Is the perfect set up drivetrain silent?
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2586 Post(s)
Liked 5,648 Times
May be a stupid question but I never knew one could be absolutely silent until I rode my “new” 2012 bike 300 total miles. It has an Ultegra group set and when I pedal it makes absolutely no sound. My 2020 bike also with full Ultegra makes what I would consider the ‘normal’ mechanical sound which I have heard on all my bikes for decades. So, brain trust, is my 2020 bike not dialed in or is the 2012 bike an anomaly?
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Quoted: 768 Post(s)
Liked 1,747 Times
I've had fairly quiet drive trains and others that were a tad more noisy, but nothing seemed out of sorts.
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,437 Times
I love a quiet bike. Some bikes and set ups seem to be impossible to get there. I am presently working on a carbon fiber frameset that I have never been able to get to an acceptable level of quietness. I believe the carbon fiber is a root cause for that. Having said that, I have managed to quiet down the drive train considerably by installing new internal cable/housing, chain, cassette, Shimano chain rings, different tire/tube set up. It is mostly 5700 components with an FSA Omega crankset/bb. Switching to Shimano chain rings really helped. I just received a new Shimano PF BB for bb86 and am going to pull the FSA and mount a Tiagra 4600. 48/34, crank set. I am hoping that will quiet the drivetrain even more. I think the cf transmits all the vibration/noise in a way the it kind of reverberates throughout the frame.
Quoted: 4417 Post(s)
Liked 4,873 Times
Are you using the same chain lube on both? Just to rule that out.
Likes For PeteHski:
Quoted: 365 Post(s)
Liked 419 Times
I dislike using superlatives, therefore: all other things being equal, a quieter drivetrain is probably better than a noisier one, since the sound is generated by converting mechanical energy to sound. Efficiency losses due to noise are likely miniscule compared to other sources of mechanical inefficiency (IANAE - I am not an engineer), so I wouldn't worry about some drivetrain noise.
Once the bike is set up properly, the thing to notice is a change in drivetrain noise (type or volume), not necessarily the absolute volume. We've all run across the rider with the grinding/squeaking drivetrain, so just don't be that guy.
Liked 4,873 Times
Likes For PeteHski:
Quoted: 6972 Post(s)
Liked 10,971 Times
If quietness is the benchmark, then the best drivetrain would be a belt drive fixie. How is that gonna work for everyone?
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
It’s probably irrelevant for riding efficiency. The energy in actual sound is typically small. If your drivetrain generated one watt of acoustic energy, you’d experience an SPL of nearly 110 dB at your riding position and NIOSH would recommend you ride no more than two hours per day due to the impact on your hearing. More realistic noises would probably be less than a milliwatt.
Otto
Otto
+1 quiet bikes
My favorite bike to ride is my fixed gear Wabi. It basically makes no sound at all, none. Squirt lubes my chain on that bike. It makes sneaking up on other riders a fun and entertaining thing to do.
Back in the day we would hunt-down freewheels that were really quiet, and, pay more for those. Regina's were especially quiet. Steel bikes with the right equipment and drive train are still really quiet. Carbon fiber bikes sound like a guitar playing bike sounds. I could never ride one because of that.
Yeah, I guess I'm weird in that respect, but I don't care. Quiet is the way to go for me.
Likes For drlogik:
I'll sometimes get a little mechanical noise if I've gone too long since I last cleaned and lubed my chain and cassette. I clean them and lube them and the sound goes away. That is counter to what I would otherwise assume; it seems the dust + lube should muffle the sound and make it quieter, but it doesn't. Clean and freshly lubed is quieter on my bike.
Likes For 308jerry:
Quoted: 1821 Post(s)
Liked 1,696 Times
Likes For alcjphil:
Quoted: 2333 Post(s)
Liked 2,097 Times
My two magnesium framed bikes are quieter than my carbon bikes. I don't ride the steel or aluminum often enough to compare. My material science background isn't the best but the propagation and attenuation of sound varies by material. And, it helps if the chain is clean and properly lubed and the hanger is aligned properly, too. Worn out chains, rings, and cassettes are noisy
Quoted: 427 Post(s)
Liked 700 Times
Ditto. Never thought of that, maybe that's why I thought my bikes were so well tuned! Surprised we still have to deal with it--must be a million and one "remedies" on the web!!
