What should I do with my VISP frameset ?
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times
I just got notification from UPS that a package will arrive tomorrow from the UK, so I assume that's the Dolan Pre Cursa that I ordered. My current plan is to strip all the components from my VISP and transfer them to the Dolan. This will leave the VISP frameset with a seatpost and clamp. So, I now have to decide what to do with the VISP. It's not all that bad, other than being very heavy. It was made in Taiwan, not China, and the welding is pretty decent, about the same as my leader 721tr. So, here are my options:
1) Sell it.
2) Build it up as a really heavy urban fixie with B43 wheels and a riser bar. Lots of gold and other garish colors, cheap Origin 8 stuff and urban platforms with double straps and wide plastic clips. Low 60s fixed gearing so I can run brakeless. Widest tires I can stuff in there, probably 700x28c with no front brake. Basically, it would be an aluminum version of the naranja. Total rebuild price under $400.
3) Strip all the components off the Vilano and reuse as many of them as possible on the VISP, then sell the Vilano. The build would look pretty wonky, but at least the VISP fits me, whereas the Vilano does not. Also, the Vilano frame quality is horrible. I would still have to spend up to $100.
4) Do nothing. Stick the VISP frameset in the attic, and forget about it.
Regardless of what I do, I don't want to end up with any more bikes.
1) Sell it.
Bikes: 1985 Cannondale SR300, 1987 Canonndale SR800 Black Lightning, 1988 Cannondale SR500 TEAM CREST,1992 Schwinn Paramount PDG Series 3, Volume V6 Cutter,
Option 2 sounds like the most fun but least practical. So that is totally what I would do.
You forgot a key part to any crazy rebuild. Take it to the hood airbrush shop and get some sort of crazy mural on it.
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
Buy another VISP and make a VISP tall bike!!!!!!
If the floor is not open to bargaining,
#2 !!!!!
FYI B43's are officially discontinued whatever that means.
#2 !!!!!
Grumpy Old Bugga
Bikes: Hillbrick, Malvern Star Oppy S2, Europa (R.I.P.)
Quoted: 370 Post(s)
Liked 8 Times
There's a VISP trackie that cruises past me periodically going to work. The rider is a scrawny old barsteward and that bit of road is a prize sod, but I swear he passes me faster than any roadie has. Just goes to show it's the motor not the bike ... but we all know that ... don't we?
Serious question. My son has a VISP roadie from about 3 years ago. We built it up as a cheap commuter with second hand bits and wheels that were trued by coercion and black magic. He's now gone back to using his OCR2 "because it's a much better ride" surprise surprise. But this leaves the VISP doing nothing. I've got enough bits and pieces lying around to make it into a reasonable roadie, but it's still be an all aluminium frame. Would there be any advantage in fitting a carbon fibre fork? The objective would be a smoother ride. I'm not likely to use a roadie style bike very much so there's little value in my buying another bike when I've got the makings (apart from the carbon fork) here. Maybe I'm just looking for another project. Any thoughts?
Regarding the OPs question. There's little point in keeping a frame that doesn't fit. Cheaper frames often have a use in 'lesser' roles. He's got so many flamin' bikes it's nice to see him embarrassed for a change
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
i just got notification from ups that a package will arrive tomorrow from the uk, so i assume that's the dolan pre cursa that i ordered. My current plan is to strip all the components from my visp and transfer them to the dolan. This will leave the visp frameset with a seatpost and clamp. So, i now have to decide what to do with the visp. It's not all that bad, other than being very heavy. It was made in taiwan, not china, and the welding is pretty decent, about the same as my leader 721tr. So, here are my options:
1) sell it.
2) build it up as a really heavy urban fixie with b43 wheels and a riser bar. Lots of gold and other garish colors, cheap origin 8 stuff and urban platforms with double straps and wide plastic clips. Low 60s fixed gearing so i can run brakeless. Widest tires i can stuff in there, probably 700x28c with no front brake. Basically, it would be an aluminum version of the naranja. Total rebuild price under $400.
3) strip all the components off the vilano and reuse as many of them as possible on the visp, then sell the vilano. The build would look pretty wonky, but at least the visp fits me, whereas the vilano does not. Also, the vilano frame quality is horrible. I would still have to spend up to $100.
4) do nothing. Stick the visp frameset in the attic, and forget about it.
Regardless of what i do, i don't want to end up with any more bikes.
1) sell it.
Bikes: Kilo TT, Felt z85, Kona Unit 2-9, 90s Schwinn 9.3 with Noleen fork
Veteran Racer
Liked 765 Times
Well, I got out of bed this morning and saw this bike hanging where the VISP used to be.
