Hydraulic Disk brake piston not fully retracting
Hi All,
One side of my front disc brake piston doesn't fully retract, so that my brake is rubbing slightly. I made the mistake of pulling the brake lever whilst the front wheel was off when i was transporting the bike.
I have tried taking the pads out and pushing the piston back but it doesn't go back fully, and it takes quite a bit of pressure to do this.
Is there an easy fox for this?
Thanks
Thanks
Quoted: 454 Post(s)
Liked 104 Times
Hydraulic discs are pretty easy to service, plenty of videos on youtube for this.
Without knowing the specific brakes you have, you could undo the top cap at the lever end (the reservoir), and then use a hex key (probably 8 or 10mm) to push the piston back in with the pads removed, this will remove the pressure issue, and you should be able to see fluid being returned to the reservoir when your doing this.
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
Hi All,
Thanks
Thanks
As for it not retracting fully when pushing on it. Make sure you push on it evenly, not cockeyed. And push harder (with a plastic tool, tire levers generally work well.)
Also, your alignment may be off. Look up videos for how to align your caliper.
Quoted: 131 Post(s)
Liked 21 Times
If they still wont retract after removing some fluid (i would try this first). Try spraying some silicone lubricant spray around the pistons. It is safe to use and wont damage the rubber seals. Do not use any other types of lubricants because they will damage the seals.
Thanks for all the replies!
sorry for the noob question, but will I need to top up the mineral oil if i do this?
Thanks
Thanks
Also, not all hydraulic brake systems take mineral oil. Some take brake fluid (Dot3 or 4). Make sure you know what kind your brakes take.
Theoretically, no. He's thinking that the air pressure in the sealed system is making it hard to push the piston back, so by taking the cap of the reservoir off, you're removing the pressure. Make sure you rotate the reservoir so it's level (and no fluid will spill out) before you do it.
Thanks corrado, I've got Tektro brakes which I believe are mineral oil.
Maybe I'll get some, just in case!
Without knowing the brake, no one can say whether it uses DOT brake fluid, or mineral oil.
Have you read the manual yet?
Quoted: 283 Post(s)
Liked 262 Times
If any brake system is made for DOT brake fluid, adding mineral oil will most likely ruin every rubber part inside the system. It will never work correctly without a surgical cleaning, and replacement of all the rubber parts.
Fluid