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
Love a quiet bike. A silent 2012 Ultegra setup isn't an anomaly.
As for your 2020...I'd give it a good cleaning, lube, tuning and compare the chains (and chain wear) between the two bikes. Also try to localize where the 2020 sound it coming from..and compare.
Likes For fishboat:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Otto
When freshly lubed, my 2005 Giant OCR Composite 1 (full carbon/Ultegra components/FSA BB) is silent. I only hear the tires on the road unless a little cross-chaining is going on. When I hear chain noise in gears where the chain is straight, I know it's time to clean and re-lube.
On a freshly paved road at slow speeds, the bike was so quiet I started to hear a ping on every rotation of the front wheel. Took me weeks to figure out that the spokes were "rubbing" against each other - producing the ping noise. Going faster - or on a rougher road, the tire/road noise was loud enough to cover up the "ping" noise.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Silence is the goal, but I understand that a metal chain moving across rotating metal teeth is going to involve friction, and therefore noise. But a well-adjusted and lubricated drivetrain can minimize this, so I maintain the moving parts meticulously. I reap the rewards when I'm gliding along, hearing only my tires on the road. That's my happy place.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
A maintained, cleaned, lightly lubricated drive train will be its quietest. There are a number of variables that were discussed above.
If you want a quiet drive train, ride fixed.
Likes For Phil_gretz:
Quoted: 1944 Post(s)
Liked 2,164 Times
Unfortunately I’m over-the-top obsessive with drivetrain noise. Because all of our drivetrains are 8 speed spacing, except one 7 speed freewheel, my logic is that any idiot can make a drivetrain quiet with that much space between the cogs.
I will build whatever cassette range I want if I can’t buy one that way. With full length cogs it is pretty easy. But I have one bike, with a new but not precise downtube index shifter, that I have returned to multiple times. When swapping out spacers that vary by .1mm (.004”) that is pretty far out there.
That said, it is a bit relative to the conditions someone is riding in. If I’m out in a lot of traffic, which is happening less these days, and I hear noise, it has to be pretty significant. If I’m on a mtb on a trail away from everything, that is where the quiet is really noticeable.
John
John
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Lots of the noise you often hear from folks is probably maladjusted RD's or untrimmed FD or cross chaining with the FD rubbing the cage.
A fairly straight chain line on a drivetrain that isn't totally trashed, nasty, and rusty will usually be pretty quiet if adjusted properly.
The interaction of the whole system with the wind and the tires on the tarmac are usually all that I hear. Even to the point you can hear minor changes in tarmac CRR as you go over the surfaces.
Bikes: 2017 Specialized Roubaix Comp, 2019 Cannondale Synopse 105 SE, 2015 Cannondale Quick 5, 2019 Specialized Fatboy
Quoted: 37 Post(s)
Liked 49 Times
Yea but aside from the noise, did you have a nice ride?
Likes For Just Mark:
- 8,9,10 speed drivetrains are quieter than 11,12 speed drivetrain
- steel frames are quieter than carbon ones
- long chainstays make quieter bikes than shorter ones
- smaller cassettes are quieter than larger cassette
- it is usually quieter to use the same chain/cassette combo from the same manufacturer (especially for 11,12 speed drivetrains)
- often times, cheap hubs are quieter than expensive hubs because cheap hubs use thicker seals, thicker grease, less engagement points, all these make for a quieter hub.
- and carbon frames, plus carbon wheel, always amplify sound. All these new school aero frame with bulbuous downtubes act as great sound resonators!
Quoted: 581 Post(s)
Liked 921 Times
Depends on the noise.
A gentle clackeyclacketyclackety as the individual rollers of the chain meet the root of the cassette teeth is not indicative of any problem, but noises that are periodic based ono your cadence - clicking, grinding, snapping - are more likely to be caused by some actual problem.
The harmless sound of the chain is also dependant on the type of lube - I find very thin lubes like Tri Flo to be considerably noisier, while the chainsaw bar oil I use when I have a rusty chain and nothing else to put on it seems to dampen the noise and make the whole system quieter.
Grupetto Bob
Liked 5,648 Times
