Is my shifter repairable? Pic inside
Liked 10 Times
Hey guy, had a crash on Thursday and my left side Dura Ace 9170 shifter is not shifting. Brake works fine. My mechanic opened up the shifter and noticed
cable was severed. He told me that it was not repairable. Just getting second opinion here.
Quoted: 564 Post(s)
Liked 422 Times
You don't trust your personal mechanic?
You think he is lying/stealing, and you want strangers with unproven experience to override what he thinks is best for you?
My opinion is that I would agree with my own mechanic.
Way back when I had a customer pay one of his employees to fix a broken wire on the cadence sensor mounted to his tandem. Each strand had to be soldered together. Not sure why, however it took the guy over an hour to do it. The point is, anything can be repaired provided time and skill level are available. Now, is it worth paying shop rate to have someone tear down that wire harness in the shifter to fix it? Likely no.
Clark W. Griswold
Quoted: 4432 Post(s)
Liked 4,076 Times
It might be repairable I have never had to do so or been inside one but maybe some tech kid could figure it out with some time and money however if the shifter is a newer shifter you might reach out to Shimano and see what they say. Dura-Ace components have a 2 year warranty and while this was a crash and generally may not qualify but is worth at least asking.
I would kind of agree with soyabean to a degree you should trust your mechanic as that would be a pretty high level repair and most shops probably wouldn't get involved.
SE Wis
Quoted: 2751 Post(s)
Liked 3,409 Times
I personally would try fixing it because (A) I'm cheap (B) Challenge, fully knowing I'll likely 99/100 need a new one.
Probably after I already had a new one on the way for use as a "spare"
I've repaired wires in tighter spots
A shop knows that time spent on a possibly unsuccessful effort still needs to be paid and possible comebacks so they will always be "replace". That's business
Likes For dedhed:
Quoted: 6269 Post(s)
Liked 4,863 Times
The other half of that lug ear below the red arrow that a pin goes through is in the top piece above the red arrow. It's broke.
Shimano doesn't make them to be fully serviceable with replacement parts AFAIK. You'd need at minimum a new shifter body too.
Quoted: 564 Post(s)
Liked 422 Times
Seriously, if I had a crash like that, I'd be more concerned if I had any buised bones and get better tyres so this doesn't happen again. Throwing money on a repair so I can continue cycling is as trivial as breathing.
Cycling is an expensive sport. I don't whine when I can't afford that S-works for $18G.
I'm starting to see how the BSO makes sense. For some folks it's all they can afford.
Quoted: 374 Post(s)
Liked 848 Times
Likes For bboy314:
Quoted: 381 Post(s)
Liked 284 Times
Part of the skill of repairing stuff is deciding what to spend your time on.
Quoted: 530 Post(s)
Liked 474 Times
The cable is probably repairable, I'd try if it was mine but I wouldn't offer to do it for a customer because it would be time consuming and not guaranteed, and isn't the lever broken anyway?
Likes For grumpus:
ScottCommutes, I have been in some very poor places on this earth and I can assure you a slashed tire can indeed be repaired. I have seen it on autos and motorcycles, and probably didn't notice it on a bicycle or two.
Likes For TiHabanero:
Quoted: 564 Post(s)
Liked 422 Times
Yup, I was using marathons on my train station bike that was only a mile each way, so any failure I would just walk it.
Been like this for years
There were holes tears in the ply, held together with strapping tape.
What's a good tape to use inside the ply that grab onto the tyre so it don't expand on inflate?
