Chainring width vs. drive # of speeds
Senior Curmudgeon
Bikes: Varies by day
Quoted: 5 Post(s)
I've Googled and searched the BikeForums, but haven't yet found a straightforward answer. I find TONS of info on measuring BCD and lots of info on measuring chain width, but little to nothing on determining the width of a specific chain-RING, and what drivetrains it's appropriate for.
First - I have a bunch of chainrings and a good caliper. Where and how do I measure the width of a chainring? I'd assume at the base of the teeth and not on the "shoulder" below the teeth?
Second - What widths will work with what drivetrains. I'd assume that any ring of X-width would work with any drivetrain with a >X-width chain? Therefore, a nine-speed chainring would also work with 8, 7, 6, and 5 speed rear ends?
Third - What is the MAXIMUM width that will work with 7, 8, 9, 10, and 11 speed (specifically) rear cassettes without chain suck?
I'm sure this info is available somewhere, but in 30 minutes of searching, I've not yet been able to find it. I suspect that the finding depends on knowing where to look - therefore I defer to youse guys' superior knowledge.
THANKS for any help - FH
Nishiki road bike, Raleigh road bike, Electra Cruiser Lux 7d, Electra Townie 3i, Electra Townie 1, Whatever I find today!
Quoted: 5781 Post(s)
Liked 2,576 Times
Up until you get to 10 and 11s all chains and sprocket are the same width (inside for chains), namely 3/32" That means that the chains are made to um properly on a sprocket with teeth that are 3/32" wide. If you have a caliper and measure all your chainrings you'll find that all have teeth of the same thickness, subject to working tolerances. You didn't find specific info because you overlooked the obvious, namely that all the chains are 1/2 x 3/32".
What does vary is the outside dimension of the chains, the distance between adjacent chainrings, the thickness of the blank, and the offset of the teeth on the blank, ie. centered, or closer to either face. Those small changes don't affect how a chain runs on the sprocket, but do affect shifting.
FB
Chain-L site
FB
Chain-L site
The Drive Side is Within
I recently ran a 9 speed chain with a 10 speed crankset and an 8 speed rear cluster. Shifted beautifully.
Senior Curmudgeon
Quoted: 5 Post(s)
OK, @FBinNY, that means that 95% of my rings will fit anything up to 9-speed rear ends? The remainder will be ⅛" (single speed, coaster-brake, and internally-geared hubs) and ?? for 10 & 11 speeders?
I'm particularly interested in the chainwheel-tooth width for 10 & 11 speed rear ends, because those sell for more than the "standard" 3/32" ones. I'm sure that I have some of those as well, but I think I need to measure to identify them.
Thanks - FH
Thanks - FH
DIY measurement Worth buying a Digital caliper ? https://www.google.com/search?q=Digi...hrome&ie=UTF-8
Now derailleur chains form their Bushings out of the side plate hole punching. that flange sits under the edges of the Roller and just the very ends of the pin.
chains are more flexible sideways , but as the side plate steel, Inner link, is thinner so is the bushing.. so wear material available is less on the Flange-Bush ..
Shorter wear life as the side plates are thinned as a direct result of less material .
Quoted: 7348 Post(s)
Liked 2,465 Times
@fietsbob, @FarHorizon says he has a good caliper.
The Thinner Bush-flange of new derailleur chains Vs the full bushing Types of Classic, Regina Oro and such, in the 6 speed freewheel era remains.
Running a Full Bush chain On My IGH has Been Much longer wearing than that of using a 8 speed Derailleur chain.
just realize the wear life sacrifices made to have that faster derailing chain.
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
Yes, they are different. I have a thread here showing the actual thickness - that needs updating for the newer stuff. I'm trying to find it now.
Yah, here it is. Please feel free to update chart.
https://www.bikeforums.net/bicycle-me...our-rings.html
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
I have some shimano road triple chainrings hanging up on my bench that are marked "8 or 9 speed."
The bicycle, the bicycle surely, should always be the vehicle of novelists and poets. Christopher Morley
edotomato
Bicycle Mechanics
21
11-02-13 01:07 AM
stevehollx
Road Cycling
1
05-30-10 01:12 AM
