Velox or Pedro's rim tape from most reputable online bike parts sources or Amazon. REI retail brick and mortar stores usually carry them as well.
I'm looking for an alternative to Velox which isn't working for me though it has worked fine on other rims for years. I need tape that sits in the "well" of this rim so it doesn't interfere with with the tire seating properly. The rim is H Plus Son Hydra. I had a bike that had yellow "shiny" tape that was wrapped twice around the rim but don't know what it was. Any ideas for tape that won't slip or what that yellow rim tape might have been?
Liked 3,032 Times
are plugging the holes prior to applying the tape?
-Oh Hey!
-Oh Hey!
Likes For Troul:
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 679 Post(s)
Liked 753 Times
Spoke holes can be plugged with Veloplugs in lieu of tape. I just tried them for the first time last month and they seem to be fine, but they do add diameter making tires harder to mount. That's the main reason I normally use Stans or Kapton.
Likes For andrewclaus:
Likes For easyupbug:
Quoted: 854 Post(s)
Liked 1,085 Times
Likes For Crankycrank:
Liked 3,032 Times
if leaking with just one of the options stills occurs, try dabbing the plugs in an anaerobic sealant & using tubeless specific rim tape that crowds the least of the inner rim area.
-Oh Hey!
-Oh Hey!
Quoted: 3565 Post(s)
Liked 2,982 Times
Why anyone would use anything other than Velox is beyond me.
Liked 2,982 Times
